Front tilt bonnet done
David_Doan
I made my front tilt kit this weekend, more pics in my blog for those who are interested. I still have to work out what I’m going to do for stops for the hinge. I’d like to use gas struts if possible. I really want to come up with some kind of power opener, maybe using a power-antenna motor.
UPDATE: Added gas struts as stops, details HERE
G
Old power top system, yes; power antenna, can't see it happening. Most ones I've seen have a plastic belt drive and not near strong enough. UNless you are building a framework for the opener/strut load point I wouldn't do it. I'd be too concerned about bending the front end depending where you tie in at.
Jim_Gruber
David,
Looking good. You've got most of the work done. Look at the hinge plans for this at Gerard's Web page. The plans there have the built in stop. Bolt through the side of the radiator support strut that connects to a slide and teflon bushings. All of the needed bushings available at local Tue Value or Ace. A really simple plan and just a little bit more and you are complete. Teflon bushings will make it much easer to go up and down and with the built in stops no cable to get in the way. I built everything from scratch using drill press, angle grinder, files, etc. Just a little patience required.
RE latches, not sure if you worked that out yet but I used SS Adjustable Draw Latches w Lock from McMaster Carr Catalog. 2 small screws in the body and 2 in bonnet hold everything in place. Go for the ones rated as 400 lbs. load. About $10-15 each as I remember but after breaking 2 sets of other latches from another supplier out of Cleveland these work and look good as well. The adjustable part id important as bonnet will change shape as it's mounting point has changed.
One of Frank C' tips for forward tilt bonnets was welding a piece of 1/4" SS rebar on the inside lip of the bonnet in the curve right at the top orf the arch. This is a weak spot on BE Bonnets and they have a tendency to crack there.
Jim_Gruber
One other thought, Front Harness. I used a 6 way trailer connection as a quick disconnect for the front harness. I combined all of the grounds for the turn signals, flashers, lights into a single connection and ended up with 6 wires to be disconnected - High Beam, Low Beam, Left TS, Right TS, Flashers, Ground. No flashers of a BE but needed for a '68 like Bugsy. A plastic Tie Wrap kept everything secure and together. With a Block and tackle I made out of some old sailing hardware, sure everyone has Harken Ball Bearing pulleys and mainsheet cleats in the back of their garage of course, I used 2 lines that attach to small S-Hooks, that attached to 2 eye bolts that go through mirror mount holes on the fenders. Disconnect the wiring harness, attach the hoist ropes, cover the battery with something just in case, disconnect the front hinge bolts, pull up on hoist rope and you can lift bonnet off of the car by yourself keeping some pressure on the front of the bonnet. Lift up, manuver and rotate sideways and lower bonnet to floor so it stands on end. 5-8 minutes start to finish after some practice.
David_Doan
David,
I'm going to work on the stops after the car is put back together, at this point I can't tell how far it can open before hitting the ground. I really want to explore gas struts to make it easier to open.
And yes, both of my wheel arches have small cracks, I'm going to do the rebar thing too.
AN5Sprite
"...easier to open" LOL
Dude- with a front-tilt, it can't be any easier to open, all the weight is at the front opposite a mighty long lever. Not worth the effort. At least that's how I remember it from my old car every time I hoist my current traditional bonnet. I have all these memories of popping the bonnet with my finger tips...never bashing my head or feeling my lower back give out... ahhhh happy times.
Jim_Gruber
David,
If you add the slides per Kit on Gerard's website it's already done. You'll end up with 3-4" of clearance.
Griz
Front tilt bonnet was the best mod I've made on my BE. I used the plans from Gerard but made them out of 1/4" aluminum which can be worked with woodworking tools as long as you don't get too aggressive with feed rates. Then installed leather straps & buckles for hold down for a nice "period look".
Griz
T Front Tilt or Stock Fit Bonnet Spridgets 18
Rut Front tilt bonnet latch Spridgets 40
Jim_Gruber One Piece Spridget Front Tilt Steel Bonnet availab Spridgets 12
Jim_Gruber Bonnet Latches for Front Tilt BE Bonnet Spridgets 9
bugimike Another front-tilt bonnet question Spridgets 0
T bugeye front tilt bonnet Austin Healey 4
Steve P. Bugeye front bonnet tilt: anyone built their own? Spridgets 3
C Mark I front tilt kit Spridgets 2
Keith_M bugeye front tilt hood fastener -- choices Spridgets 9
Rut Bugeye front tilt latches Spridgets 24
D Added gas struts to front tilt Spridgets 11
D Front-tilt latches Spridgets 15
toysrrus Bugeye: "FRONT TILT OR REAR TILT"? Spridgets 16
56HealeyDan 100-4 Front Crankshaft Seal Austin Healey 7
AngliaGT 1997 Miata - Anyone Have a Picture on How to Mount the Front License Plate Bracket? Other Cars 12
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
1 TR2/3/3A Rimmer Brothers Replacement Front Wing Quality? Triumph 8
Carlbanan56 MGB Front hub MG 4
J MGB Front Wheel Bearings. Re-grease or replace? MG 19
scottkilpatrick TR4/4A Front Brakes - Basics for Pads Triumph 11
C MGB-GT MGB-GT Front Ride Height MG 0
C MGB-GT Front Ride Height MG 0
J For Sale Bilstein Front Shocks for Jaguar E-Type 727-498-6493 Jaguar Classifieds 0
J TR2/3/3A Mystery knocking sounds at front wheel Triumph 11
E Wanted 1963 Healey 300 mark 2 front grille wanted Austin Healey Classifieds 0
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
AUSMHLY Front Wheel Spin Drag Austin Healey 6
mctriumph TR2/3/3A Front Suspension upgrades for the 59 Triumph 10
CARSINC For Sale Sprite Front Wire Wheel Hubs Spridgets Classified 0
bighealeysource Front Brake Adjusters Austin Healey 0
L Wanted right front turn signal 1975 TR6 Triumph Classifieds 2
TR3Acustodian TR2/3/3A Replacing "H" front badge Triumph 11
G Rebuilding Front Seats Austin Healey 4
drooartz MGB Front suspension rebuild is next MG 57
Joel Lester TR2/3/3A What final front suspension torque settings needed? Triumph 7
H TR4/4A Advise asked for front repair Triumph 1
A BN7 Front Hub Stud Nuts Austin Healey 5
P 100/6 Front Wheel Alignment Austin Healey 10
Prof. T Wanted 1974 - TR 6 Front Chrome License Plate Holder Triumph Classifieds 1
S For Sale Triumph TR 2-3 Front Left Fender Triumph Classifieds 2
B Wanted Bugeye front bonnet fender mirror like this Spridgets Classified 5
P MGB 1974 MGB front spring length. MG 0
