front disc brakes- 66 sprite
bullno
Novice Bruce- 2 years 4 months and still restoring. Put on rebuilt front brake calipers. Bled the lines but there is still considerable drag on rotor. The rear brakes (drum) disengage when released. Open the bleed screw slightly on either side it frees up both sides. Since the rear brakes release I would not think my problem is in the master cylinder. Anyone have any suggestions. Thanks Bruce
That sounds suspiciously like the flex lines to the calipers.
They collapse on the inside, and yet look good on the outside.
If they are older, my suggestion would be to change them.
Hope this helps.
Dave :savewave:
P.S. too make sure, instead of loosening the bleeder, loosen the line as it goes into the flex hose.
Good luck.
Mine were doing this too, before I had worse problems.
I have been taking it easy on the brakes since, slowing by compression more.
One suggestion people made for me was to check the brake light switch, sometimes it hangs up / interferes with the pedal.
If it's screwed in a bit too far I guess this can happen.
Also of course the flex lines, they don't last forever.
There is drag on the front brakes, centrifugal force of the spinning rotor is what moves the pads back. If you are stepping on the pedal and checking the front brakes with the car on stands, there will be drag. If everything is new, expect lots of drag until the pads seat.
Thanks for everyones advise, the lines are new and I get good flow through bleeder. I don't have the tires on so I am pulling on just rotor, I can turn but it is hard. Will proceed forward and check when I get it down. thanks for everbodys advise. Bruce
Bruce: Probably not a concern of yours but while you are on the subject of dragging front brakes I wanted to mention that I have found that getting the cut away on the caliper pistons aimed in the correct direction [down] is somewhat critical. Noticable in dragging brakes once you get back on the road.
Kurt.
This statement alone says it's not the flexible lines. It is also saying it's not the calipers or pads. Therefore the problem must be the master cylinder not releasing or another physical obstruction in the hydraulic system common to both front wheels. Try adjusting the push-rod between the brake pedal and the master cylinder, or possibly the brake pedal pivot is rusty and sticking.
Ohiobugeye Front brakes won't release after disc brake conversion Spridgets 10
C Wanted 3000 Front Disc Brakes Austin Healey Classifieds 4
C Bugeye Disc Front Brakes FORUM Navigation Questions 0
C Bugeye Disc Front Brakes Spridgets 4
bighealeysource front disc brakes conversion for 100-4 Austin Healey 21
T Check list to convert to front disc brakes Spridgets 9
T Front disc brakes make a big difference? Spridgets 5
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
K TR2/3/3A Securing new brake disc to the front hub? Triumph 4
I Bug eye front disc brake conversion. Spridgets 5
L Denis Welch Front Disc Conversion Kit 100/6 Austin Healey 6
KVH TR4/4A Front Wire Wheel Hubs Differ from Disc Hubs?? Triumph 5
K TR2/3/3A Front disc brake squeal.... Triumph 4
croz TR2/3/3A Moss Replacement front disc pads Triumph 3
R BJ7 Front Brake disc hitting Austin Healey 12
maxwedge5281 front disc brake hubs for steel wheels Austin Healey 24
steveg Front Toyota disc conversion now complete - photo essay Austin Healey 0
pkmh Dismantling BJ8 Front Hub From Caliper Disc Austin Healey 20
R TR4/4A Disc wheel studs front and rear TR4a irs Triumph 4
O Front disc's from a 63 Midget Spridgets 0
Trevor Jessie Front brake line locating brackets [disc]. Spridgets 6
M BN4 prob with disc brake conversion[front] Austin Healey 2
56HealeyDan 100-4 Front Crankshaft Seal Austin Healey 7
AngliaGT 1997 Miata - Anyone Have a Picture on How to Mount the Front License Plate Bracket? Other Cars 12
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
1 TR2/3/3A Rimmer Brothers Replacement Front Wing Quality? Triumph 8
Carlbanan56 MGB Front hub MG 4
J MGB Front Wheel Bearings. Re-grease or replace? MG 19
scottkilpatrick TR4/4A Front Brakes - Basics for Pads Triumph 11
C MGB-GT MGB-GT Front Ride Height MG 0
C MGB-GT Front Ride Height MG 0
J For Sale Bilstein Front Shocks for Jaguar E-Type 727-498-6493 Jaguar Classifieds 0
J TR2/3/3A Mystery knocking sounds at front wheel Triumph 11
E Wanted 1963 Healey 300 mark 2 front grille wanted Austin Healey Classifieds 0
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
AUSMHLY Front Wheel Spin Drag Austin Healey 6
mctriumph TR2/3/3A Front Suspension upgrades for the 59 Triumph 10
K TR2/3/3A Rear tire pressure when there is an anti roll bar at the front of the car? Triumph 1
CARSINC For Sale Sprite Front Wire Wheel Hubs Spridgets Classified 0
bighealeysource Front Brake Adjusters Austin Healey 0
L Wanted right front turn signal 1975 TR6 Triumph Classifieds 2
TR3Acustodian TR2/3/3A Replacing "H" front badge Triumph 11
G Rebuilding Front Seats Austin Healey 4
drooartz MGB Front suspension rebuild is next MG 57
Joel Lester TR2/3/3A What final front suspension torque settings needed? Triumph 7
