running lights contact or lack of?
Newkie
Just wondering if there is a trick to creating a good contact from the bulbs to the socket for both front and rear running lights. They are very sensitive to movement because of how loose the bulbs sit in the sockets.
Thanks
Hopefully with this difficult description I was trying to explain, you understood what I was asking?
Art (73' MGB)
bgbassplyr
Shim the socket spring to put more pressure on the contact area.
Polish the contacts on both the socket and the bulb.
Deleted member 8987
If that is a roblem, I use my soldering iron and put a bigger glob of solder on the back contact(s), file round, cleand everyting, and it generally works.
On older cars, I often find that to fix even an older bulb, but it seems the vibrations and road "bumps" often wiggle the bulbs around and wear down those contacts.
I have one Lucas socket that the long, skinny contact area in the socket has shrunk a bit into the phenolic.
The solder blob fixed that, too.
C Key off, lights on engine still running??? Triumph 4
M No running lights MG 2
K 1991 XJS Day time running lights Jaguar 0
K Daytime Running Lights Jaguar 1
K TR2/3/3A What are the running symptoms........ Triumph 21
T General Tech Running hot Triumph 8
J TR4/4A 1964 Triumph TR4 - Not Starting/Running Triumph 3
shadowfever Running well, then no fire Spridgets 7
C Rough-Running 3000 Austin Healey 29
S MGB Running poorly MG 7
tr6web TR6 TR6 rough running - what can it be? Triumph 17
Hamish Racing TR2/3/3A Winter engine running in - icy Triumph 7
R running car on jack stands Spridgets 16
BierRunner TR6 TR6 Running Rough Triumph 5
tr6web TR6 Quit running after a few minutes - need advice Triumph 15
B For Sale 57TR3 Small Mouth with OD Project. 12 yeqrs running. I'm not going to finish Triumph Classifieds 14
sparkydave Trouble running hot Spridgets 10
T TR2/3/3A rough running after 20 min shutdown Triumph 9
S TR2/3/3A Running rich SUs. Triumph 25
Y Wanted Looking for running 3.5L MK V engine Jaguar Classifieds 0
J Spitfire 1979 Spitfire Running rough [sputtering, exhaust poping] at start up Triumph 2
Gliderman8 Starter keeps running TVR 20
Rut MGB Running out of gas symptoms MG 21
K TR2/3/3A Anyone running NGK spark plugs? Triumph 26
T TR2/3/3A Anyone running tubeless radials on TR3 steel radials? Triumph 2
N Running Cold Austin Healey 12
bugedd Car running poorly Spridgets 7
Bob_Spidell Running hot/Overheating Austin Healey 44
Martinld123 SU carbs lose fuel prime when not running Austin Healey 3
mailbox For Sale 76 TR 7 project car [non running] Triumph Classifieds 0
N Stuck Needle Valve - Rough Running Austin Healey 15
J For Sale 1976 Sptifire with 1.8L Miata engine/5-speed [running like a boss!] Triumph Classifieds 0
BN6 Breaking In Running In a newly built Healey Engine Austin Healey 15
R TR2/3/3A TR 3A running hot at high rpm Triumph 12
M Proper running temp for 1275 Spridgets 28
HighAltitudeTR3 TR2/3/3A Running a little hot... Triumph 14
D Lilly running #3 / since last we talked.... Austin Healey 7
D Lilly second time running... or trying Austin Healey 8
D Lilly first time running in 15 years.... Austin Healey 19
sd80mac7204 TR6 Interesting TR6 running issue Triumph 19
glemon TR5/TR250 Stumped TR250 Running Rough--Follow Up Triumph 3
glemon TR5/TR250 Stumped TR250 Running Rough Triumph 8
F TR2/3/3A SUs Running Rich Triumph 25
S TR2/3/3A Struggling to stay running during warmup? Triumph 0
vette Constant Engine Running RPM. Austin Healey 20
S TR2/3/3A Oil Leak Dripping from Front and Rear of Left Side Oil Pan---Only While Running Triumph 14
C T-Series MGTC Running Boards MG 1
gbtr6 TR6 TR6 no start after running amazingly well til now. Triumph 16
K TR4/4A Running the motor witout the gearbox installed? Triumph 3
D Rough running BT7 3 carb HELP Austin Healey 13
