TR6 TR6 contact breaker points - closing
Alfasudcrazy
Member
My TR6 is going like a gem of late except for one anoying thing. The contact breaker points close after doing about 15 miles. Adjust them again and it s fine until I have done another 15 miles?
I think I tighten them up as tight as its safe to do - what could be causing it. I have replaced the points a few times but that does not seem to cure it - can anyone help? /ubbthreads/images/graemlins/cryin.gif
Geo Hahn
Are you using any lubrication on the distributor cam? The cheap (usually red) plastic bit that rides on the cam can wear if the cam is hot and dry. I use a bit of assembly lube there though there is a purpose made product just for that spot (they used to give you a little capsule of it in each box of points... but then they used to give you toy cars in your box of cereal too).
Also, you might simply not be getting the points tightened down enough though really it doesn't take a lot to hold them in place.
trrdster2000
Alfasudcrazy, I have seen this twice and both times it was not the points closing but the plastic bit that rides on the cam in the distributor melting and the problem was a hot coil for an American car from AutoZone or such. If you still have a set of points you took out, have a look and see if the litle bit is shorter than a new set. The Lucas Sport Coil will fix that. Wayne
SkinnedKnuckles
Sounds like you may be a candidate for a breakerless ignition system...
Hawk813 TR6 TR6 Brakes Triumph 2
M For Sale 1971 Triumph Tr6 Triumph Classifieds 0
J For Sale Set of Dayton 72 spoke chrome wire wheels for TR6 / TR250 Triumph Classifieds 1
M TR6 TR6- Weber 3236 downdraft conversion Triumph 5
BierRunner TR6 TR6 Trunk Lock Striker Triumph 3
P TR6 Horn issue 1974 TR6 Triumph 5
Charlypm For Sale 69 Triumph TR6 Racecar Triumph Classifieds 1
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 5
R TR6 TR6 Triumph 6
tr6nitjulius General TR TRIUMPH TR6 the possibilities! Triumph 12
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
A For Sale 1974 TR6 Triumph Classifieds 1
EWD For Sale ‘74 TR6 original wheel trim rings Triumph Classifieds 3
EWD For Sale ‘74 TR6 original radio Triumph Classifieds 0
EWD For Sale ‘74 TR6 original starter Triumph Classifieds 0
EWD For Sale ‘74 TR6 original steering wheel Triumph Classifieds 0
JPSmit TR6 at lunch today Spotted 0
E Wanted looking for a tr6 bell housing Triumph Classifieds 12
jfarris For Sale TR6 Yellow Fan - new Triumph Classifieds 0
