Spitfire Tire bumps wheel well on spit mk3
68umph
I just bought a 1968 spitfire & the previous owner replaced shocks and springs. When I hit big bumps the tire rubs the wheel well. Car has wire knock offs so I don't think it's due to over sized tires. I'm thinking about adding a spacer on the shock to shorten the travel. Has anyone else experienced this issue? Thanks!
The outer edge of the tire hits the top center edge of front wheel well. Only when I hit a bump that compltely compresses the shock
Are these factory wire wheels or something aftermarket? Also you say the PO changed the springs, could be he dropped the front lower.
YI'm not sure if they are afterml carket. I think I will need to consult with some local club guys so they can see what's going on.
If it touches over a bump I would expect there would be a visible problem with ride height, i.e. low at the front.
Springs hold the car up, not shocks- see if you can see if the coils have been cut, or remove a spring and check the free height against the specification.
Using spacers is a makeshift solution.
S TR2/3/3A Tire balance Triumph 15
J MGB Tire pressure for 1980 MGB MG 14
T Tire Age Austin Healey 14
R 2500M Inner Fenders - are they the same as a Vixen 2500? (Also Tire Size) TVR 3
Frameman 1949 Tire Options Austin Healey 16
T TR6 TR6 Tire Pressures Triumph 2
NutmegCT Tire pump in reverse? Restoration & Tools 5
prb51 BN6 Wheel/Tire Combo Austin Healey 26
JohnGone Wanted Q: Small Boot, Small Spare Tire? And, Jack needed. MG Classifieds 2
F TR4/4A Tire saver ramp recommendations Triumph 10
D Wanted Austin healey Tire - used Austin Healey Classifieds 4
Bocaray TR2/3/3A Centred Tire Triumph 3
H Wanted Need Spare tire rod BJ8 Austin Healey Classifieds 1
S For Sale Tire for Sale (155SR15) Triumph Classifieds 3
F TR2/3/3A Spare tire cover Triumph 8
S TR2/3/3A spare tire compartment holes for modern license Triumph 8
Mark Bailey Old tire rule? Restoration & Tools 5
Healey Nut Tire Sizes Austin Healey 10
F TR2/3/3A Spare tire cover Triumph 3
P Wanted E type spare tire bracket Jaguar Classifieds 2
P Wanted 62 E Type spare tire bracket Other British Classifieds 1
K TR2/3/3A Tire pressure and ride comfort? Triumph 9
P TR6 What make and size tire was on the TR6 when it left the factory? Triumph 7
G Rear tire scrubbing!!? Spridgets 23
H Can a 175x13 tire be fitted on Bugeye Spridgets 6
M TR5/TR250 Compatible Modern Tire Size Triumph 5
L TR2/3/3A tire manufacturing build date Triumph 2
K TR2/3/3A Optimum Tire pressure for a TR3 daily driver? Triumph 5
J TR6 Tire Recommended for TR6 Triumph 3
S TR2/3/3A tr3 spare tire fit Triumph 16
K TR2/3/3A TR3B Tire/Wheel Advice Triumph 2
L General TR tire age code Triumph 3
H TR2/3/3A Original Dunlop 5.50X15 Bias Ply Tire Data Triumph 4
AUSMHLY Wheel Tire Camber Austin Healey 57
madhouse Tire pressure monitoring system [TPMS] for Healey? Austin Healey 0
tahoe healey Tire pressure again Austin Healey 59
Raymond MGB Wire Wheel Tire Mounting MG 0
T General TR Wire wheels - tire mounting/balancing - Southern California Triumph 14
O TR2/3/3A Spare tire Triumph 4
M Brake fluid on tire - cylinder need replaced? Spridgets 19
F TR2/3/3A Spare Tire Size Triumph 11
H Tire choices for Bugeyes Spridgets 14
D Vredstein 185X70 Spare Tire Fitment Austin Healey 5
K TR2/3/3A Volvo low profile space saver spare tire for TR3 ? Triumph 1
Darwin Spitfire Max tire width Triumph 4
vette Tire Size and Improving Rear Brake Drums Austin Healey 17
NutmegCT T-Series tire pressure? MG 8
HealeyRick Time to Re-tire Spridgets 2
