'65 Spit heater control valve
DomCasual
Member
I believe the temp control valve cable on my MKII Spit is not connected correctly.
Reference Haynes, Page 82, Fig 2.15 "Heater coolant temperature control valve.
From the diagram in Haynes it appears that the cable passes between the firewall and the valve so when the control knob is pushed in [to stop the cabin heat] the valve would rotate clockwise.
My cable is connected on the engine side of the valve so when the knob is pushed in the valve rotates counter-clockwise.
My question is: Which direction does the valve rotate to admit hot water to the heater coil?
JPSmit
No help here but you may want to ask again on the Triumph forum.
E Spitfire 74 Spit Rebuild Triumph 2
boeingpilot For Sale Parting out '75 and '76 Spit 1500s Triumph Classifieds 0
C Spitfire Mystery wires - Spit, left near distributor Triumph 2
lilifer_13 Spitfire New alternator doesn't fit - '78 Spit Triumph 2
M Spitfire Triumph spit flange/hub removal Triumph 13
D Spitfire 1980 spit.. 34000 miles unbelievable Triumph 5
dklawson Spitfire Bleeding Herald Brakes [similar to Spit] Triumph 9
G For Sale Round-tail Spit-6 Project car with OD for Sale [Cambria CA] Triumph Classifieds 0
tomshobby Spitfire head size of damper pulley bolt on 78 Spit? Triumph 2
D Spitfire 1975 Spit resurrection Triumph 4
trrdster2000 GT6 Finally got a photo of some of our work on the Spit 6 Triumph 2
mgedit TR2/3/3A Coolant spit out of overflow Triumph 20
B Spitfire Parting out 67 Spit Mk3 Triumph 1
D Spitfire MkI Spit questions Triumph 9
AEW Spitfire vintage racer replica on Spit running gear. Triumph 4
T Spitfire Free early Spit in Boise Triumph 1
zedvictor1 Spitfire different diff for Spit 1500 with overdrive? Triumph 1
T Spitfire Grease slinger position on a Spit 1500 axle Triumph 7
glemon Spitfire Craigslist Spit Triumph 2
G Spitfire Anyone ever see a Spit look like this one? Triumph 5
tr6nitjulius Stag TR3*4*6*7*8*Spit*GT6*Stag=20 [pics] Triumph 0
H Post-War Other Spit 1500 Engine in a Herald 1200 Triumph 1
D Spitfire '65 Spit window regulator installation tips needed Triumph 0
This14u Spitfire Pic of Spit A-Pillar Details Triumph 3
D Spitfire MKII cam in a MKII '65 Spit - pros and cons Triumph 2
TonyPanchot Spitfire 72 Spit 1500 Key Light Triumph 2
TonyPanchot Spitfire Spit Windscreen trim Triumph 3
6 Spitfire Tire bumps wheel well on spit mk3 Triumph 5
K Spitfire Door striker 63 Spit Triumph 1
tr6nitjulius Spitfire TR3*3 TR4*2 TR6*7 Spit*2 GT6*1 Others*2 Triumph 5
G Spitfire Bought a Spit today, a bit bummed out Triumph 12
G Spitfire Spit Hardtop $50! Triumph 4
G Spitfire Weight diff b/w Spit 4 and 6? Triumph 3
O Spitfire Spit 1500 Thrust Washers? Triumph 13
This14u Spitfire Clutch Slave Access on Late Spit Triumph 0
doates Spitfire Why Doesn't My Spit Sit Level Triumph 8
B Spitfire Advice on Muffler for 69 Spit Triumph 5
B Spitfire big bearing snap rings on Spit single rail Triumph 0
Dudly Spitfire steering wheel for 79 spit Triumph 1
Dudly Spitfire Blowing fuses in my 79 spit Triumph 10
B Spitfire Aftermarket synchros 1500 Spit single rail Triumph 2
M_Pied_Lourd Spitfire Low Mileage Spit Triumph 3
B Spitfire 1500 SPIT OD ELECTRICAL Triumph 1
Reh Spitfire GT6 rear shock to spit mount Triumph 3
doates Spitfire Spit was running great Triumph 17
G Spitfire Anyome here running a single DCOE on a Spit? Triumph 0
doates Spitfire Spit Does Not Want To Stop Triumph 12
K Spitfire Spit rear spring... Triumph 4
A Spitfire Can I remove the nut on the front of a Spit diff? Triumph 4
A Spitfire Free 1500cc Spit Engine in SF area Triumph 0
