Spitfire temp sender for spit 1500
ljlong
Hi all,trying to fit an aftermarket watertemp sending unit into my'78 Spitfire. The sender is 1/8 NPT, I tried a 3/8 NPT to 1/8NPT reducer but that didn't fit into the waterpump housing. Can anyone tell me the actual size of the holes in the housing. Thanks in advance. "LJ" Long
I thought the sender was at the top of the radiator...
Either way, I wouldn't even bother with it, and would just get the pointy brass through-radiator type that comes with a new electric fan and reroute the wires.
Are you trying to utilize the location in the image above? I'm not sure exactly what the stock thread/hole size is, but it's not NPT and it's very close to 7/16". The original sensor used a washer to seal it. I installed Sun mechanical gauges in my MkI. I used a 1/4 18 NPT tap on the hole without any drilling. It seems to work fine. The brass is what came with the gauge. I hope that helps.
Well, got it sorted out. The sender is the one that come's with my temp gauge. It's an AutoMeter # ATM-5737. Of course I wouldn't want to replace it with one of those "pointy brass" units as those are primarily just a thermostatic switch for turning a fan on/off. Secondly I was wrong about the size of my sender unit. It's not 3/8 NPT as I stated but 3/8" 27 TPI The opening in the water pump housing is indeed 5/8" as Ross indicated. The obvious thing to do would be to find an appropriate adapter. This has proved to be difficult. The solution it seems is to drill and tap my alloy thermostat cover for the 3/8" sender. I find that this seems to be a common problem when using aftermarket products and hopefully someone can use the info. Thanks to all for their input.
I'm not sure that will work, unless you find a thermostat that will clear the sender. This was a situation with Heralds, but those cars used a 'flat-top' thermostat similar to
those found in the TR2/3/4.
:yesnod: <span style="font-size: 12pt"><span style="font-weight: bold">YEP</span> this is the part that worked for me on my 1500 spit...</span>
vette Threads for the Water Temp Sender Austin Healey 6
Stewart MGB Temp sender issues MG 4
Mink TR4/4A Temp gauge/sender question Triumph 15
bigjones Testing Temp Sender Spridgets 5
pipercollins Running Temp, Guage, Sender Questions Triumph 11
Rob_P Temp Sender MG 3
Bob Claffie Temp sender thread Austin Healey 18
I temp gauge or sender? Triumph 3
JPSmit next dismantle question - water temp sender Spridgets 10
RJS TR4/4A Smiths Oil Temp Gauge Triumph 11
G Smith's temp gauge repair Restoration & Tools 4
MikeAH100M High Temp Engine Miss Austin Healey 2
RJS TR4/4A TR4A Temp Gauge Scale Triumph 6
Martinld123 Problems with my BN2 Temp Gauge reading Austin Healey 13
shadowfever Water temp Spridgets 9
Govtslug TR6 Coolant Temp Q Triumph 4
EWD TR6 Temp Gauge - 74 TR6 Triumph 11
Editor_Reid Water Temp Gauge Austin Healey 5
H TR4/4A 67 tr4a runs rough and losses power when hot but not over normal temp Triumph 14
J TR6 73 TR6 Temp Gauge Wiring Question Triumph 6
Rut Bugeye 1275 temp probe placement. Spridgets 8
B For Sale Triumph Tr3 Fuel gauge Temp gauge Oil pressure gauge, speedometer tachometer Triumph Classifieds 0
S TR2/3/3A temp gauge sealer Triumph 7
W Electrics, fuel system, under bonnet temp. Austin Healey 3
S TR2/3/3A removing the temp gauge needle Triumph 5
T TR2/3/3A Where is best spot to check temp with infrared thermometer? Triumph 17
DugMoney Need Advice - Moving Temp Gauge Sensor 1275 Spridgets 3
M Proper running temp for 1275 Spridgets 28
JFS TR2/3/3A Radiator fan temp probe Triumph 3
D TR2/3/3A tr3 temp guage capillary tube thread size Triumph 3
JFS TR2/3/3A Temp Sensor Removal Triumph 6
S TR4/4A Temp guage problem Triumph 5
R Capillary tube temp gauge Austin Healey 7
R TR2/3/3A TR3A tired temp gauge Triumph 5
RickPA Water temp gauge reads low Austin Healey 6
F TR2/3/3A Water Temp Triumph 10
R water temp bulb loose Austin Healey 27
C Wanted Sunbeam Alpine 1, II Water Temp Electrical sending unit.[Or one that will work] Other British Classifieds 1
Superwrench Oil Pressure/ Water temp Gauge Austin Healey 17
K TR2/3/3A Temp gauge capillary tube routing? Triumph 11
Gundy Temp gauge on Mk3 Midget Spridgets 4
M water temp gauge Spridgets 7
A TR4/4A Tr4A temp gauge doesn't work Triumph 19
Sopwith_Camel temp Jaguar 8
T TR4/4A How hot at radiator neck when temp gauge is reading innthe middle Triumph 6
Got_All_4 TR2/3/3A Need a temp glass Triumph 11
B Temp gauge capillary tube Austin Healey 3
P Temp. Probe for 1275 with Bugeye Radiator? Spridgets 21
Jim_Gruber Temp sensor wire spring re attachment to probe Spridgets 3
KVH TR4/4A Infrared Thermometer for Radiator Temp Triumph 6
