First time poster so I'd like to start with a Hello to everyone!
I just purchased a 98 XJ8 Vandenplas with 62,000 miles and am having overheating issues. When I picked it up it had a coolant leak at the base of the thermostat housing. A new O Ring solved that problem and all was fine for about 3,000 miles. Then the top radiator hose bew off after about 6 hours of steady driving. I checked the thermostat which was working properly, flushed the cooling system and replaced the spring loaded clamps with regular screw type clamps. It ran fine for another 200 miles or so then started to get seriously overheated and began blowing coolant out the overflow bottle at the left front fender! Now I can let it sit and idle for for extended periods of time and it will go through the proper cooling fan on and off cycle several times with no problem. I I even raised the idle to 1500 rpm and let it run through the cooling cycle a few times with no problem. As soon as I begin to drive the temp rises quickly and it overheats blowing coolant again!
The only thing I can figure is that I must have a blown headgasket?? I don't claim to be a Jag expert so I'm wondering if I am missing something else here???
Thanks for the help!
