Coach Key (T-Key / Chruch Key / Fool's Key) Revival
JHaydon
Sorting through the accessories provided with the TR3A now residing in my garage, I found two "Coach Keys" AKA "T-Keys". Based on earlier threads, one may be the prized original and the other is the dreaded later "dogbone handle" type. I'm happy to keep using the dogbone version and stash the straight one (even though the concours field is beyond my reach).
However... The tip of the business end is a bit worn, particularly on the dogbone version. TRF says about their replacement key:
"this will be a full-size key... end will have to be filed or ground to fit square holes in Dzus fasteners"
Would it be ridiculous to try to revive this non-sacred tool by filing it (carefully, to preserve the taper and square profile)? Has anyone bothered to try it?
I'm not just trying to save $13. I shed tears whenever a tool goes in the trash. If it costs me $130 in labor to make it like new, I'd consider it time well spent.
TomMull TR2/3/3A Wee coach key Triumph 2
CJD TR2/3/3A Original Style Coach Key? Triumph 24
J Ignition Key Malfunction Austin Healey 6
PAUL161 T-Series MGTF Ignition Key MG 7
KVH General Tech Oil Pump Woodruff Key Triumph 10
D Key Blanks Austin Healey 6
M TR6 Key Codes Triumph 7
A Where to get key blanks for SD1 in the U.S.? Rover / Land Rover 5
L BUG EYE WHAT CAUSES A VOLTAGE REGULATOR TO STICK ON WHEN U TURN KEY OFF Spridgets 3
J Ignition Key Cylinder Removal Austin Healey 3
G Inertia Cut-Off Switch - E-Fuel Pump to Ignition [Key] Switch Austin Healey 3
D Source for XJ6c Series ll Ignition key blanks & remote Jaguar 1
K Left my key on for 5 hours and wont start, UGG!!!!!! Austin Healey 48
S TR2/3/3A try start it with the key and it blows the fuse Triumph 7
6 1965 Sprite Ignition Key Spridgets 3
R Woodruff key for DWR camshaft? Austin Healey 2
G General Tech Have new blank key for TR3 but cannot get it "cut" to fit ignition. Triumph 14
K Correct key head shape. Austin Healey 1
J MGB 1977 MGB starter activates when key on the "on" position. MG 6
S TR4/4A key cylinders Triumph 6
S TR4/4A Ignition switch key position Triumph 2
G Generator - Key Replacement Austin Healey 6
S Open a ingnition key barrel to find the key number. Restoration & Tools 2
S key ID from a barrel? Other British Cars 5
Rut RX7 key fob Spridgets 6
Scotsman TR4/4A Commission Plate interpretation "key" Triumph 3
Got_All_4 TR2/3/3A Ingnition switch key change Triumph 7
5 ignition-trunklatch key Austin Healey 3
W TR6 TR6 Horn only works when key is off Triumph 27
M TR4/4A Trunk/Boot lock key code?? Triumph 4
F Sunbeam/Hillman Key Blank Sunbeam (Rootes) 4
H Spitfire Triumph starts just fine but Ignition is 'Off' and key is in my wife's purse. Triumph 6
S TR2/3/3A small woodruff key Triumph 5
W Bugeye ignition key repalcement Spridgets 2
S TR2/3/3A timing chain cover and woodruff key Triumph 4
D Start Bugeye with KEY only - OR - KEY plus light switch on S or H? Spridgets 4
pkmh BJ8 - Removal of existing Key Washer behind castellated nut Austin Healey 20
J TR2/3/3A Ignition key issue Triumph 4
JPSmit Wiring Key - hand to have Restoration & Tools 1
J Where To Find BJ8 Key Door Lock ,Trunk & Glove Box Numbers ??? Austin Healey 3
PatGalvin TR5/TR250 TR250 Ignition Key Question Triumph 4
S TR6 TR6 project back together- turn the key and CLICK Triumph 7
M 99 XJ8 How Do You Troubleshoot Key Transponder Module? Jaguar 0
M X-308 99 XJ8 Engine ECU and Chip in Key Jaguar 2
K TR2/3/3A TR3 Dzus Key Fob? Triumph 4
M T16 engine, ecu and two key fobs, or Rover 820 Rover / Land Rover 0
TonyPanchot Spitfire 72 Spit 1500 Key Light Triumph 2
K TR2/3/3A TR3..testing wiring..leaving key on..Petronix? Triumph 3
V Door lock key cylinder Triumph 9
G MGB MGB "Spare" key MG 7
