Where is the brake light switch? 1978 Mg Midget
jbuffalo
I have looked for this switch for 2 weeks, in the car by the foot well, under the car?, the brake lights worked -now they dont. Where is the switch? thanks Jim
The brake lite switch is under the hood, in front of the pedal box. it will have to green wires running from it and is screwed into the pedal box in front of the brake pedal. Basically in front of the master cylinder.
mark
Re: Where is the brake light switch? 1978 Mg Midg
Jim, next time don't waste two weeks - ask here first! /bcforum/images/%%GRAEMLIN_URL%%/laugh.gif
If you need a new switch there are several opinions here about where to get one.
Here's mine:
I bought one off Ebay and after 6 months it failed. The plunger part inside broke. I contacted the seller, he said he sells lots of them and this was a first. He offered to send me a new one if I sent him the broken one. (after 6 months!)
I did, he did, I put the replacement on the car & it's working. The green box with white lettering says "LUCAS" and has a part number: SMB422
His name is Pat Nardi
Phone is: 570-326-5395
His Ebay store: Pat's Store
One nice thing about this switch is that it has a hex head so you don't have to remove anything but the old switch to get it in.
It's gonna take a lot of swearing...
Remove the 8 bolts/screws that secure the pedal box to the foot well. You should be able to lift the pedal box just enough to remove the switch without taking anything else off if you are lucky.
If you don't want to save the old switch just break off the part that keeps you from turning it & get one like the one I mentioned above. Then you never have to move the box.
It does help to remove the cover - on my 78 the coil is attached to the cover.
Found it under the coil-just removed the coil and the pedal box cover and unscrewed it. How does it work-it seems to ground against the brake pedal arm? No moving parts that I can see. thanks Jim
Jim, there's supposed to be a plunger that contacts the pedal arm to actuate the switch. The switch is nothing more than a monentary contact push button.
Jeff
Woops, he has a peice missing. Problem found.
Thats why it didnt work when I tested it. The surface is smooth-worn down. Ordered the switch suggested. I am just happy to find the thing. thanks Jim
Got_All_4 General TR Someone asked where to get DOT5 silicon brake fluid a while back Triumph 4
M TR6 Where does this TR6 brake line go?[pic] Triumph 3
tony barnhill Brake Fluid Everywhere!! MG 23
jjbunn I wondered where all that brake fluid went! Triumph 7
356roadster brake drums for early 100 bn1: where to buy? Austin Healey 16
B MGA Where to Buy, What to Buy? Axle Nut MG 9
Scotsman TR4/4A Chimney nuts, where do they go Triumph 5
P Where’s the British car? Spotted 4
AngliaGT As Buzz Lightyear would say - "Triumphs....Triumphs Everywhere" Spotted 6
jehuie Where to post for parts that fit many cars? FORUM Navigation Questions 1
Pythias Where to post FOR SALE Spridgets 1
donbmw Out in the middle of nowhere Spotted 2
A Where to get key blanks for SD1 in the U.S.? Rover / Land Rover 5
F Off Topic Personal update/ Where is Frank? Triumph 4
B BE floor pan welds aren't everywhere? Spridgets 2
Basil Where's Walter? Spotted 8
Q TR2/3/3A Where to start?! Triumph 13
AngliaGT VWs EVERYWHERE! Spotted 0
jlaird MGB Up date. Where to begin? MG 7
B Windshield glass, where to buy Restoration & Tools 4
steveg TR6 '74 - Where is the Starter Relay located? Triumph 1
C MGA Where to tap into 12v for a power outlet MG 2
S TR2/3/3A I have this miss where the car will start and kinda idle Triumph 23
C Anyone know where to get one of these? Austin Healey 6
S TR2/3/3A Slight clunk in the rear assembly somewhere. Triumph 3
P Area where pillar, shroud, and drainage channel meet. Austin Healey 3
P Drainage Channel Where It Meets The Shroud Austin Healey 6
M TR4/4A Where to buy a new crown wheel & pinion for TR4A Triumph 5
PAUL161 T-Series Where My TF Came From MG 1
JPSmit Worth Something Somewhere else Spridgets 7
FlyingCat Spitfire What hoses go where... Triumph 6
A Phase 1, Phase 2, Where's Phase 3 Austin Healey 14
Got_All_4 TR6 triumph tr6 wrist pins where to get them Triumph 5
T TR2/3/3A Where is best spot to check temp with infrared thermometer? Triumph 17
Got_All_4 General TR Anyone know where to get one of these? Triumph 5
R J-H Stromberg carb connections? Where do they go? Other British Cars 2
Paulus General TR Where to get HVDA parts and vibration when engaging clutch. Triumph 13
B TR2/3/3A Where on the clutch pedal? Triumph 4
N Spitfire Just picked up this 73 Spitfire. Hasn't run in ten years. Where do I begin? Triumph 10
P T-Series Where's my last TD? MG 2
AngliaGT Jags EVERYWHERE! Spotted 2
R engine removal- where to connect hoist? Austin Healey 16
C Where and how to "disconnect" my two SU's? Austin Healey 3
55modified TR2/3/3A warning indicator bulbs need replacing where and what to buy? Triumph 4
S TR4/4A Where do the ground straps connect Triumph 5
Foura TR4/4A Oil oil everywhere revisited Triumph 11
Jim_Gruber Hubs a Rocking on side where Speedi Sleeve was installed Spridgets 5
warwick-steve Where did the smell go? Austin Healey 11
Gliderman8 TR6 Convertible cover snaps... where to install? Triumph 2
