Contact OL Oxidation Solvent
Jeb
Member
Hi folks....
Just wanted to make a plug for Wurth Contact OL oxidation solvent. I have never seen another product that works so well to eliminate corrosion on electrical contacts. This stuff is particularly helpful on old British switches that have gotten arthritic.
The stuff is stupid expensive, but the first time you save a $75 Jaguar rocker switch or an unobtanium four way flasher switch for a TR-250, you'll realize the stuff is like liquid gold.
It's available from Wurth USA and most German car specialty shops carry it.
One nice side effect of the stuff is that on black plastic switches, it also makes the black plastic shiny and new looking.
Jeb
AHSebring How do I create "Contact" to "Start Conversation" in my About Tab? FORUM Navigation Questions 1
CARSINC How to remove factory contact cement? Spridgets 9
71TR6 TR2/3/3A Control Head horn contact Triumph 7
RAC68 Professional Trim and Upholstary Contact Cement Austin Healey 4
B "Healey 5-Speed"/Pete Delaney Contact Austin Healey 27
S TR2/3/3A Contact cement for vinyl Triumph 6
Popeye Contact adhesive for open cell foam - seat rebuild [TR4A] Restoration & Tools 8
Michael Oritt Brake pedal contact or mercury switch Austin Healey 19
Tinkerman TR2/3/3A Removing old contact cement Triumph 6
TR4nut TR2/3/3A TR3/4 Water Pumps - Anyone have the ebay rebuilder contact info? Triumph 5
Tinkerman How to remove dried on contact cement? Triumph 11
T Wheel rim corrosion at tire bead contact Austin Healey 1
TonyPanchot Art Lipp Contact Triumph 3
Tinkerman Fun With Contact Cement On My Dash Triumph 2
ekamm contact cement use Triumph 7
ekamm Contact Cement Go Away Triumph 3
T Guys - contact me before bidding on Tr-man items Triumph 13
Newkie running lights contact or lack of? MG 2
mccalebr Trying to contact Jeff Dahn [Bugeye58] Spridgets 4
Gray_Cat Morrisservice Contact Spridgets 4
angelfj1 Personal Contact at Moss Motors Triumph 6
CraigLandrum Weldwood contact cement oopsie Triumph 28
jlaird contact Bud direct via emale Spridgets 5
1965_MGB MGB MK1 MGB Horn Contact Question MG 0
emann BE horn push contact too long? Spridgets 8
Michael Oritt Kendall Jones contact info Racing 3
bcliff Contact info for Gaston [the dash guy] Triumph 16
jaybird MGV8 & MG2006 contact list MG 0
C Hub Rebuilder Contact? Triumph 0
Alfasudcrazy TR6 TR6 contact breaker points - closing Triumph 3
T CONTACT Sunbeam (Rootes) 1
Editor_Reid MGB-GT Want to Contact MGB-GT V8 Owners MG 9
S TR2/3/3A voltage regulators gap and oxidation Triumph 10
JimLaney Clean Oxidation from cast aluminum Restoration & Tools 6
I Can someone explain this? Iron oxidation and heat Spridgets 4
glemon Parts Washer Solvent Question Restoration & Tools 11
Morris A good solvent? Spridgets 9
Sebring222 Wanted- Solvent for dried brake fluid MG 7
dklawson Solvent Pop - Is There an Easy Fix? Triumph 10
2wrench Solvent is hazardous waste, so what to use? Triumph 19
Randy Forbes Solvent for a Parts Washer Restoration & Tools 17
