TR6 TR6 -- clutch pedal has too much play
Steve1970
hi all!
been working thru some clutch disengagement issues this weekend. i'm only getting 3/8" slave cyl rod movement (heard it was supposed to be more like 5/8"). as a temp fix i've moved the slave cyl rod up to the top hole of the clutch lever.
gone thru all of the usual troubleshooting steps... problem seems to be with the clutch pedal itself; there's about 1/2" side-to-side free play on the clutch pedal where it pivots on the pedal shaft, very loose feeling. what's the best remedy for this?
i'm hoping that fixing this will allow me to re-place the slave cyl rod back to the middle hole, as the top hole causes the clutch to feel very stiff.
thanks in advance! Steve
pop your clutch linkage off the pedal pivot. Look at the holes, probably elongated, pin might be worn also. You might find bushings at your well equipped hardware store, or go get an early Honda Accord(early being 86-91) clutch mcyl rod. It can replace the lucas one in the cylinder. Bush the elongated hole in the pedal(new rod comes with clevis) and the rod is adjustable for length...
Ron,
I may be reading this incorrectly, but the way I understand this is that Steve has play between the pedal and pedal shaft, not the pedal to linkage connection. I'm thinking up in the top of the box area where the brake and clutch pedal slide on the shaft.
Steve, am I correct in this assumption or did I get it all wrong?
Courtesy of Moss Motors on line catalog:
Sorry, Steve, I nearly forgot. Welcome to the Forum.
You're not too far from me if you ever need help. Don't hesitate to contact me if you do.
hey thanks for the replies guys!
there is some play in the m-cyl linkage rod (which i will address with Ron's idea of using a rubber bush), but the big culprit is where the pedal attaches to the pedal shaft. according to Paul's diagram it looks like i'm short a couple of bushings on the pedal shaft. spectacular timing as i'm just now putting in a TRF order.
Paul many thanks for your offer of help, and please send me a pm if i can be of any help; still learning on these cars, but hey i've got two hands.
You're right, I skipped over the pedal side-to-side movement which is the bushings. Mea Culpa
RonMacPherson said:
...or go get an early Honda Accord(early being 86-91) clutch mcyl rod. It can replace the lucas one in the cylinder. Bush the elongated hole in the pedal(new rod comes with clevis) and the rod is adjustable for length...
hi Ron,
i'm seriously considering doing this (in addition to the clutch pedal bushings). i can't find the pushrod online for that honda accord. should i just call up a dealer and order a clutch master cyl push-rod for a 1990 Honda Accord?
assuming i can get my hands on one, how do i swap the pushrod? does it involve pulling apart the master cyl?
many thanks!
Steve,
The correct rod would be available from Moss in the diagram that I posted, which is part of the assembly. If you have been having issues and the slave is the original, this may be the time to replace everything while you're in there.
I'd order a #35 Clevis Pin as well.
hi Paul,
i didn't see anything in moss (or anyone else's) catalog for an adjustable master cyl push rod (they did have an adj slave rod). i'll give it a second look when i get home tonite. was thinking the honda master cyl pushrod might be a possible alternative if it didn't require a lot of customization.
the slave cyl incl the pushrod was replaced by PO a few months ago, so i'm good there. but a new clevis is a definite.
Steve,
Don't waste any money on the adjustable slave rod. It's of no value. Ask me how I know!!
I meant that the picture for the Clutch Master Cylinder includes the rod at the rear. And no, it is not adjustable.
H TR6 1974 TR6 clutch noise when pedal is depressed Triumph 3
B TR6 TR6 clutch pedal height Triumph 2
Brosky TR6 TR6 V-8 Automatic, with optional clutch pedal Triumph 9
G TR6 Are you happy with your TR6 clutch pedal play? Triumph 28
Got_All_4 TR6 Which Clutch Master Cylinder Fork is for TR6 Triumph 4
TR6Canuck For Sale 72 TR6 clutch and transmission Triumph Classifieds 4
K TR2/3/3A Clutch Slave Cylinder location when TR3 has a TR6 Gearbox? Triumph 16
K TR2/3/3A TR6 Gearbox in a TR3.....Use a TR6 clutch disc and pressure plate or Triumph 7
B TR6 TR6 1976 Clutch Choice Question Triumph 3
bfitz TR6 72 TR6 clutch high engagement point Triumph 16
M TR6 Which clutch master cylinder for a 71 TR6? Triumph 5
M_Pied_Lourd TR2/3/3A TR6 Transmission Swap Clutch Slave Question Triumph 3
T TR6 Problem with Clutch on 1976 TR6 Triumph 12
Scot1966 TR6 TR6 Clutch Triumph 5
K TR2/3/3A TR3A with TR6 trans Clutch Bleed Issue Resolved. Triumph 6
K TR2/3/3A TR6 gearbox on TR3: re clutch slave adjustment. Triumph 13
toysrrus TR6 TR6 & GT6 Flywheel, Clutch question: Triumph 4
D TR6 1976 TR6 Clutch & Brakes Triumph 5
D TR6 1976 TR6 Brakes and Clutch Triumph 0
G TR6 TR6 Clutch Problem Triumph 22
D TR6 New poster, TR6 clutch problem Triumph 10
T TR6 tr6 clutch travel saga Triumph 1
K TR6 TR6 Trans in a TR3...What about clutch? Triumph 1
F TR6 triumph tr6 clutch problem Triumph 14
V TR6 TR6 Clutch Master Triumph 5
hondo402000 TR6 TR6 Clutch question Triumph 5
T TR6 TR6 clutch bleeding woes Triumph 28
hondo402000 TR6 New TR6 Clutch shaft, fork and beefy pin Triumph 3
hondo402000 TR6 TR6 Clutch cross shaft Triumph 9
T TR6 Borg & Beck or LUK clutch kit for the '74 TR6 Triumph 38
S TR6 CLUTCH ???????? TR6 Triumph 4
bigbadbluetr6 TR6 TR6 Clutch Hydaulics Triumph 12
wangdango TR6 '76 TR6 frozen clutch? Triumph 10
RynoBoy74tr6 TR6 1974 TR6 clutch adjustment Triumph 11
JKent TR6 TR6 clutch problems Triumph 16
SherpaPilot TR6 TR6 Clutch Question Triumph 3
hondo402000 TR6 TR6 clutch master cylinder arrived[not girling] Triumph 5
bluemiata90 TR6 TR6 CLUTCH PIN OR HYDRAULIC TROUBLE Triumph 6
bluemiata90 TR6 TR6 clutch issue, Possible bleeding problem ????? Triumph 4
mrv8q TR6 TR6 clutch line Q Triumph 26
bluemiata90 TR6 TR6 ADJUSTABLE CLUTCH ROD??? Triumph 17
D TR6 HVDA TR6 Installation and SPEC Clutch [Cross post] Triumph 2
K TR6 Could 70-76 TR6 Clutch master and slave ..... Triumph 1
T TR6 Replacing TR6 clutch and master cylinders Triumph 2
electric TR6 clutch whistle noise - 74 tr6 Triumph 9
I TR6 Correct clutch master cylinder fluid for 69TR6? Triumph 5
F Brake and clutch fluid 73 TR6 Spridgets 9
F TR6 TR6 clutch noise Triumph 15
