X-308 99 XJ8 Engine ECU and Chip in Key
Michael J.
Has anyone found a procedure to program the engine computer to work with the chip imbedded in the key?
I keep getting codes indicating that one of the circuits in the ECM (Engine Control Module) is bad. I purchased a used ECM from a jag salvage yard, but car turns over but will not start. I have been told that the key has a chip in it and the ECM must be programmed to communicate with the chip.
Jag dealer says to bring in the car, well that is an hour tow truck ride. Take the replacement ECM out and install the original and car will start, but only run as restricted performance.
I have not talked to dealer about bring the replacement ECM and the key yet. Wondering if the only option is to bring the car to the dealer.
Does anyone repair these ECM's?
There used to be a shop in Houston that I had one repaired for an XJS, but have no information on if they are still in business or how to contact them.
StagByTriumph
If I recall correctly it is a dealer specific action where you need the computer PDU that is available only to dealers and authorized service centers. The factory PDU is quite expensive, in the tens of thousands. You should be able to have it performed at any Jaguar Land Rover or even some Ford - Lincoln Mercury dealers were equipped to deal with Jaguars if there was no local JLR service center.
Go have a chat with the service manager and you might get some help - maybe ...
M
Michael J.
Re: X-308 99 XJ8 Engine ECU and Chip in Key and Adjusting Variable Valve Timing
I finally gave up, loaded the car on a tilt bed and hauled it to the dealer one hour away. The rough running and overheating issue is allegedly tied to the variable valve timing according to the dealer technician. He thought that the vendor that overhauled the engine that I bought did not properly adjust the adjustable timing piston. They could not (would not) keep the car to make the adjustment. Instead, they wanted me to load it on a tilt bed, haul it home an hour away and then bring it back a week later as if it is not big deal getting time off from work and paying the $200+ towing each way to/from home an hour away. I bought the wrench for the variable timing piston from XKs Unlimited. When you buy the cam alignment tools, most kits have the bar to secure the cam flats and the pin for the transmission flex plate, but not the wrench for the variable cam timing. Supercharged engines do not have this pain in the backside feature. So if you need to do cam chain work on normally aspirated 4.0 engines, buy the additional wrench. Standing at the front of the car, Facing the windshield, Do you bottom the variable piston by turning CW or CCW or is the piston supposed to be somewhere in between? Anyone out there know the procedure?
Kirk_Fisher Not exactly a Ferrari 308 TVR 4
jdubois My 308 restoration is nearing end of the tunnel! Other Cars 23
C Trade a 66-69 E roadster for my 84 Ferrari 308 QV? Jaguar 0
P Jag XJ8 starts but then dies right away. Jaguar 4
G FOR SALE - 2002 XJ8 Vanden Plas Jaguar Classifieds 0
M 2004-2008 XJ8 Air Suspension Reliability and Problems Jaguar 0
M Replacement Sub-Woofer for X308 99 XJ8 with Premium Sound System Jaguar 1
M How Do I check Fuel Pressure at Injector Rail 99 XJ8? Jaguar 5
M 99 XJ8 How Do You Troubleshoot Key Transponder Module? Jaguar 0
M Looking for a Vendor to Repair 98 - 2002 XJ8 ECM Jaguar 2
M 4.0 V-8 for XJ8, XK8 and S-Type Differences? Jaguar 1
M Rough Running 99 XJ8 after Overheating Jaguar 42
M 99 XJ8 Thermostat Housing Failure Jaguar 0
M Self Dimming Mirror on 99 XJ8 Jaguar 1
M Sub-woofer Speaker for 99 XJ8 with Premium Sound Jaguar 1
M Intermittent Hard Starting on 99 XJ8 Trouble Code Jaguar 13
M How to Determine Trim Codes for 99 XJ8 Jaguar 3
M IPod Connectivity Kit for 2007 XJ8 Jaguar 1
D XJ8 rides rough Jaguar 5
F XJ8 Dosen't Start Jaguar 5
F XJ8 Dosen't Start FORUM Navigation Questions 2
John_Worthington Stuck valve? 98 XJ8 Jaguar 2
John_Worthington Updating timing chains and tensioners 98 XJ8 4.0L Jaguar 9
1 It's not a classic, but XJ8 or SType4.2 Jaguar 17
E XJR XJ8 Difference? Jaguar 0
1 XJ8 or XJR? Jaguar 2
1 What's the consensus of the XJ8 up to year 2003 Jaguar 4
S Trans fluid question for 98 xj8 Jaguar 16
T XJ8 Jaguar 2
F XJ8 Tail Lights do not work Jaguar 0
S 2000 XJ8 Starting Problems Jaguar 4
J 2003 XJ8 MYSTERY WATER LEAK Jaguar 2
R 98 XJ8 overheats Jaguar 4
J 2003 XJ8 Soverein seeking input Jaguar 5
B 1998 XJ8 Wiper over-run Jaguar 0
L General Tech Engine id Triumph 8
mctriumph For Sale Tr7 engine Triumph Classifieds 2
mctriumph TR2/3/3A Weirdest engine failure Triumph 2
sim A-series Engine Block Search Spridgets 2
H "Failure to Proceed" (Engine Won't Fire) Austin Healey 9
L Engine ID British Motor Corp 4
J Can a TF engine be installed in a TD body? MG 7
K TR2/3/3A Coil against hot engine?.....relocating the coil? Triumph 11
C Engine Operating Temperature Austin Healey 21
CARSINC WANTED: 1275 Engine Spridgets 0
tinman58 TR2/3/3A Por-15 in engine block? Triumph 12
W BN4 Engine Mounts Austin Healey 2
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
