    BCF is a FREE resource for the Little British Car community. I just did a little math and found that less than 1% of the registered members appreciate this forum enough to support us with an account upgrade. We do not "require" you to pay to play here, but if you find BCF helpful, appreciate no pop up ads, and want to ensure we stay online - Consider supporting us with an "optional" low-cost member upgrade. There are some benefits to upgrading!
MGB '66 B dash knob help
Coastalman
Here I am back again with another question. Thanks very much for the help the forum has given me as I work on my 1966 B project.
I am disassembling the dash and have taken everything off except the knobs for the vent and heat. I pushed the detent in, just as I did the other knobs on the dash and , unlike the other knobs, these will not budge. Is there something else that needs to be done to get these two knobs off the shafts? I tried to gently pry them off as I was pushing the detent, but no joy.
Thanks,
Charlie
I finally got the knobs off. It took soaking with PB Blaster, heat from a hair dryer and prying from side to side with small screwdrivers to do it. but it is done. Now off to strip the dash, primer it and paint it with wrinkle paint.
Charlie
I'm glad they came off without breaking.
I love the look of wrinkle finish paint.
Glad you got them off intact. I seem to remember struggling with mine when I replaced them a number of years ago. Fussy things.
On reassembly, coat (THIN) the spring thingie with some bearing grease... likely you will be the next one to need to remove them. And if not, the next guy will thank you. :wink:
I do plan on greasing them. I also found some rough edges where the spring grove is cut into the shaft and I have smooth filed those edges down. I polished the shaft with emory cloth to make it as clean as possible. I sure don't want to go through the trouble of getting the knobs off that I did this time.
:thumbsup:
Marla TR4/4A Dash knob chrome bezels Triumph 4
Editor_Reid WTB Bugeye Dash Knob Set Spridgets 13
A Mini Mk1 dash heater knob British Motor Corp 0
tomshobby Steering wheel, dash, and shift knob. Triumph 20
D MGB MGB Dash Temperature Control Knob MG 3
CCURTISS TR2/3/3A TR3 Dash Knob Question? Triumph 2
M dash knob installation Triumph 3
C Midget Defrost/Temp Dash Knob? MG 0
J For Sale TR 3 dash warning light lens, used Triumph Classifieds 0
J Spitfire No start after fiddling with dash Triumph 2
Patrick67BJ8 Custom BJ8 Dash Switch Panel Austin Healey 7
K TR2/3/3A Switching to green LED dash panel bulbs? Triumph 3
V For Sale Hard Top and Solid Walnut Dash for Sale Triumph Classifieds 2
KVH General TR Green Turn Signal Dash Indicator Triumph 8
timsgolf Center Dash Switch Plate Painting Austin Healey 5
C MGA Dash removal MG 0
C For Sale BJ8 original dash Austin Healey Classifieds 3
rjc157 For Sale Dash Austin Healey Classifieds 1
Bocaray TR2/3/3A Headlight Dimmer conversion to dash switch Triumph 6
M MGA RHD MGA dash finisher MG 0
A MGB MGB dash painted MG 13
Rob Glasgow LED Dash Light Upgrade Austin Healey 28
jfarris TR2/3/3A Removing choke cable from dash insert Triumph 3
BoyRacer Blue Vinyl Dash Material Austin Healey 3
jfarris TR2/3/3A Dash Lights Triumph 3
E Wanted wanted Austin healey 3000 adjustable steering wheel & dash pad Austin Healey Classifieds 2
R Ground wires under dash Spridgets 5
EWD TR6 74 TR6 Renegade Dash Wire Triumph 7
B TR4/4A Dash Color? Triumph 3
EWD TR6 TR6 top dash trim paint Triumph 2
TomMull Dash wiring Plus 2 S Lotus 16
I TR6 Dash light issues Triumph 19
J Attaching BT7 Dash Facia Panel Austin Healey 2
EWD TR6 Dash Pad Replacement Triumph 3
longbridgehealey Bugeye dash Spridgets 6
J TR2/3/3A Wooden piece under scuttle with dash Triumph 6
Basil New Dash Cover in the Telly Other Cars 3
oldbagpipe Wanted Early TR4 Silver [Aluminum] Dash Cluster Triumph Classifieds 1
steveg TR6 Metal Dash - does anyone make one? Triumph 13
charleyf TR2/3/3A Under dash fuse Triumph 7
F TR2/3/3A Dash repair Triumph 7
M Getting behind the dash on BJ8 Austin Healey 4
Rut TR4/4A Dash color Triumph 9
Rut TR4/4A TR4 wood dash Triumph 26
J Walnut veneer for the dash, Look what I found! Austin Healey 12
I TR6 Thickness of original TR6 dash Triumph 2
S TR2/3/3A Dash Pot Oil Triumph 14
TRMark T-Series Dash for Sports/Racer MG 5
S BJ8 Choke Cable- How to tighten the nut behind the dash? Austin Healey 6
