electrical gremlins
Stewart
Run into a weird problem today. Finally got the 73 close to being dialed in (rear throttle return spring broke so I cant sync the carbs) and now that its running like a sports car should now when I rev the engine up in gear to 5k indicated the red ignition light comes on. Shift and it goes out however it did not come on while at that rpm in 4th (Dont ask how I know)I'm pretty sure the tach may be off as it's been funky since I got the car but would the ign light glow for an over volt or just undervolt condition? At idle its putting out a healthy 14.4.
The other gremlin I've run into is with the head lights the left one in particular. It hasn't burned out but it just glows weakly and the high beam indicator is dimly glowing. High beam is also weak. Right side is fine. Any ideas
Alternator belt loose or diode bridge dropping at higher RPM.
Grounds on the "glowing" headlamp.
..at least that'd be where I'd start.
Head lights fixed. The white wire going to the marker light had been cut at somepoint by the dpo and then twisted back together. Once that was fixed properly everything is back to normal. Strangely the marker was working perfect. I cant wait till I get the new harness in so I dont have to deal with dpo fixes anymore.
Now to figure out why the alt. is going what its doing. Belt is nice and tight.
Hello Stewart,
the ignition warning light will light up if the alternator output voltage gets too high, does you battery area smell of sulphuric acid, a sure clue to overcharging?
Alec
Ditto on Piman AND belt slippage (not likely) but the other things that can be easily looked into are...
Weak/worn/bouncing brushed in the brush pack. You can yank the white plastic pack and look inside. The outer brush will always be worn more than the inner, but it still should have some length to it and it's spring should be sufficiently strong to keep the face of the brush against the contact ring on the armature.
The other thing requires removal of the unit. At very high revs it is possible to cause and "open" in the armature (stator) windings due to simple centrifugal force. You'll have to have a pro at an alternator/starter specialty shop look for that one.
BTW: When you go back together with it, use a name brand (Gates) belt that has "teeth" on the inside. They run cooler, last longer and don't have as much of a tendency to slip.
Jack
6inline Electrical gremlins giving me fits Austin Healey 18
jvandyke electrical gremlins Spridgets 39
R Electrical Gremlins - No Power Spridgets 10
S Chasing Electrical Gremlins Triumph 1
C TR2/3/3A TR3A Electrical problem Triumph 20
CARSINC Sprite Electrical System Information Spridgets 2
K TR2/3/3A Turn signal flasher issue.....electrical is not my strong point. Triumph 13
R Electrical Experts - Vixen 2500 - Ignition Switch Observation? TVR 10
N MGB Electrical Part Identification MG 3
KVH General Tech Yes, the Horns Again--Electrical TR4A Triumph 8
SNClocks Electrical Wire Lug Spridgets 2
K TR2/3/3A Another electrical problem: Park light & 5ignal light on Drivers side are brighter than....... Triumph 3
F General TR Electrical parts Triumph 6
S TR2/3/3A Electrical Triumph 31
lram59 General Tech Electrical terminals Triumph 8
6 Electrical Help Please Spridgets 7
B Bugeye Electrical Diagram with additions Spridgets 6
B Austin-Healey late 3000 BJ8 Electrical Diagram Austin Healey 1
B Austin-Healey early 3000 BJ8 Electrical Diagram Austin Healey 0
B Austin-Healey 100-6/3000 Electrical Drawing Austin Healey 2
B Austin-Healey 100 BN2 Electrical Diagram Austin Healey 0
B Austin-Healey 100 BN1 Electrical Diagram Austin Healey 0
KVH General Tech O/D Electrical Wire Burned Triumph 22
J TR4/4A Getting electrical shock from horn button when using the horn. Triumph 9
E GT6 Help electrical guru needed Triumph 4
B Bugeye Electrical Diagram Spridgets 0
Got_All_4 TR5/TR250 Wiring/Electrical Mystery Worked Perfect Then Not Triumph 5
D TR2/3/3A TR3A electrical issues Triumph 2
B Bugeye Electrical Wiring Diagram in Logic Format Spridgets 17
dbenichou289 TR2/3/3A Heater electrical connections Triumph 4
Simmo General Tech Electrical question Triumph 4
B BJ8 Phase 1 Electrical Diagram Austin Healey 21
T TR6 72 TR6 electrical snafu Triumph 4
P TR6 Electrical Problem Triumph 26
M Difficult Electrical Problem in 59 BE with Generator Spridgets 6
N Electrical Issues Need Help Austin Healey 8
H Re: electrical short wiring damage Spridgets 11
I Bugeye electrical questions Spridgets 17
N Electrical Troubleshooting Advice Needed Spridgets 6
steveg Electrical sleeving Austin Healey 11
N TR6 Electrical Issues Triumph 5
N Electrical issue. FORUM Navigation Questions 2
C Ghost in the electrical system Austin Healey 51
S TR2/3/3A Electrical Issue Triumph 40
KVH General TR Steering Shaft/Column Short Circuit?--Electrical Issue with Light Switch Triumph 3
DornTRoriginal TR2/3/3A Electrical Wiring Best Practices Triumph 13
R TR2/3/3A Early TR3 electrical system Triumph 12
K TR2/3/3A More electrical....the Starter? Triumph 8
S TR4/4A Electrical wiring tips Triumph 2
K TR2/3/3A More electrical....the Starter? Triumph 5
