TR6 TR6 Tire Pressures
T
TR6Dan
Member
I replaced the factory wheels on my '74 TR6 with Konig 16x7 wheels and Yokohama Avid Ascend 205/65 R16 95H SL BSW tires. What tire pressure would you recommend? I am thinking somewhere in mid 30?
Thanks,
Dan
poolboy
You might feel the ride is a little harsh on a bumpy road, but you may actually like a little oversteer if your tires are pumped up to the mid 30's..
28 to 30 in the front; ... 31 or 32 in the rear..try that.
P TR6 What make and size tire was on the TR6 when it left the factory? Triumph 7
J TR6 Tire Recommended for TR6 Triumph 3
Scot1966 TR6 Screws in TR6 spare tire well Triumph 12
sundown TR6 TR6 tire pressure Triumph 4
I TR6 69 TR6 spare tire lid Triumph 4
bcbennett TR6 TR6 Tire Clearance Triumph 3
B TR6 TR6 Tire Advice Triumph 6
B TR6 Putting a 205 75 tire on a tr6 Triumph 4
bcbennett TR6 TR6 Spare Tire Triumph 27
R TR6 TR6 Spare Tire Cover Needed Triumph 9
MTribe TR6 TR6 tire size photos? Triumph 30
bigbadbluetr6 TR6 TR6 Spare Tire Triumph 1
N TR6 Opinions on 205-70R15 tire size for TR6 Triumph 11
I TR6 TR6 - uneven tire wear in rear tires Triumph 1
YYCDave TR6 TR6 Rear Shock Conversion & Tire Size Triumph 2
F TR6 TR6 Tire Recommendatios Triumph 12
AngliaGT TR6 TR6 Tire Replacement Triumph 6
B TR6 Yes.....another TR6 tire size question Triumph 7
R6MGS TR6 Another TR6 Tire Thread Triumph 21
B TR6 Question about tire size options on a TR6 Triumph 3
SpannerMan TR6 TR6 jack minimum height for changing a tire? Triumph 5
Brosky TR6 Looking for tire advice for TR6 Triumph 17
T TR6 TR6 Tire Sizes - Modern Equivalent to 185 SR 15? Triumph 13
T TR6 Tire Preservation Question - 1976 TR6 Triumph 13
Z TR6 TR6 Tire Recommendation? Triumph 5
SCguy TR6 Tire suggestions for a TR6/Panasports Triumph 4
B TR6 My TR6 rear tire tilt inwards at top Triumph 9
Cain TR6 TR6 Tire Size Triumph 10
J For Sale Set of Dayton 72 spoke chrome wire wheels for TR6 / TR250 Triumph Classifieds 1
M TR6 TR6- Weber 3236 downdraft conversion Triumph 5
BierRunner TR6 TR6 Trunk Lock Striker Triumph 3
P TR6 Horn issue 1974 TR6 Triumph 5
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
