Spitfire 72 Spit 1500 Key Light
TonyPanchot
Looking for information on the correct location for the lamp that illuminates when the door is opened, got it sorted and setting atop the key but would like to see it home, thanks for the assistance all
dklawson
From memory I thought it was just a small lamp bracket that attaches to the bottom of the dash rail. I will try and remember to look tonight.
zedvictor1 Spitfire different diff for Spit 1500 with overdrive? Triumph 1
T Spitfire Grease slinger position on a Spit 1500 axle Triumph 7
H Post-War Other Spit 1500 Engine in a Herald 1200 Triumph 1
O Spitfire Spit 1500 Thrust Washers? Triumph 13
B Spitfire Aftermarket synchros 1500 Spit single rail Triumph 2
B Spitfire 1500 SPIT OD ELECTRICAL Triumph 1
Rhodyspit75 Spitfire Midget carbs and manifold on 1500 Spit Triumph 6
G Spitfire Anyone have a single DCOE mainfold for a 1500 Spit Triumph 0
pipercollins Spitfire Spit 1500 Clutch Issues Triumph 24
C Spitfire Spit 1500 bumpers Triumph 4
G Spitfire Best Euro 1500 Spit head? Triumph 0
G Spitfire 1500 Spit ring gap spec needed please Triumph 1
J Spitfire Spit 1500 Bellhousing Problem Triumph 0
L Spitfire temp sender for spit 1500 Triumph 7
pjsmetana Spitfire Compression Test - Spit 1500 Triumph 34
B Spitfire 76 Spit 1500 almost there Triumph 16
JodyFKerr Spitfire Spit 1500 Distributor Triumph 2
c5racer Spitfire 1500 Spit exhaust manifold fit a 1500 midget? Triumph 2
T Spitfire 1500 spit frame Triumph 1
N Spitfire How to remove fan clutch on 1500 Spit Triumph 6
D Spitfire Top replacement recommendations for a Spit 1500??? Triumph 9
D Spitfire Need help making my Spit 1500 a little more fun... Triumph 24
L Spitfire Help me make a carb choice [Spit 1500] Triumph 18
L Spitfire Ignition Timing for my Spit 1500... Triumph 12
E Spitfire 74 Spit Rebuild Triumph 4
boeingpilot For Sale Parting out '75 and '76 Spit 1500s Triumph Classifieds 0
C Spitfire Mystery wires - Spit, left near distributor Triumph 2
lilifer_13 Spitfire New alternator doesn't fit - '78 Spit Triumph 2
M Spitfire Triumph spit flange/hub removal Triumph 13
D Spitfire 1980 spit.. 34000 miles unbelievable Triumph 5
dklawson Spitfire Bleeding Herald Brakes [similar to Spit] Triumph 9
G For Sale Round-tail Spit-6 Project car with OD for Sale [Cambria CA] Triumph Classifieds 0
tomshobby Spitfire head size of damper pulley bolt on 78 Spit? Triumph 2
D Spitfire 1975 Spit resurrection Triumph 4
trrdster2000 GT6 Finally got a photo of some of our work on the Spit 6 Triumph 2
mgedit TR2/3/3A Coolant spit out of overflow Triumph 20
B Spitfire Parting out 67 Spit Mk3 Triumph 1
D Spitfire MkI Spit questions Triumph 9
AEW Spitfire vintage racer replica on Spit running gear. Triumph 4
T Spitfire Free early Spit in Boise Triumph 1
glemon Spitfire Craigslist Spit Triumph 2
G Spitfire Anyone ever see a Spit look like this one? Triumph 5
tr6nitjulius Stag TR3*4*6*7*8*Spit*GT6*Stag=20 [pics] Triumph 0
D Spitfire '65 Spit window regulator installation tips needed Triumph 0
This14u Spitfire Pic of Spit A-Pillar Details Triumph 3
D Spitfire MKII cam in a MKII '65 Spit - pros and cons Triumph 2
D '65 Spit heater control valve Restoration & Tools 1
TonyPanchot Spitfire Spit Windscreen trim Triumph 3
6 Spitfire Tire bumps wheel well on spit mk3 Triumph 5
K Spitfire Door striker 63 Spit Triumph 1
