Electrical troubleshooting ideas??
Monark192
Here we go - I put the key, turn it and nothing - except that the fuel gauge moves. No fuel pump, no starter motor. Lights work, cleaned the connections at the fuse block, and the voltage at the battery is good. Where do I go from here?? I am sure it is something simple as the car started, ran for a minute in place. When I went to restart 10 minutes later - nothing! This is serious - the wife said lets go for a ride in the Midget and I had to tell her the bad news.
Loose wire at the solenoid, jammed starter, or bum key switch.
Try jumping across the solenoid with an old screwdriver (key OFF) and see if it spins the starter. If not, the starter is jammed. Put the car in 4th gear, brake off and rock it. You will hear it pop out. Or use a small wrench on the square nub of the starter armature. It is exposed.
If it still has troubles, I bet the key switch is bad which would be the most logical since the fuel pump isn't working.
Try a hot wire from the + of the battery to the + of the coil and see if the pump works and you have an ignition light.
hey, we just got through taking the engine out, and put everything back together, (sometimes I wanna have a heart to heart with whoever decided you have to take the whole engine out to get to the clutch, but /I/ can't come up with a better design, soo..) anyway, everything goes, but there's no spark, and the coil's not getting any power..any ideas? I have a master electrician looking it over, but, yanno, there's nothing like getting a jump on it...
if you are replacing the clutch, don't forget to check the pilot bushing for wear. it's alot easier to replace it now then hear it squeal later. sometimes it's better to put both in together to reduce the potential for the pilot bushing to cock. i have done it both ways and at least once had to remove the engine to realign/replace the bushing after the car kept squealing.
:: nods :: oh, yeah, I checked and double-checked everything, 'cause I can't take that thing out on my own! (or I could, but not in one day, yanno?) help is few and far between!
Okay - I have an ignition lightand the fuel pump runs. Jumping across the solenoid spins the starter - does this mean the solenoid is bad or??
Okay - I removed the small wire that runs from the solenoid to a small thingy (note to self - buy a shop manual) mounted up under the fender and she runs!!!
Thanks spritenut!
N Electrical Troubleshooting Advice Needed Spridgets 6
H need troubleshooting help with 100-6 fuel?electrical? Austin Healey 9
nevets Troubleshooting OD electrical question Austin Healey 6
C TR2/3/3A TR3A Electrical problem Triumph 20
CARSINC Sprite Electrical System Information Spridgets 2
K TR2/3/3A Turn signal flasher issue.....electrical is not my strong point. Triumph 13
R Electrical Experts - Vixen 2500 - Ignition Switch Observation? TVR 10
N MGB Electrical Part Identification MG 3
KVH General Tech Yes, the Horns Again--Electrical TR4A Triumph 8
SNClocks Electrical Wire Lug Spridgets 2
K TR2/3/3A Another electrical problem: Park light & 5ignal light on Drivers side are brighter than....... Triumph 3
F General TR Electrical parts Triumph 6
S TR2/3/3A Electrical Triumph 31
lram59 General Tech Electrical terminals Triumph 8
6 Electrical Help Please Spridgets 7
B Bugeye Electrical Diagram with additions Spridgets 6
B Austin-Healey late 3000 BJ8 Electrical Diagram Austin Healey 1
B Austin-Healey early 3000 BJ8 Electrical Diagram Austin Healey 0
B Austin-Healey 100-6/3000 Electrical Drawing Austin Healey 2
B Austin-Healey 100 BN2 Electrical Diagram Austin Healey 0
B Austin-Healey 100 BN1 Electrical Diagram Austin Healey 0
KVH General Tech O/D Electrical Wire Burned Triumph 22
J TR4/4A Getting electrical shock from horn button when using the horn. Triumph 9
E GT6 Help electrical guru needed Triumph 4
B Bugeye Electrical Diagram Spridgets 0
Got_All_4 TR5/TR250 Wiring/Electrical Mystery Worked Perfect Then Not Triumph 5
D TR2/3/3A TR3A electrical issues Triumph 2
B Bugeye Electrical Wiring Diagram in Logic Format Spridgets 17
dbenichou289 TR2/3/3A Heater electrical connections Triumph 4
Simmo General Tech Electrical question Triumph 4
B BJ8 Phase 1 Electrical Diagram Austin Healey 21
T TR6 72 TR6 electrical snafu Triumph 4
P TR6 Electrical Problem Triumph 26
M Difficult Electrical Problem in 59 BE with Generator Spridgets 6
N Electrical Issues Need Help Austin Healey 8
H Re: electrical short wiring damage Spridgets 11
I Bugeye electrical questions Spridgets 17
steveg Electrical sleeving Austin Healey 11
N TR6 Electrical Issues Triumph 5
N Electrical issue. FORUM Navigation Questions 2
C Ghost in the electrical system Austin Healey 51
S TR2/3/3A Electrical Issue Triumph 40
KVH General TR Steering Shaft/Column Short Circuit?--Electrical Issue with Light Switch Triumph 3
6inline Electrical gremlins giving me fits Austin Healey 18
DornTRoriginal TR2/3/3A Electrical Wiring Best Practices Triumph 13
R TR2/3/3A Early TR3 electrical system Triumph 12
K TR2/3/3A More electrical....the Starter? Triumph 8
S TR4/4A Electrical wiring tips Triumph 2
K TR2/3/3A More electrical....the Starter? Triumph 5
B TR2/3/3A Electrical Problem Triumph 13
