TR6 Which clutch master cylinder for a 71 TR6?
Michael
I am a complete novice and restoring a 1971 TR6. British Victoria lists 2 clutch master cylinders (.75 bore and .70 bore) and I don't know how to know which that I need. Thanks for any assistance.
michael
TR3driver
Great Pumpkin - R.I.P
Either one will work. The smaller bore gives a softer clutch pedal, but takes more pedal travel. For some folks, depending on wear and such, there may not be enough travel. Fitting the larger MC is one work around.
Your car would probably have had the .70" originally, but 69-70 (and earlier) used the .75"
Sbardon
Member
TR3 Driver, I had a clutch master cylinder issue this weekend and 'almost' had to get towed home, the master was sticking at half return and wasn't providing enough fluid do operate the clutch.... Some air pressure in the vent hole and hammer tapping and "click' it returned home... and I got home.... I believe I rebuilt it years ago... but now not trusting it.... and will probably replace it.
I knew about the .70 vs .75 choice, it is interesting.... just wondering if you have any more insight on the choice, pros or cons?
Currently my 76 TR6 has a .70. it has worked in the past, but yes seems to be 'just enough'. My tendency would be to keep it stock...
Are there any risks with the .75? could stroking the slave cylinder farther damage anything?
I have read somewhere that the pedal force will increase about 12%.... ?
any insight would be appreciated.
S
Sbardon
Member
tr3 driver.... my issue became obvious, tried and could not get a new spring, replaced with same. Works well.
mctriumph
On a 6 the OE rod is non adjustable. Since 52 years have passed, I suggest retro fitting the earlier rod to pickup some
adjustment to make it sweeter. A 6 can also benefit from a brace as the earlier cars had. Some of the clutches for the
2.5L are way too stiff and flex the bracket.
Mad dog
K New Clutch Master/Slave Cylinder Austin Healey 1
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
Got_All_4 TR6 Which Clutch Master Cylinder Fork is for TR6 Triumph 4
K TR2/3/3A Clutch and Brake Master Cylinder push rod stop bolts? Triumph 15
R TR6 Clutch Master Cylinder Hydraulic Line (Thread / Flare Type) Triumph 4
mctriumph master cylinder brake/clutch Tr3 Triumph Classifieds 9
J For Sale Triumph TR 2/3 original brake/clutch master cylinder Triumph Classifieds 2
D Clutch Master Cylinder Leak Austin Healey 20
angelfj1 Wanted '59 TR3A Clutch Master Cylinder - USED, RE-BUILDABLE, NOS Triumph Classifieds 4
angelfj1 TR2/3/3A 59 TR3A Clutch Master Cylinder Failure Triumph 19
D 1965 Alpine Clutch Master Cylinder Sunbeam (Rootes) 0
warwick-steve Final fix for clutch pipe to master cylinder leak?? Austin Healey 13
KVH TR4/4A Clutch Master Cylinder Triumph 3
warwick-steve Clutch master cylinder to fluid reservoir leak Austin Healey 5
Rob Glasgow Clutch Master Cylinder Issue Austin Healey 3
Got_All_4 TR2/3/3A Clutch issue maybe master cylinder Triumph 13
S MGB MGB clutch master cylinder MG 0
John_Mc TR6 Rebuild or replace Clutch Master Cylinder? Triumph 8
MY66AH Master Cylinder Clutch Rod Spridgets 6
AngliaGT Early '74 Midget - Clutch Master Cylinder Removal Spridgets 7
T TR2/3/3A Girling Brake/Clutch Master Cylinder [slant port] Variations? Triumph 6
K TR2/3/3A Clutch Master Cylinder "Stop" Bolt.... Triumph 4
R Clutch Master Cylinder Shim Austin Healey 12
S "59" 100-6 brake/ clutch master cylinder upgrade Austin Healey 3
H master cylinder brake vs mc clutch Austin Healey 14
J T-Series clutch Master cylinder or slave? MG 8
Lukens More clutch / brake master cylinder questions. Triumph 7
Henson80MGB T-Series '80 MGB Clutch Master Cylinder-rebuild or replace MG 10
dondel Clutch Fork movement & Master Cylinder Austin Healey 13
PATR8 New Clutch Master Cylinder Triumph 4
mrv8q TR2/3/3A TR3 Clutch Master Cylinder Triumph 20
T Putting the clutch master cylinder back together Triumph 13
Shinsen774 T-Series Clutch Master Cylinder - The little things can be MG 14
Y BJ8 Clutch Master Cylinder Bleeding Procedure? Austin Healey 7
M Clutch Master Cylinder Cap Spridgets 7
hondo402000 TR6 TR6 clutch master cylinder arrived[not girling] Triumph 5
TRnorwegian Changing clutch master cylinder - peace of cake? Triumph 10
T Clutch master cylinder ? Triumph 5
X T-Series Clutch Master Cylinder Cap MG 2
R T-Series 74 B clutch master cylinder MG 0
I TR6 Correct clutch master cylinder fluid for 69TR6? Triumph 5
C brake & clutch master cylinder question Austin Healey 2
N Clutch Master cylinder, rebuild or not. Triumph 26
G clutch master cylinder rebuild. Spridgets 0
Branson Clutch / Master Cylinder Question Spridgets 1
A Clutch Master Cylinder Line Triumph 3
J clutch master cylinder bore diameter? Triumph 1
jerrybny Clutch Master Cylinder Cap Triumph 2
jjbunn T-Series Clutch Master Cylinder - where is it?! MG 3
