100-4 Front Crankshaft Seal
56HealeyDan
Hello Members,
I seem to have a lot of oil coming from the front of the engine and purchased a stock-type replacement to install. Before I do that, I am curious if anyone has retrofitted a modern steel-encased rubber seal with any success? If not, has anyone found a way to make these work better?
Thank you!
If you're referring to the old 'rope style' seal BCS offers a modified cover to fit a modern rubber/spring seal (others may too by now).
pan
Hello Members,
Thank you!
G'day Dan,
I recently fitted a new felt seal on my engine and there is no leak from there. This is the type of seal that Austin used in the day and perfectly adequate provided there is no wear on the crankshaft pulley and the pulley is centralised in the seal. A lip seal could be more likely to wear into surface of the pulley than a felt seal but it would take a long time to do that.
Cheers,
Alwyn
56HealeyDan
56HealeyDan
Thank you for your replies. I forged ahead with an original type seal after removing what was left of the old felt seal. As you can see from the picture, there wasn't much left. The new felt seal from Moss is about twice as wide as the channel in the timing cover. I've got questions! Are these supposed to be trimmed to fit? I've tried wedging it in with no luck. Are they supposed to be saturated with grease or oil to get them wedged in?
I am open to and appreciate any other tips to make this a one-time replacement.
P.S. Alwyn, I am glad I read your post elsewhere about attaching the cover and pully as a unit.
Michael Oritt
If you're still thinking about it get the BCS upgrade--it will undoubtedly outlast a felt seal. I put one on about 10 years ago and when I had to remove the cover to replace the timing chain and tensioner the seal was in like-new condition.
P 100/6 Front Wheel Alignment Austin Healey 10
K 100-6 Exhaust Front Mounting Bracket Austin Healey 2
K For Sale TR3 front passenger side fiberglass floor panel.....$100 CAD OBO plus shipping. Triumph Classifieds 3
L 100/6 replacement front seats Austin Healey 7
L Denis Welch Front Disc Conversion Kit 100/6 Austin Healey 6
MikeAH100M 100 Front Hub Spacer/Distance Piece Austin Healey 2
C 100-6 front drum brakes? Austin Healey 36
A Wanted Front Bumper Brackets/Spring bar assembly for 100-6 Austin Healey Classifieds 0
L Front Brake 100/6 Austin Healey 1
D front shocks 100 m Austin Healey 12
T Front transmission seal not on 100-6 Austin Healey 2
C AH 100 Best Options for front and rear suspension? Austin Healey 9
cmc140 Austin-Healey 100 front splash pan / splash shield question. Austin Healey 8
T 100 4 Front Sway Bar Austin Healey 12
W 100-4 front main bearing cap issue Austin Healey 5
M 100-4 BN2 Front Fender with extra Groove Austin Healey 2
bighealeysource front disc brakes conversion for 100-4 Austin Healey 21
Y Restoring a 58 100 six front shroud Austin Healey 1
R 100-4 front fender removal Austin Healey 2
T 100 Front Shroud Attachment Austin Healey 0
M Healey 100-4 Front Spring Stiffness Austin Healey 2
bighealeysource 100-4 front shock replacement Austin Healey 2
H Healey 100 Front Wheel Bearing replacement Austin Healey 4
bighealeysource Removing front shocks on a 100 -4 Austin Healey 12
S 100/4 front suspension/Mt Washington Hill Austin Healey 3
J Does anyone need a front valance for a 100-4? Austin Healey 1
mbrooks 100 oil leak from front of engine Austin Healey 3
Editor_Reid Healey 100 Front Springs Austin Healey 7
timbn2 Front Shroud for 100 Austin Healey 2
Michael Oritt Looking for a good 100 crankshaft Austin Healey 3
A 100/6 BN4 Restoration Austin Healey 8
Editor_Reid Healey 100 Frame Diagram Austin Healey 1
A 100/6 BN4 Door Lock Austin Healey 15
R 100-4 Transmission Austin Healey 1
W For Sale Selling 1958 100-6 w/ hardtop Austin Healey Classifieds 4
R Healey 100 Dipstick Stuck Austin Healey 12
T 100 BN2 Possible Ignition Issue Austin Healey 10
T For Sale New Premium Water Pump for 100-6 Austin Healey Classifieds 0
3 100 Clutch Freeplay Austin Healey 7
E For Sale Austin Healey 100 and 3000 parts Austin Healey Classifieds 1
R Big Healey 100 Head Austin Healey 4
G For Sale 100 Year Grille Badges Other British Classifieds 3
Guido36 Webers on a Healey 100 Austin Healey 6
R For Sale 100 engine block w/head Austin Healey Classifieds 3
kodpkd For Sale Alloy valve cover for AH 100-6 3000 PRICE DROP! Austin Healey Classifieds 1
A SOLD!! 1959 100-6 Austin Healey Classifieds 0
dougie '56 100-4 Racer For Sale Austin Healey 12
longbridgehealey SOLD!! 1957 100-6 BN-4 Austin Healey Classifieds 0
longbridgehealey Letting the 100-6 Go Austin Healey 26
P Wanted Wanted: Healey 100-4 frame Austin Healey Classifieds 4
