TR4/4A Cam Bearings - TR4
MoHealey
Is there a readily available tool or substitute procedure for extracting/refitting the cam bearings in my TR4 motor?
It's tool S.32-1 in the workshop manual.
Any help appreciated.
Thanks
They did mine at the local machine shop. Be certain that the oiling holes are aligned with the block preperly when installing the new ones.
I had a machine shop turn a mandrel for me. Cost $10, but that was decades ago (and I have no idea where it is today). That, plus some 3/4" threaded rod, nuts and a flat bar with a 3/4" hole was enough to build a suitable substitute.
The rearmost bearing is particularly tricky, as it's the only one that has a front & back (even though the 3 bearings are identical). IOW, the middle two bearings can be installed with either side to the front, but the rear bearing must be turned correctly or it will block the oil feed to the rocker shaft.
Outside of the really basic stuff, it seems as though every "involved" task I give the local shops gets mucked up. Like the aforementioned oilway. Or the oil pressure relief valve on my MGB-GT a couple of months ago (you do NOT want to try to change that bad boy whilst the motor is in the car)...anyway, would like to eliminate that kind of stuff by doing more myself.
Was hoping there was a commercially available tool that could be somehow modified.
Your home-made version has me thinking.....
Thanks
Lisle #18000 is the tool.List$274.00 Sale $179.00 I have sold many over 34 years.Tool is universal and works on all cam bearings. With out it you will have to pay the machine shop and this is the tool they will use.
B Installing cam bearings 1275, can I do it? Spridgets 1
KVH TR4/4A I Replaced the Cam Bearings Triumph 19
M Wanted TR3/4 Cam Bearings Triumph Classifieds 1
D cam bearings Austin Healey 23
KVH General Tech Are These Cam Bearings OK? Triumph 2
KVH TR4/4A Cam Bearings Triumph 6
Boggsy64 MGB Cam bearings - Lisle 18000 MG 0
F First timers mistake our not. [cam bearings] Spridgets 11
A 1300 cam bearings in Midget 1500 Spridgets 3
aeronca65t Spitfire Spitfire cam bearings? Triumph 2
T MGA MGA/MBG cam bearings - FS MG 0
Brosky Cam bearings, full disclosure with pictures Triumph 10
TR6oldtimer Anyone had a problem due to lack of cam bearings Triumph 22
J Spitfire Spitfire Cam bearings Triumph 3
G Cam Bearings Triumph 4
Morris Cam bearings Spridgets 26
S Cam Bearings Austin Healey 9
J TR 4 Norris Cam 342S Spec Sheet Racing 1
PAUL161 T-Series Crane Cam MG 0
D TR6 Gp 2 cam, head shaved ,shorter pushrods, with a rough idle Triumph 10
M MGA RHD twin cam steering pinion MG 0
D Cam Timing question. Spridgets 11
TomMull TR2/3/3A Steering Box Cam or Worm Triumph 18
S TR2/3/3A Replacing the cam shaft Triumph 27
K TR2/3/3A Rebuilding an Engine?..New Cam Sprocket & Gear...1/2 Price Triumph 0
Kolecki TR2/3/3A engine assembly cam timing issue Triumph 8
K TR2/3/3A Finding valve lash with cam specs? Triumph 8
Got_All_4 TR5/TR250 Cam and Lifter Problems Triumph 13
B Anyone have a Europa Twin Cam for sale? Lotus 6
J TR2/3/3A Confirming Cam Set Up Triumph 5
G Valve adjustment and easiest way set cam position Austin Healey 15
Walter74 Kent AH4 cam shaft Austin Healey 18
J General TR Cam shaft upgrade????? Triumph 3
S TR6 Quiz .... What cam is this? Triumph 0
J TR2/3/3A Triumph TR3 cam shaft measurement Triumph 2
B TR4/4A Front cam bearing Triumph 8
B TR4/4A Performance cam Triumph 24
K TR2/3/3A More pics of Kast Cam Triumph 4
K TR2/3/3A Kast f cam...301466 Triumph 5
L TR2/3/3A Cam follower rotation Triumph 5
Csarneson BN4 Cam Gear Install Austin Healey 3
N Best cam choice??? Spridgets 5
R General Tech Cam measurement. Triumph 6
Got_All_4 TR6 Cam selection decision time could use your thoughts Triumph 2
M TR2/3/3A Cam Bearing Tool Dimensions Triumph 16
W Cam gear position BJ8 Austin Healey 11
R TR6 Cam choices? Triumph 23
T TR4/4A Core Plug - Cam Rear change Triumph 7
KVH General Tech Engine Rebuild: Failed at Cam Break-in Triumph 11
