TR2/3/3A Clutch Master Cylinder "Stop" Bolt....
karls59tr
Bronze
Anyone know the correct length that the stop bolt for the MC lever is supposed to be? And is the end of the MC pushrod supposed to be almost touching the lever when adjusted properly?
Geo Hahn
Are you referring to the bolts on the front lip of the master cylinder bracket? Although those are not correct for my '59 (were eliminated by then though the holes remained) I added a pair to reduce some of the slop created by wear in the hole at the top end of the pedals:
Since they were non-original I just used what worked - in this case a couple of 5/16" bolts 1ÂĽ" long. Because they are there to remove the play in a pedal at rest - the pedal (and rod) touch them when not in use.
TR3driver
Great Pumpkin - R.I.P
The stop bolts were deleted later on, I don't believe a 59 should have them.
The bolt listed in the SPC is 1-1/8" long. There is a service note on the Girling brakes that calls for 1/2" free play at the pedal "before the master cylinder piston starts to move". ISTR that is supposed to correspond to .030" measured at the stop bolt, with the pedal held down enough to remove all slack in the clevis pin & pushrod.
Don Elliott
When I bought my 1958 TR3A (TS 27489 LO) brand new in May 1958, there were no stop bolts as delivered. Since then - like about 3 years ago, I installed one for one of my master cylinders to limit the travel as Geo describes above,
K
karls59tr
Bronze
Guess I could'nt see the forest for the trees when doing my slave cylinder adjustment..... blamed the release bearing and just about every other component...I just could'nt get the clutch working right. I turned the MC rod in about a 1/4" and voila a perfectly functioning clutch.:eagerness:
K New Clutch Master/Slave Cylinder Austin Healey 1
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
Got_All_4 TR6 Which Clutch Master Cylinder Fork is for TR6 Triumph 4
K TR2/3/3A Clutch and Brake Master Cylinder push rod stop bolts? Triumph 15
R TR6 Clutch Master Cylinder Hydraulic Line (Thread / Flare Type) Triumph 4
mctriumph master cylinder brake/clutch Tr3 Triumph Classifieds 9
J For Sale Triumph TR 2/3 original brake/clutch master cylinder Triumph Classifieds 2
D Clutch Master Cylinder Leak Austin Healey 20
angelfj1 Wanted '59 TR3A Clutch Master Cylinder - USED, RE-BUILDABLE, NOS Triumph Classifieds 4
angelfj1 TR2/3/3A 59 TR3A Clutch Master Cylinder Failure Triumph 19
D 1965 Alpine Clutch Master Cylinder Sunbeam (Rootes) 0
warwick-steve Final fix for clutch pipe to master cylinder leak?? Austin Healey 13
KVH TR4/4A Clutch Master Cylinder Triumph 3
warwick-steve Clutch master cylinder to fluid reservoir leak Austin Healey 5
Rob Glasgow Clutch Master Cylinder Issue Austin Healey 3
Got_All_4 TR2/3/3A Clutch issue maybe master cylinder Triumph 13
S MGB MGB clutch master cylinder MG 0
M TR6 Which clutch master cylinder for a 71 TR6? Triumph 5
John_Mc TR6 Rebuild or replace Clutch Master Cylinder? Triumph 8
MY66AH Master Cylinder Clutch Rod Spridgets 6
AngliaGT Early '74 Midget - Clutch Master Cylinder Removal Spridgets 7
T TR2/3/3A Girling Brake/Clutch Master Cylinder [slant port] Variations? Triumph 6
R Clutch Master Cylinder Shim Austin Healey 12
S "59" 100-6 brake/ clutch master cylinder upgrade Austin Healey 3
H master cylinder brake vs mc clutch Austin Healey 14
J T-Series clutch Master cylinder or slave? MG 8
Lukens More clutch / brake master cylinder questions. Triumph 7
Henson80MGB T-Series '80 MGB Clutch Master Cylinder-rebuild or replace MG 10
dondel Clutch Fork movement & Master Cylinder Austin Healey 13
PATR8 New Clutch Master Cylinder Triumph 4
mrv8q TR2/3/3A TR3 Clutch Master Cylinder Triumph 20
T Putting the clutch master cylinder back together Triumph 13
Shinsen774 T-Series Clutch Master Cylinder - The little things can be MG 14
Y BJ8 Clutch Master Cylinder Bleeding Procedure? Austin Healey 7
M Clutch Master Cylinder Cap Spridgets 7
hondo402000 TR6 TR6 clutch master cylinder arrived[not girling] Triumph 5
TRnorwegian Changing clutch master cylinder - peace of cake? Triumph 10
T Clutch master cylinder ? Triumph 5
X T-Series Clutch Master Cylinder Cap MG 2
R T-Series 74 B clutch master cylinder MG 0
I TR6 Correct clutch master cylinder fluid for 69TR6? Triumph 5
C brake & clutch master cylinder question Austin Healey 2
N Clutch Master cylinder, rebuild or not. Triumph 26
G clutch master cylinder rebuild. Spridgets 0
Branson Clutch / Master Cylinder Question Spridgets 1
A Clutch Master Cylinder Line Triumph 3
J clutch master cylinder bore diameter? Triumph 1
jerrybny Clutch Master Cylinder Cap Triumph 2
jjbunn T-Series Clutch Master Cylinder - where is it?! MG 3
