Do I use a sealent on a head gasket
Flagstaff
Sorry I could not find an answer to the above question but I think there was one at some time.
The question should I use some kind of sealant on a cooper head gasket. If yes what to you recommend. If not thanks for the input.
Curt
Hello,
I have used THIS with good results.
Of course your mileage may vary.
m
On cooper head gasket gaskets, most definately use a sealer, copper gasket spray, Permatex Hitack spray gasket, even aluminum silver paint works.
regularman
Another one singing praises for permatex copper spray. I had already replaced the head gsket once on the midget, used this the second time and it fixed my problems. I have also used it on a subaru that had already blown two head gaskets, and also a mazda truck that had blown a head gasket and worn a groove between 3 and 4 cylinder and also on my moms escort that had a head gasket problem.
This last on with the midget learned me. I will always use this stuff on ahead gasket. Its cheap and it works.
recordsj said:
what about a sealant when using Payen brand head gasket?
If we are talking about the black Payen head gasket, it can be installed dry, or with sealer, if sealer is used I recommend the Permatex Hitack gasket spray with this head gasket, over the copper gasket spray. The black Payen head gasket does not need a sealer, we use sealer on the race engines with the black Payen head gasket, because it does nothing to affect the seal, but makes gasket removal easier, it comes off without tearing. Hope this helps.
Spridget64SC
In my shop, the Black paper type gaskets get Silver spray paint. Copper/steel composite gaskets get "Copper-Coat" type spray. Like Hap said, the silver paint allows easier removal of the black head gasket.
HTH,
Mike Miller
Rhodyspit75
If I’m reading this correctly I seems that both Hap and Mike are saying that the reason to use the spray is for removal and it’s not necessary to help the gasket seal. I did see on the BPNW site that they recommend it. This is for a 1275 that’s not raced so I’m not concerned with removing and replacing. The gasket i removed had failed between 2&3 cylinders. I have no idea whose gasket it was but I’ve ordered the Payen black from BPNW.
By the way Hap I get lots of compliments on the VTO wheels I bought from you for my Bugeye.
Thanks, Ernie.
Pythias
Over the years I've heard both with and without sealant recommended, depending upon who's doing it.
Those who say without say that if you need sealant you haven't properly prepared the surfaces--that if you've had them properly machined you don't need it and when you have to do a rebuild it's a pain to get it all scraped off again--- and to only use plastic scrapers when you do...
Those who say to use it say that it's cheap insurance against flaws and you are all but guaranteed a proper seal... and that it can save the expense of taking the block and head to a machine shop. ...
Pick you poison.
bobhustead
A copper bearing liquid Kopr-Kote, Permatex spray-a-gasket, etc., is what I have used on every head install. BTW, you will probably get more responses if you start a new thread than by posting new matter in a thread that has been dead for a while.
Bob
LarryK
Have used the copper spray for years on all head gaskets without a failure. Just remember to retorque in 500 miles.
Platinum
Lately, with the "new, improved" head gaskets that are "environmentally friendly" the spray coatings are insurance.
We've always used the Permatex copper.
LarryK
What I have used for 55 yrs.
K TR2/3/3A Cylinder head stud height question? Triumph 4
K TR2/3/3A Memory refresh: non ARP cylinder head studs..... Triumph 2
K TR2/3/3A NEW update on my cylinder head/gasket story........ Triumph 4
K TR2/3/3A Skimming the cylinder head. How do I find the....... Triumph 4
K TR2/3/3A cylinder head washer Triumph 0
K TR2/3/3A The thread pitch of the cylinder head studs? Triumph 10
K TR2/3/3A Getting a cylinder head skimmed for flatness.... Triumph 2
K TR2/3/3A Update on the head gasket repair......something is not right/ Triumph 8
K TR2/3/3A New head gasket is installed.....did a compression check motor cold. Triumph 4
J Spitfire Payen Head Gasket -which way up ? Triumph 6
R TR6 Classic british car mechanic on Hilton Head SC Triumph 0
K TR2/3/3A The steel head stud washers? Triumph 7
K TR2/3/3A Applying the Permatex copper gasket spray to the head gasket? Triumph 6
S Spitfire Cyl head coolant hose fitting Triumph 1
B TR6 Milling the head Triumph 5
sim 948 aluminum head gasket Spridgets 2
K TR2/3/3A Retorquing the Cylinder Head after the initial torquing.? Triumph 23
S TR2/3/3A Rebuilding a cylinder head Triumph 30
petnatcar Cylinder Head Nuts - Tightening Sequence Austin Healey 2
tahoe healey "Convertible" vs "Drop Head Coupe" Austin Healey 8
K TR2/3/3A head gasket repair wire Randall Triumph 1
K TR2/3/3A Checking a cylinder head with a straight edge to see if it's warped? Triumph 22
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
Celtic 77 MGB Mystery cylinder head attachment. MG 4
tinman58 TR2/3/3A Head Gasket Triumph 15
K TR2/3/3A Cylinder head removal and valve adjustment Triumph 2
K TR2/3/3A Update on the blown head gasket Triumph 33
K TR2/3/3A Bad news...blown head gasket??? Triumph 15
F TR2/3/3A head light buckets Triumph 3
D TR2/3/3A cylinder head oil plug bolt size Triumph 6
R Big Healey 100 Head Austin Healey 4
R For Sale 100 engine block w/head Austin Healey Classifieds 3
B Surprise screw head Restoration & Tools 0
D TR6 Gp 2 cam, head shaved ,shorter pushrods, with a rough idle Triumph 10
K TR2/3/3A Who sells steering wheel control head "Allen head'' grub screws? Triumph 5
B Head Re-Torque Austin Healey 8
AUSMHLY Reduced-Shank Cylinder Head Studs Austin Healey 0
AUSMHLY Cylinder Head Studs Austin Healey 3
AUSMHLY Cylinder Head Input/Exhaust Circlip/Split pin Austin Healey 3
AUSMHLY Engine Flush After Head Gasket Leak Austin Healey 19
KVH General Tech Rusted Cylinder Head Freeze Plug--WOW Triumph 16
KVH General Tech Head Gasket Sealant Triumph 4
AUSMHLY BJ8 Cylinder Head Installation Austin Healey 6
KVH General Tech ARP Head Studs/Liner Protrusion Triumph 10
healeynut For Sale 100/4 block and head Austin Healey Classifieds 1
K TR2/3/3A Inside the horn and turn signal control head. Triumph 3
T TR2/3/3A Water pumps/head cooling Triumph 22
T TR2/3/3A cylinder head ,valves and springs Triumph 0
KLUTZ Wedge Adding Blue Devil head gasket sealer Triumph 4
