Clutch master cylinder to fluid reservoir leak
warwick-steve
Hi all
Some weeks ago I fitted a new original type brake/clutch fluid reservoir and new pipes from the reservoir to the master cylinders. The brake side remains dry however the connection at the clutch master cylinder to the clutch pipe leaks slightly. It is only a very slight leak but I cannot stop it however tight I tighten the fitting nut. I top up the fluid every 6 weeks so which I can live with but I am tempted to try fitting a yet another new pipe however I am not convinced this would solve the problem. Is it realistic to drop an o ring under the pipe and tighten onto that?
Would appreciate your advice
Thanks
Steve
carpenter1
You need to make sure that the flare on the pipe and fitting are not damaged or out of shape. a small amount of PTFE tape will seal it
Also check that it is not leaking out of the fitting on the bottom of the reservoir, they do leak from there but dowty washers work better than copper
steveg
Dowty washers (steel with viton centers) work great. I think you need a third one between the clutch reservoir insert and the floor of the main reservoir.
These function like an o-ring contained by a steel washer. They are 1/2" ID.
warwick-steve
warwick-steve
Thanks both
The leak is not under from under the reservoir but at the connection at the clutch master cylinder. I guess I should try PTFE tape first.
I had not heard of Dowty washers but can imagine they would solve many leak problems.
Steve, were you suggesting using one of these under the pipe flare? Is the bottom of the master cylinder threaded hole flat? The od of the washer would be about 9mm and the seating diameter of the flare on the viton seal would be about 5mm.
I wonder if you can get a Dowty seal this small. I will check.
Thanks for your help
Steve
steveg
Steve -
The Dowty washers are for the fittings on the tank. They won't work on the master cylinder.
You'll need a new supply pipe, which comes flared with tube nuts. See item 90 below:
If the flare on your new supply line is leaking, it was not made properly and you have grounds for getting a replacement.
K New Clutch Master/Slave Cylinder Austin Healey 1
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
Got_All_4 TR6 Which Clutch Master Cylinder Fork is for TR6 Triumph 4
K TR2/3/3A Clutch and Brake Master Cylinder push rod stop bolts? Triumph 15
R TR6 Clutch Master Cylinder Hydraulic Line (Thread / Flare Type) Triumph 4
mctriumph master cylinder brake/clutch Tr3 Triumph Classifieds 9
J For Sale Triumph TR 2/3 original brake/clutch master cylinder Triumph Classifieds 2
D Clutch Master Cylinder Leak Austin Healey 20
angelfj1 Wanted '59 TR3A Clutch Master Cylinder - USED, RE-BUILDABLE, NOS Triumph Classifieds 4
angelfj1 TR2/3/3A 59 TR3A Clutch Master Cylinder Failure Triumph 19
D 1965 Alpine Clutch Master Cylinder Sunbeam (Rootes) 0
warwick-steve Final fix for clutch pipe to master cylinder leak?? Austin Healey 13
KVH TR4/4A Clutch Master Cylinder Triumph 3
Rob Glasgow Clutch Master Cylinder Issue Austin Healey 3
Got_All_4 TR2/3/3A Clutch issue maybe master cylinder Triumph 13
S MGB MGB clutch master cylinder MG 0
M TR6 Which clutch master cylinder for a 71 TR6? Triumph 5
John_Mc TR6 Rebuild or replace Clutch Master Cylinder? Triumph 8
MY66AH Master Cylinder Clutch Rod Spridgets 6
AngliaGT Early '74 Midget - Clutch Master Cylinder Removal Spridgets 7
T TR2/3/3A Girling Brake/Clutch Master Cylinder [slant port] Variations? Triumph 6
K TR2/3/3A Clutch Master Cylinder "Stop" Bolt.... Triumph 4
R Clutch Master Cylinder Shim Austin Healey 12
S "59" 100-6 brake/ clutch master cylinder upgrade Austin Healey 3
H master cylinder brake vs mc clutch Austin Healey 14
J T-Series clutch Master cylinder or slave? MG 8
Lukens More clutch / brake master cylinder questions. Triumph 7
Henson80MGB T-Series '80 MGB Clutch Master Cylinder-rebuild or replace MG 10
dondel Clutch Fork movement & Master Cylinder Austin Healey 13
PATR8 New Clutch Master Cylinder Triumph 4
mrv8q TR2/3/3A TR3 Clutch Master Cylinder Triumph 20
T Putting the clutch master cylinder back together Triumph 13
Shinsen774 T-Series Clutch Master Cylinder - The little things can be MG 14
Y BJ8 Clutch Master Cylinder Bleeding Procedure? Austin Healey 7
M Clutch Master Cylinder Cap Spridgets 7
hondo402000 TR6 TR6 clutch master cylinder arrived[not girling] Triumph 5
TRnorwegian Changing clutch master cylinder - peace of cake? Triumph 10
T Clutch master cylinder ? Triumph 5
X T-Series Clutch Master Cylinder Cap MG 2
R T-Series 74 B clutch master cylinder MG 0
I TR6 Correct clutch master cylinder fluid for 69TR6? Triumph 5
C brake & clutch master cylinder question Austin Healey 2
N Clutch Master cylinder, rebuild or not. Triumph 26
G clutch master cylinder rebuild. Spridgets 0
Branson Clutch / Master Cylinder Question Spridgets 1
A Clutch Master Cylinder Line Triumph 3
J clutch master cylinder bore diameter? Triumph 1
jerrybny Clutch Master Cylinder Cap Triumph 2
jjbunn T-Series Clutch Master Cylinder - where is it?! MG 3
