Trans Axle Parts
Lotuswins
Okay, I remember how the rocker shaft is held in place now, there is a small roll pin through the detent plate on the rear of the shaft, you will have to punch/drill that out to remove the rocker shaft. Lotus factory drilled that in place when adjusting the 5th gear detent which is external to the case.
AUSMHLY BJ8 Trans Cover Carpet Austin Healey 7
T General TR Another trans popping out of 2nd Triumph 14
S TR2/3/3A engine and trans are stuck together pretty well Triumph 8
AngliaGT Pontiac Trans Sport / Honda Insight Spotted 1
EWD TR6 ā€˜74 TR6 Starter & Trans Cover Triumph 13
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 2
steveg Toyota W58 Trans Hard Getting Into Gear Austin Healey 8
skystryd Trans and Diff Spridgets 7
tinman58 TR5/TR250 Trans slipping in reverse Triumph 38
R General Tech Preserve eng/trans that has been removed Triumph 11
S For Sale 3000 BJ8 Laycock 4 speed with 22% OD trans & 2 6 cyln engines / long blocks / BUNDLE Austin Healey Classifieds 1
S For Sale RARE FIND BN2-BT7 and? Trans Parts for Sale Austin Healey Classifieds 2
T Toyota 6 cylinder eng & trans in a BJ7 Austin Healey 0
Superwrench For Sale 62 BT-7 Trans. and OD unit for sale Austin Healey Classifieds 0
doc50 NASH METROPOLITAN trans capacity? Other British Cars 0
RAC68 Alternate Trans/OD Oil Selection Austin Healey 17
doc50 Nash Metroplitan trans swap? Other British Cars 33
Bob Claffie Spitfire Engine & trans compatability Triumph 1
B For Sale 1956 Austin Healey 100-4 SCCA big bore race car plus parts lot engine trans etc Austin Healey Classifieds 0
P 5spd Trans for Bugeye Sprite Spridgets Classified 14
RAC68 Another Discussion of Trans/OD Fluid Austin Healey 14
S Smitty trans Master cylinder Austin Healey 21
C General MG Midget trans mounts MG 0
R TR2/3/3A Transmission fluid for 57 TR-3 Manual OD Trans Triumph 3
S TR4/4A Trans/OD gear oil? Triumph 14
D TR4/4A Trans replacement front oil seal not same size as original Triumph 2
D TR4/4A broken trans fork pin Triumph 14
C TR4/4A How to get the $&@%# filler bolt out of the side of the trans to top her off?!? Triumph 7
histerical Dat Trans Spridgets 2
bugedd Datsun 210 Trans Question Spridgets 9
M TR4/4A Covers at side of H frame over the trans tunnel...ideas please. Triumph 9
K TR6 Thread repair for trans cover bolt Triumph 14
S TR2/3/3A driver side on the trans-cover? Triumph 11
tinman58 TR5/TR250 Trans swap Triumph 2
NutmegCT Any Borg-Warner automatic trans experts here? Other Cars 5
N Trans compatibility Spridgets 6
RAC68 Loud Trans Scrapping Noise Austin Healey 9
britlover TR4/4A Where can I get an A-type TR4A Trans rebuilt in SE Michigan? Triumph 9
M TR2/3/3A TR3 overdrive trans rear speedi sleeve Triumph 6
S TR2/3/3A overdrive trans Triumph 11
R GT6 GT6 trans issue Triumph 3
S TR2/3/3A Test an overdrive trans. Triumph 6
K TR2/3/3A TR3A with TR6 trans Clutch Bleed Issue Resolved. Triumph 6
B TR6 Trans number decode Triumph 6
G Diff and trans oil Spridgets 8
DanLewis Two midgets available: '79 is free [no engine, trans], running '77 $1500 [NFI] Spridgets 1
K TR2/3/3A Help!..Installed new Clutch....Trans stuck in Gear? Triumph 8
RedTR3 TR2/3/3A Trans Gear lever interference Triumph 0
BlueMax Engine & Trans Finley In! Spridgets 27
doc50 TR2/3/3A TR3 trans issue Triumph 1
