100-6 Brake Master Cylinder Bore
prb51
For a BN6 with drums all around, should the bore be .625 or .75? I've seen both listed. This is for a later BN6 with the remote can reservoir.
It appears this often causes issues when ordering etc.... I believe the later BN6, like mine, used the .625 as did the early BN7's....some sites say use it only for the clutch others say clutch or brake??
red57
Discs in front = 5/8" master, Drums all round = 3/4" master. Your BN6 with drums should be 3/4". Remote vs integral reservoir has doesn't matter, it's the volume of fluid needed for those extra wheel cylinders that requires the larger bore master. Some folks compromise pedal effort vs pedal travel and use a .070 master but that's not stock.
prb51
prb51
darn.... guess I better get busy then. My mistake for taking the MOSS catalogue as correct then...they have both listed as correct for the BN6...the last .75 I got from them would not hold a bench bleed....junk.
prb51
prb51
Autofarm sells Brit made stuff but would you have any idea what would work/fit with the hard fluid lines already in the BN6 from that site...mixing and matching can be a pita. I don't want to have to change out the hard lines.
prb51
prb51
Any idea if the stock in/out tube fittings are the same.... I would rather buy a name brand anyway
Thanks for the link...yes, those are the same fittings and dimensions so I'll order one tomorrow.
S "59" 100-6 brake/ clutch master cylinder upgrade Austin Healey 3
A 100-6 Brake Lights Austin Healey 2
simon1966 Brake fluid Canister on a RHD 100 Austin Healey 10
Vineyarder Austin Healey 100-4 brake line fittings Austin Healey 10
Marvin Gruber 100/6 Brake Upgrade Austin Healey 5
L Front Brake 100/6 Austin Healey 1
L 100/6 BN4 Brake fluid Austin Healey 17
B Power Brake Servo for a 100 Austin Healey 3
O 57 100-6 Disk Brake Upgrade kit Austin Healey 9
J Drum brake instructions for 100/6 or 3000 Austin Healey 4
C 100 Drum Brake Keep or upgrade to disc? Austin Healey 9
B Early 100 brake parts needed Austin Healey 1
H 100/6 Brake Drums Austin Healey 1
C 100-6 Resto-Mod Nasty-Boy Brake Upgrade - Help... Austin Healey 2
H 100/6 Brake drums Austin Healey 1
LuckyLuke 100-4 brake / clutch pedal seals not available Austin Healey 3
356roadster brake drums for early 100 bn1: where to buy? Austin Healey 16
Michael Oritt Looking for a good 100 crankshaft Austin Healey 3
56HealeyDan 100-4 Front Crankshaft Seal Austin Healey 7
A 100/6 BN4 Restoration Austin Healey 8
Editor_Reid Healey 100 Frame Diagram Austin Healey 1
A 100/6 BN4 Door Lock Austin Healey 15
R 100-4 Transmission Austin Healey 1
W For Sale Selling 1958 100-6 w/ hardtop Austin Healey Classifieds 4
R Healey 100 Dipstick Stuck Austin Healey 12
T 100 BN2 Possible Ignition Issue Austin Healey 10
T For Sale New Premium Water Pump for 100-6 Austin Healey Classifieds 0
3 100 Clutch Freeplay Austin Healey 7
E For Sale Austin Healey 100 and 3000 parts Austin Healey Classifieds 1
R Big Healey 100 Head Austin Healey 4
G For Sale 100 Year Grille Badges Other British Classifieds 3
Guido36 Webers on a Healey 100 Austin Healey 6
R For Sale 100 engine block w/head Austin Healey Classifieds 3
kodpkd For Sale Alloy valve cover for AH 100-6 3000 PRICE DROP! Austin Healey Classifieds 1
A SOLD!! 1959 100-6 Austin Healey Classifieds 0
dougie '56 100-4 Racer For Sale Austin Healey 12
longbridgehealey SOLD!! 1957 100-6 BN-4 Austin Healey Classifieds 0
longbridgehealey Letting the 100-6 Go Austin Healey 26
P Wanted Wanted: Healey 100-4 frame Austin Healey Classifieds 4
M For Sale Austin Healey 100-4 Lemans Kit OEM Austin Healey Classifieds 5
C What to do with my late father's Healey 100 Austin Healey 5
P 100/6 Front Wheel Alignment Austin Healey 10
andrea 100-Six Photo Album Links Austin Healey 1
prb51 Wanted Wanted...hardtop for 100-6 BN 6 2 seater Austin Healey Classifieds 2
prb51 100-6 Drum Brakes Austin Healey 9
S 1958 100/6 Bumper Brackets Color Austin Healey 2
S Wanted Used Austin-Healy 100/100-6/3000 Restoration Guide By Gary Anderson And Roger Moment Austin Healey Classifieds 14
Michael Oritt 100 Flywheel Weight Austin Healey 16
healeynut For Sale 100/4 block and head Austin Healey Classifieds 1
boxofparts 100-4 Engine Options Austin Healey 12
