BE horn push contact too long?
emann
ok,
I now have my steering wheel nut threaded onto the column - thanks to everyone's suggestions on how to rework the column threads.
But now, the horn push will not stay in place because the contact sticks out too far.
I'm thinking of shaving a little off the contact so it will fit, but am wondering if there's something I have wrong (OK, I KNOW I have something wrong, just not sure what)
Does the hub that sits between the steering wheel and the dash go on with the oblong side sticking up towards the sky? That's how I have it know, but am wondering if spinning it would make a difference.
Any other ideas on what might be wrong?
TIA,
Ed
jlaird
Did you take that plastic tube thing off. It is only for shipping.
emann
emann
your kidding - really ????
never would have guessed that.
Thanks Jack.
so i assume that means the shorter metal piece goes down towards the hub and the longer piece sticks up to the horn push? with the plastic piece, i figured it doesn't matter, with out it, it probably does.
never, ever would have thought of taking the plastic off.
jlaird
Hehe, dosn't compress much with the plastic on.
emann
emann
got home last night and looked at the horn push.
Jack, I can't see how the plastic tube thing is just for shipping. The spring is stuck inside it and will not come out.
The push I have came from Moss Motors (part #560-430). It has about a 1-1/2" long clear plastic tube. Sticking out of one end is a 1" long brass-colored piece of metal with 6 sides and a rounded off tip. Sticking out of the other side is a 1/4" piece of the same stock but the end sticking out has a bit of flattened solder on it.
The two pieces are connected inside the clear tube by a piece of wire braid. The clear tube is 6-sided at both ends internally but is round and smaller inside at one point to keep the two pieces apart. The back of the longer piece has a spring behind it so that it is spring-loaded.
The smaller piece of brass will come out of the tube if you push in the longer piece, but the long piece will not come out. I cannot figure out what is holding it in.
Sorry for the long post, but this one's really got me baffled.
TIA,
Ed
jlaird
Have the part in my hand at the moment.
The short brass end is pressed into the plastic. The long end slides freely.
One end must ride on the brass ring on the dash extender the other must push against the metal on the horn button.
The small end with the ball goes against the dash extender behind the wheel.
To get one to work properly some time ago I had to make a new tube with thin plastic from a tooth brush case, the clear plastic kind. Took a bit of fussing to get it the right length.
Is the contact on the horn button clean.
emann
emann
Jack,
yes the horn button contact is clean.
Everything works, it just won't all fit into the steering wheel hub. The horn push sits out about 3/8" where it sits on the contact.
I think i'll look at shortening it up - either the plastic piece or the long brass piece.
Thanks,
Ed
jlaird
Guess you could grind off the long end some???
K Restoring Horn Push Button Austin Healey 12
Joe Reed General MG Early Midget horn push on Personal wood rim steering wheel... MG 3
P Grounding of Horn Push-Bugeye Spridgets 4
F Replacing the horn push adjustable steering wheel Austin Healey 7
C Wiring new Mota Lita horn push into my MG Midget Spridgets 6
longbridgehealey horn push Spridgets 3
wangdango TR6 '76 tr6 horn push Triumph 1
livinginthepast Stupid Q dejour - horn push/badge won't stay put! Spridgets 14
jvandyke after market steering wheel horn push set up Spridgets 49
C Need a horn push for '68 Sprite Spridgets 0
drooartz New wheel with horn push Spridgets 2
NickMorgan Sticking horn push Triumph 8
P TR6 Horn issue 1974 TR6 Triumph 5
P TR2/3/3A TR2 Horn Mounts Triumph 7
K 68 midget. No horn, headlights, turn signals Spridgets 9
J MGB HELP, my horn does not work! MG 8
olarson TR2/3/3A Horn Replacement Wiring Triumph 7
Sopwith_Camel horn relay wiring Jaguar 3
K TR2/3/3A The horn and turn signal assembly. Triumph 3
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
D TR2/3/3A Traffic at or and horn button not working Triumph 2
P TR2/3/3A 6 volt Oogah horn Triumph 8
K TR2/3/3A Inside the horn and turn signal control head. Triumph 3
jehuie Morris Minor horn mystery British Motor Corp 12
Sixpack TR6 Horn Mystery Triumph 3
J TR4/4A Getting electrical shock from horn button when using the horn. Triumph 9
R Horn relay Spridgets 2
K TR2/3/3A The chrome ring around the bakelite horn button? Triumph 4
T TR2/3/3A TR3A rack & pinion conversion question - solution for horn & directional lever Triumph 2
P TR6 TR6 Horn Relay Problems Triumph 8
S Indicator / Horn Switch Austin Healey 10
nichola TR6 Help me - circuit breaker above horn relay Triumph 5
nichola TR6 What is this, connected to horn relay? Triumph 8
Bayless Wanted: Spridget horn button bracket Spridgets Classified 1
71TR6 TR2/3/3A Control Head horn contact Triumph 7
71TR6 TR2/3/3A Windtone WT618 horn current Triumph 9
D TR2/3/3A Tr3 horn testing and wiring Triumph 8
Kurtis Bugeye Sprite front frame rail horn replacement Spridgets 5
D TR6 Replacing Horn insert in steering column Triumph 11
nevets BN6 horn button Austin Healey 17
C TR2/3/3A Horn Control replacement Triumph 3
Bayless Question on '67 horn button Spridgets 5
K TR2/3/3A Horn Button Removal Triumph 10
S TR2/3/3A Horn not working unless I rotate the control head Triumph 6
TRMark T-Series Horn/Dipper Switch MG 4
R German horn on BJ7 Austin Healey 8
K Is my BJ8 horn switch connected to ground positively or negatively? Austin Healey 3
longbridgehealey Horn question follow up Austin Healey 12
longbridgehealey 100-6 BN4 horn question Austin Healey 2
UmmYeahOk GT6 Steering Wheel Horn Troubles Triumph 11
