TR2/3/3A Contact cement for vinyl
sp53
Contact cement for vinyl. I have heard that contact cement canreally very. I forgot, but I guess the can color and type can make a big differenceand the people around here at the store are hit and miss when you ask about stuff like that,so I am putting up to you guys, and thanks in advance.
steve
charleyf
My suggestion is to go to a local auto upholstery shop and ask if you can buy a pint/ quart of their regular upholstery glue. We were able to do that locally and it has worked out the best. YOU ARE USING A PRODUCT AS IT WAS INTENDED, NOT SOMETHING THAT YOU WERE ABLE TO GET THAT MIGHT WORK!!!! They usually have the glue in a large container and may or may not have empty cans available. So if you were to take your own jar or sealable can all they would have to do is shoot their pressurized glue into your container. You can then purchase small disposable brushes at most all hardware stores to apply it with. Works much better than pressurized cans.
Charley
malbaby
Another product that I have used for vinyl is laminate contact adhesive...ie what kitchen cabinet makers use for bonding laminate to hardboard.
ed_h
Most any contact adhesive will stick down vinyl, but some will let go in the high temps a car interior will see. I know that the laminate adhesive in kitchens will sometimes fail near ovens or other heat sources.
Ed
martx-5
I've had very good luck with 3m Hi-Strength 90 spray adhesive and for areas that you can't spray, I've used Weldwood Contact Cement in the bottle.
Also, the 3M Super 77 spray is supposed to be good also, but I can't speak from experience.
Brinkerhoff
An auto upholsterer will have Weldwood Landau Vinyl top contact cement . Take an empty qt. paint can. Brush it on and hit it with a hair dryer to tack it then "stick it and forget it". You can re heat it and reposition fabric if careful and it will restick.
S
sp53
Thanks you guys all good stuff and I wrote down what John used on his tr2. Most of his stuff was leather and I have had a problem over the years with a lot of contact cement on vinyl. I think part of my problem is the type of vinyl I was using, mostly cheap stuff with that white material on the back. I noticed the original vinyl had like a denim on the back, and yes when the vinyl gets hot it starts to let go over time, fortunately most the joints get pinched in place. I will try talking to some of the shops.
steve
CARSINC How to remove factory contact cement? Spridgets 9
RAC68 Professional Trim and Upholstary Contact Cement Austin Healey 4
Tinkerman TR2/3/3A Removing old contact cement Triumph 6
Tinkerman How to remove dried on contact cement? Triumph 11
Tinkerman Fun With Contact Cement On My Dash Triumph 2
ekamm contact cement use Triumph 7
ekamm Contact Cement Go Away Triumph 3
CraigLandrum Weldwood contact cement oopsie Triumph 28
AHSebring How do I create "Contact" to "Start Conversation" in my About Tab? FORUM Navigation Questions 1
71TR6 TR2/3/3A Control Head horn contact Triumph 7
B "Healey 5-Speed"/Pete Delaney Contact Austin Healey 27
Popeye Contact adhesive for open cell foam - seat rebuild [TR4A] Restoration & Tools 8
Michael Oritt Brake pedal contact or mercury switch Austin Healey 19
TR4nut TR2/3/3A TR3/4 Water Pumps - Anyone have the ebay rebuilder contact info? Triumph 5
T Wheel rim corrosion at tire bead contact Austin Healey 1
TonyPanchot Art Lipp Contact Triumph 3
T Guys - contact me before bidding on Tr-man items Triumph 13
Newkie running lights contact or lack of? MG 2
mccalebr Trying to contact Jeff Dahn [Bugeye58] Spridgets 4
Gray_Cat Morrisservice Contact Spridgets 4
angelfj1 Personal Contact at Moss Motors Triumph 6
jlaird contact Bud direct via emale Spridgets 5
1965_MGB MGB MK1 MGB Horn Contact Question MG 0
emann BE horn push contact too long? Spridgets 8
Michael Oritt Kendall Jones contact info Racing 3
bcliff Contact info for Gaston [the dash guy] Triumph 16
jaybird MGV8 & MG2006 contact list MG 0
C Hub Rebuilder Contact? Triumph 0
Alfasudcrazy TR6 TR6 contact breaker points - closing Triumph 3
T CONTACT Sunbeam (Rootes) 1
Editor_Reid MGB-GT Want to Contact MGB-GT V8 Owners MG 9
J Contact OL Oxidation Solvent Restoration & Tools 0
KVH Dash Cement Triumph 1
K TR2/3/3A An odd thought.....vinyl wrap a TR3? Triumph 8
BoyRacer Blue Vinyl Dash Material Austin Healey 3
mrv8q TR2/3/3A TR3A TRF vinyl seat reupholstery kit Triumph 7
J Wanted TR6 seat vinyl Triumph Classifieds 1
J For Sale For Sale - 2x TR6 seats in red vinyl - Best Offer! Triumph Classifieds 1
J For Sale Early 70s TR6 seats in new red vinyl, with new tracks, $500 OBO Triumph Classifieds 0
AUSMHLY BJ8 Leather interior - what pieces were leather/vinyl Austin Healey 13
B Victoria British leatherette/vinyl Austin Healey 8
wangdango BJ8 foot well vinyl panels? Austin Healey 7
Hangtown Healey overspray removal on vinyl Austin Healey 5
T Colorado Red Vinyl Interior Austin Healey 6
K TR2/3/3A Gluing vinyl to cockpit capping? Triumph 5
K TR4/4A TR4A vinyl top boot cover factory markings??? Triumph 0
K TR4/4A Black marks on a TR4A/TR6 vinyl top boot cover? Triumph 4
Kleykamp TR2/3/3A Vinyl covering on dash on TR3 Triumph 7
JimTR4 TR4/4A Top dash pad vinyl is "puffy" Triumph 2
TomMull Stickey vinyl steering wheel Restoration & Tools 7
