RX7 key fob
Rut
I ran across an old key fob from my RX7 days and wanted to offer it to someone with rotary love. For postage...
Rut
Whitephrog
My father in law was a big Wankel engine fan. He bought the first RX3 sold in East Tennessee. I always thought that the NSU RO80 was the best looking of all the rotary powered production cars. I got passed on the Autobahn one day by a Wankel powered Mercedes C111. I was going 90 kph. The C111 passed me like I was standing still.
Rut
Rut
Ray,
The C111 was an absolute marvel of engineering and beauty in my eyes...I always lusted after them!
Rut
BillD
Member
My 91 'vert would be proud to rock that fob. :encouragement:
Rut
Rut
bugedd Limited Slip advice, scrapping idea of RX7 rear end Spridgets 34
bugedd RX7 rear axle and brake question Spridgets 2
T Any pictures of Rx7 E-brake cables? Spridgets 6
N RX7 rear axle ??? Spridgets 13
B RX7 Rear End in a Midget Racing 3
J Ignition Key Malfunction Austin Healey 6
PAUL161 T-Series MGTF Ignition Key MG 7
J Coach Key (T-Key / Chruch Key / Fool's Key) Revival Restoration & Tools 0
KVH General Tech Oil Pump Woodruff Key Triumph 10
D Key Blanks Austin Healey 6
M TR6 Key Codes Triumph 7
A Where to get key blanks for SD1 in the U.S.? Rover / Land Rover 5
L BUG EYE WHAT CAUSES A VOLTAGE REGULATOR TO STICK ON WHEN U TURN KEY OFF Spridgets 3
J Ignition Key Cylinder Removal Austin Healey 3
G Inertia Cut-Off Switch - E-Fuel Pump to Ignition [Key] Switch Austin Healey 3
D Source for XJ6c Series ll Ignition key blanks & remote Jaguar 1
K Left my key on for 5 hours and wont start, UGG!!!!!! Austin Healey 48
S TR2/3/3A try start it with the key and it blows the fuse Triumph 7
6 1965 Sprite Ignition Key Spridgets 3
R Woodruff key for DWR camshaft? Austin Healey 2
G General Tech Have new blank key for TR3 but cannot get it "cut" to fit ignition. Triumph 14
K Correct key head shape. Austin Healey 1
J MGB 1977 MGB starter activates when key on the "on" position. MG 6
S TR4/4A key cylinders Triumph 6
S TR4/4A Ignition switch key position Triumph 2
TomMull TR2/3/3A Wee coach key Triumph 2
CJD TR2/3/3A Original Style Coach Key? Triumph 24
G Generator - Key Replacement Austin Healey 6
S Open a ingnition key barrel to find the key number. Restoration & Tools 2
S key ID from a barrel? Other British Cars 5
Scotsman TR4/4A Commission Plate interpretation "key" Triumph 3
Got_All_4 TR2/3/3A Ingnition switch key change Triumph 7
5 ignition-trunklatch key Austin Healey 3
W TR6 TR6 Horn only works when key is off Triumph 27
M TR4/4A Trunk/Boot lock key code?? Triumph 4
F Sunbeam/Hillman Key Blank Sunbeam (Rootes) 4
H Spitfire Triumph starts just fine but Ignition is 'Off' and key is in my wife's purse. Triumph 6
S TR2/3/3A small woodruff key Triumph 5
W Bugeye ignition key repalcement Spridgets 2
S TR2/3/3A timing chain cover and woodruff key Triumph 4
D Start Bugeye with KEY only - OR - KEY plus light switch on S or H? Spridgets 4
pkmh BJ8 - Removal of existing Key Washer behind castellated nut Austin Healey 20
J TR2/3/3A Ignition key issue Triumph 4
JPSmit Wiring Key - hand to have Restoration & Tools 1
J Where To Find BJ8 Key Door Lock ,Trunk & Glove Box Numbers ??? Austin Healey 3
PatGalvin TR5/TR250 TR250 Ignition Key Question Triumph 4
S TR6 TR6 project back together- turn the key and CLICK Triumph 7
M 99 XJ8 How Do You Troubleshoot Key Transponder Module? Jaguar 0
M X-308 99 XJ8 Engine ECU and Chip in Key Jaguar 2
K TR2/3/3A TR3 Dzus Key Fob? Triumph 4
