TR2/3/3A TR3 trans issue
doc50
Well, I don't see my post of 10 minutes ago, hope I'm not doubling up here...
My TR4 / OD trans pops out of 2nd gear (only) under hard decel. I can hold the lever without too much pressure to keep it in gear. Q
uestion: Is this something that I can fix from the top or do I have to pull the trans? (Hands folded in prayer here).
Also, is there a piece I can fit into the speedo cable that will correct the speedometer? I show 10-15% high, ie; 80 mph is around 65 actual.
I did this for our old Revcon motorhome and there are several ratios to pick from for that application, hoping there is something here too.
Thanx.
Thom
1959 TR3
TS34909L(O)
doc50 TR2/3/3A TR3 trans issue. Triumph 18
M TR2/3/3A TR3 overdrive trans rear speedi sleeve Triumph 6
toysrrus TR2/3/3A What Oil goes in your TR3/4 Trans? Triumph 14
K TR4/4A How to check TR3/4A Trans for wear? Triumph 3
tinman58 TR2/3/3A Tr3 trans fix Triumph 3
K TR2/3/3A TR3 OD Trans & Diff Fluids? Triumph 4
K TR6 TR6 Trans in a TR3...What about clutch? Triumph 1
K Anyone racing A TR3 with TR6 trans? Racing 0
T TR2/3/3A TR3 trans cover to floor gasket Triumph 8
A TR2/3/3A TR3 REAR TRANS SEAL Triumph 6
T TR2/3/3A TR3 [Toyota] trans question Triumph 5
T TR2/3/3A Early TR3/4 trans help needed Triumph 7
K TR4/4A Putting aTR4 motor and trans in a TR3 Triumph 4
K TR2/3/3A What $ to ask for a used TR3 Trans? Triumph 6
M TR2/3/3A Quick TR3 Question .Trans cover color Triumph 6
TR4nut TR2/3/3A Another TR3 trans trivia question.. Triumph 2
TR4nut TR2/3/3A Question on TR3 trans top cover Triumph 9
C TR2/3/3A Motor and Trans Out!!! TR3 shift lever??? Triumph 6
mrv8q TR2/3/3A TR3 Trans Cover gasket Triumph 2
mrv8q TR2/3/3A TR3 Trans tunnel holes Triumph 3
R TR2/3/3A TR3 Timminge Triumph 11
J For Sale Triumph TR2 TR3 rocker panels, right and left Triumph Classifieds 0
J SOLD!! Triumph TR2 TR3 Channel - Drip - Rear Edge Triumph Classifieds 1
J For Sale TR2 TR3 Tie Member Triumph Classifieds 0
S TR2/3/3A tr3 valve spring compressor Triumph 5
