TR2/3/3A TR3/4 Water Pumps - Anyone have the ebay rebuilder contact info?
TR4nut
I'm still struggling with temp issues in my 3A - especially with current weather in Houston. I am suspicious that I don't have the best water pump in place - right now its one of those multivane new design ones (sorry don't know if its 5 or 6 vane at the moment.
At highway speeds I've noticed that I actually run hotter at higher rpms - the engine will drop in temp if I drop from say 3000-3500 rpm to 2500-3000. Can't think of a reason for that other than potential pump cavitation at the higher revs.
At idling speeds the engine eventually will overheat, especially now in the summer. Reading through past information from other owners I think it may be the rotor design, not having as good of clearances set up with the main pump body.
Bottom line I'd like to try a brass impeller pump - at one time a rebuilder on ebay was offering rebuilt original pumps, zerk fittings and all. A little pricey so I didn't bite - but now I'm interested. Unfortunately I don't see them on ebay any more - anyone happen to know who was rebuilding those pumps and if they still might be available?
Thanks
Randy
mallard
I got one of those pumps off ebay. It was expensive at $169.00. It's on the car but is still untested. It looks completely original as it should. It came from East Coast Jaguar in Wilmington Delaware 302 475 7200 the guys name was John.
TR4nut
TR4nut
Perfect Keith - thanks!
Moseso
I've got one of those pumps on my TR3. It seems to work fine. He uses modern sealed bearings in his build. The zerk is there purely for appearance -- not to be used.
70herald
A water pump either works or it doesn't. Before you go spending money on new pump you probably don't need, I think you should check timing, and if it is running lean. Since this is at highway speeds then engine if fairly loaded, so it could also be something like a partially plugged fuel pump not keeping up with what the engine needs.
I just has a problem with the hose attached to the gas tank, with a small leak. turns out the pump was pulling some air. When I changed it the air fuel mixture suddenly became somewhat richer. (and the trunk no longer stinks)
TR4nut
TR4nut
Actually I've gone through quite a bit already on the car - I don't think it is any one thing that gives the overheating issue, trying to run a 3A in humid 95+F Houston weather is indeed asking a lot. But I respectfully disagree about a water pump either working or not. Pumps have efficiencies, and I know by comparing an original leaky pump with a bronze impellor with an aftermarket pump and cast iron impeller the bronze impeller is larger - I believe it likely has better tolerances to the pump body with the impeller and I would bet (with nothing to back it up) that it had better efficiency than the newer offerings - main thing being better flow at low rpms. Anyway that is what I'd like to test to see if I can improved things.
K For Sale Triumph TR3 Water Pumps for Rebuild Triumph Classifieds 0
K For Sale TR3 Water Pumps for Rebuild Triumph Classifieds 0
K TR2/3/3A TR3 water pumps again...DIY? Triumph 0
K TR2/3/3A TR3 Water pumps again.... Triumph 4
D TR2/3/3A TR3 water pump question Triumph 4
Gordon_Dedrick TR2/3/3A TR3 Water pump replacement Triumph 5
S TR2/3/3A rebuilding a tr3 water pump Triumph 22
S TR2/3/3A Lubing the water pump on a tr3 Triumph 1
T TR2/3/3A TR3 under water again Triumph 4
S TR2/3/3A Bad fuel perhaps water tr3 miss Triumph 0
K TR4/4A TR3/4A Water Pump Housings? Triumph 10
K TR2/3/3A Removing the water pump on a TR3? Triumph 11
luke44 TR2/3/3A TR3 Water Temp Sensor Installation Problem Triumph 37
luke44 TR2/3/3A TR3 Water Pump Pully - Color Triumph 7
T TR2/3/3A thread pitch for TR3 water tap in block Triumph 4
luke44 TR2/3/3A TR3 Water Temp Gauge Core Triumph 14
M TR2/3/3A TR3 water pump housing question. Triumph 4
mountainman TR2/3/3A TR3 Block Water Tap Triumph 11
Tinkerman TR2/3/3A TR3 A Water Pump Housing Pipe Triumph 7
RedTR3 TR2/3/3A TR3 Uprated Water Pump? Triumph 11
Tinkerman TR2/3/3A TR3 Pipe, Water Pump Housing, Mounts Where? Triumph 15
newmexTR3 TR2/3/3A TR3 water pump / thermostat replacement Triumph 1
E TR2/3/3A tr3 water pump pulley Triumph 6
M TR2/3/3A TR3 water valve Triumph 4
Tinkerman TR2/3/3A Water pump studs TR3 need the size Triumph 3
M TR2/3/3A TR3 Water Pump Rebuild Triumph 6
H TR2/3/3A TR3 Water Pump Triumph 4
Tinkerman TR2/3/3A Water Pump post 60000 TR3 Triumph 4
Tinkerman TR2/3/3A TR3 post 60000, water pump Triumph 10
Tinkerman TR2/3/3A Water pump TR3 post 60000 Triumph 2
White79MGB TR2/3/3A New TR3 Owner, Water Pump Triumph 17
MGTF1250Dave TR2/3/3A TR3 Water Pump Triumph 7
mrv8q TR2/3/3A TR3 Water pump/Engine mount advice Triumph 2
jsneddon TR2/3/3A TR3 Water Pump Question Triumph 12
R TR2/3/3A TR3 Timminge Triumph 11
J For Sale Triumph TR2 TR3 rocker panels, right and left Triumph Classifieds 0
J SOLD!! Triumph TR2 TR3 Channel - Drip - Rear Edge Triumph Classifieds 1
J For Sale TR2 TR3 Tie Member Triumph Classifieds 0
S TR2/3/3A tr3 valve spring compressor Triumph 5
