'70 Series II engine bay wiring harness --
Goodfellow
I have purchased a new engine bay wiring harness for my restored Series II. According to the SNG Barratt catalog, it is the correct part number for a Left hand Drive Series II (part #JL-202).
Unfortunately when I looked at the bonnet bulkhead connector from the old harness, I noticed that it had seven wire connections versus the new harness which only has six. All my wiring diagrams from the factory manual and from every Jag site that I could find shows only six connections.
This is the connector in question -- shown is the original connector with seven wires. The extra wire in question is the larger gauge wire that is connected to the #6 bonnet bulkhead plug connector.
This is the wire that isn't found on the newly purchased harness.....
...... and is connected top the #6 plug pin.
The original wiring diagram shows only six connections -- and no mention of this #6 wire. It looks like the wire color was originally white with a very thick red tracer swirling around it -- or red with a thick white tracer -- not sure at this point due to color fading
Has anyone run across this problem with their cars? I should mention that this car has power brakes and AC.
Any help would be appreciated.
I have tried to attach (failed!)a pic. showing the redundant wire ( red/yellow trace) which is listed in the wiring code as supply fog lamp etc.
Regards,
Greg
That Red/Yellow wire is for fog lamps. Generally unused, it was just there for someone who chose to add them.
The other end of that wire is behind the drop-down center panel:
And here you can see it (connected to nothing) inside the bonnet:
G '70 Series II engine bay wiring harness -- Jaguar 7
sim A-series Engine Block Search Spridgets 2
A Making an A-series engine stand adaptor fitting Spridgets 2
M Photos Needed of Series III E-Type Engine Oil Filter Clearance at Exhaust Manifold Jaguar 1
dklawson MGB Nissan Engine/Head Equivalent ??? Datsun B-Series? MG 3
Boink Cut-away B series engine... MG 6
theleisure Inside an A-Series Engine Spridgets 6
78Z B-series Engine ID MG 24
aeronca65t A-Series Austin engine Other British Cars 0
M 4.2 Liter Engine Serial Number in a Series III XJ6 Jaguar 2
Creatrixx A+ head on an A series engine? British Motor Corp 8
mjamgb Modern pistons for a 3-main B-series engine Racing 15
Sherlock BMW 3-Series [with Corvette engine!] Other Cars 5
coldplugs A series OHC engine British Motor Corp 5
AngliaGT Jeep J Series Pickups Spotted 0
B Land Rover Series 3 Wiring Diagrams Rover / Land Rover 0
Deanrobert Xke series lll cooling issues Jaguar 5
zoohow TR2/3/3A lights in series Triumph 2
LD-Ordie Series II gear lube question Rover / Land Rover 3
PAUL161 T-Series T Series Starters MG 0
PAUL161 T-Series T series tierod ends MG 2
O XKE series 2 thermo fan switch bung stud repair. Jaguar 9
M Front caliper rebuild 1970 Series 2 E-Type Jaguar 0
R For Sale Fidanza Aluminum Flywheel for 1275 A-Series Spridgets Classified 0
L BMC A-series: Oil in coolant British Motor Corp 6
6 SOLD!! For sale 1966 Series 1 FHC $85,000.00 Jaguar Classifieds 3
ROARRR Series 2 XJ6 with cert for chev eng for parts or refurb Jaguar Classifieds 4
N Wanted Spats - XK Series? Jaguar Classifieds 4
S Series 1/2 Wiper Motor Needed Rover / Land Rover 0
steveg HS vs HD series carbs Austin Healey 2
W XJ6 Series I bumper swap to Series II Jaguar 0
S For Sale Mg t-series crankshaft tb tc td tf 1250 1500 MG Classifieds 0
D Source for XJ6c Series ll Ignition key blanks & remote Jaguar 1
Lin Fairly new YouTube series on AH100 restoration Austin Healey 0
H Lotus Super 7 series 2 Race car for sale Lotus 0
T For Sale Gear reduction starter fits jaguar 3.8 340 mark series 3.8l 3.4l - $100 Jaguar Classifieds 0
steveg HD series Jet Centering - a Caution Austin Healey 19
M E-type series 1 plastic dash vents Jaguar 1
M XKE Coupe series 1 Tub versus series 1.5 Jaguar 1
O Wanted Vauxhall Victor F series parts Other British Classifieds 2
O TR6 TR series transmission compatibility Triumph 4
B For Sale 1969 Jaguar XKE 4.2L Series II Coupe - Indiana Jaguar Classifieds 0
Basil About to re-install my fuel tank Series I E-Type Jaguar 6
Healey Nut "Father Brown" British television series Austin Healey 9
Basil Series 1 EType Spotted 2
J Wanted tri-SU carbs, manifold and linkage for '69 series 2 4.2 Jaguar Classifieds 3
Nunyas Salvaged Lotus Evora rebuild video series Lotus 8
D Series II E-Type tire size Jaguar 9
S M Series Bonnet Striker Pin failures TVR 2
