TR5/TR250 Trans swap
tinman58
I have a TR250 with a 72 TR6 motor and trans with overdrive. The transmission is not in the best of shape. It growls and will pop out of 2nd gear while slowing down. In hindsight I should have gone thru the tranny while I was doing the restoration. The question is... I have a TR3 transmission that I could rebuild while still driving the 250.Could the TR3 transmission mate up to the TR6 Motor and overdrive? Or am I asking for trouble? What I want to do, is a weekend swap, no down time for the TR250.
TR3driver
Great Pumpkin - R.I.P
You'd have to buy another mainshaft to match the OD & 3 synchro box. Besides, since they share oil and what you are describing sounds like the countershaft bearings and/or thrust washers have failed, you'll probably want to go through the OD as well. No sense hooking a freshly rebuilt gearbox to an OD full of crud.
I'm thinking the longer input shaft could be a problem, but don't know for sure. You'll probably have to cut down the front cover as well (although I'm told that depends on exactly which pressure plate you have). Oh yeah, and if it's from a pre-TS50000, the starter won't fit. I think you can get around that by using one of the "high torque" aftermarket starters, though.
tinman58
tinman58
Thanks Randall! I will rebuild the existing one it the 250. I will have to drive the TR3 instead.
doc50 Nash Metroplitan trans swap? Other British Cars 33
Kleykamp TR2/3/3A Engine swap and Separating Trans from Block out of car? Triumph 5
L Spitfire Spitfire Trans Swap... Triumph 2
8 OD trans swap MG 8
AUSMHLY BJ8 Trans Cover Carpet Austin Healey 7
T General TR Another trans popping out of 2nd Triumph 14
S TR2/3/3A engine and trans are stuck together pretty well Triumph 8
AngliaGT Pontiac Trans Sport / Honda Insight Spotted 1
EWD TR6 ‘74 TR6 Starter & Trans Cover Triumph 13
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 2
steveg Toyota W58 Trans Hard Getting Into Gear Austin Healey 8
skystryd Trans and Diff Spridgets 7
G Trans Axle Parts Lotus 20
tinman58 TR5/TR250 Trans slipping in reverse Triumph 38
R General Tech Preserve eng/trans that has been removed Triumph 11
S For Sale 3000 BJ8 Laycock 4 speed with 22% OD trans & 2 6 cyln engines / long blocks / BUNDLE Austin Healey Classifieds 1
S For Sale RARE FIND BN2-BT7 and? Trans Parts for Sale Austin Healey Classifieds 2
T Toyota 6 cylinder eng & trans in a BJ7 Austin Healey 0
Superwrench For Sale 62 BT-7 Trans. and OD unit for sale Austin Healey Classifieds 0
doc50 NASH METROPOLITAN trans capacity? Other British Cars 0
RAC68 Alternate Trans/OD Oil Selection Austin Healey 17
Bob Claffie Spitfire Engine & trans compatability Triumph 1
B For Sale 1956 Austin Healey 100-4 SCCA big bore race car plus parts lot engine trans etc Austin Healey Classifieds 0
P 5spd Trans for Bugeye Sprite Spridgets Classified 14
RAC68 Another Discussion of Trans/OD Fluid Austin Healey 14
S Smitty trans Master cylinder Austin Healey 21
C General MG Midget trans mounts MG 0
R TR2/3/3A Transmission fluid for 57 TR-3 Manual OD Trans Triumph 3
S TR4/4A Trans/OD gear oil? Triumph 14
D TR4/4A Trans replacement front oil seal not same size as original Triumph 2
D TR4/4A broken trans fork pin Triumph 14
C TR4/4A How to get the $&@%# filler bolt out of the side of the trans to top her off?!? Triumph 7
histerical Dat Trans Spridgets 2
bugedd Datsun 210 Trans Question Spridgets 9
M TR4/4A Covers at side of H frame over the trans tunnel...ideas please. Triumph 9
K TR6 Thread repair for trans cover bolt Triumph 14
S TR2/3/3A driver side on the trans-cover? Triumph 11
NutmegCT Any Borg-Warner automatic trans experts here? Other Cars 5
N Trans compatibility Spridgets 6
RAC68 Loud Trans Scrapping Noise Austin Healey 9
britlover TR4/4A Where can I get an A-type TR4A Trans rebuilt in SE Michigan? Triumph 9
M TR2/3/3A TR3 overdrive trans rear speedi sleeve Triumph 6
S TR2/3/3A overdrive trans Triumph 11
R GT6 GT6 trans issue Triumph 3
S TR2/3/3A Test an overdrive trans. Triumph 6
K TR2/3/3A TR3A with TR6 trans Clutch Bleed Issue Resolved. Triumph 6
B TR6 Trans number decode Triumph 6
G Diff and trans oil Spridgets 8
DanLewis Two midgets available: '79 is free [no engine, trans], running '77 $1500 [NFI] Spridgets 1
K TR2/3/3A Help!..Installed new Clutch....Trans stuck in Gear? Triumph 8
