Wanted '59 TR3A Clutch Master Cylinder - USED, RE-BUILDABLE, NOS
angelfj1
Looking for a clutch master cylinder to replace one that failed recently.
The cylinder should look like this
from left to right
original MC during restoration, photos from recent eBay ad (UK supplier)
and NOT like this
(foreground in photo) the MC currently offered by the major suppliers
Any leads on a replacement MC would be appreciated.:smile:
Best regards,
Frank
TomMull
Is this the supplier? Picture shows correct cylinder.
> TRIUMPH TR3 TR3a TR3b Brake / Clutch Master Cylinder (From 1957- 62) | eBay <
I think I have a used one but there are several bore sizes. Will see if I can find it and measure the bore.
By the way, the adapter fitting on the new repros comes out and the pipe goes right in without it or at least it did on the one I replaced several years ago. You can't do much about the reinforcing tab cast into the housing.
Tom
TomMull
This might be what I was thinking of. Probably of no use to you as it has the reinforcing fin. It is also 7/8 bore, which is incorrect for the TR3.
angelfj1 TR2/3/3A 59 TR3A Clutch Master Cylinder Failure Triumph 19
T TR2/3/3A TR3A clutch&brake master cylinders Triumph 11
T TR2/3/3A TR3A clutch problem Triumph 15
C TR2/3/3A TR3A clutch/brake cylinder rebuild Triumph 4
K TR2/3/3A TR3A with TR6 trans Clutch Bleed Issue Resolved. Triumph 6
K TR2/3/3A TR3A Clutch Slave Bleed Issue? Triumph 8
M TR2/3/3A TR3A clutch hydraulic problem Triumph 9
T TR2/3/3A TR3a Clutch Pedal Return Triumph 2
K TR2/3/3A Complicted Clutch Slave Problem TR3A Triumph 12
M TR2/3/3A TR3A Clutch Bleeding Triumph 17
L TR2/3/3A TR3a Clutch cylinders Triumph 16
K TR4/4A Can I put a TR3A Clutch in a 4A? Triumph 16
M TR2/3/3A Position/Adjustment of TR3A Clutch Slave Cylinder Triumph 20
H TR2/3/3A TR3A Clutch Ratteling Triumph 3
Tinkerman TR2/3/3A TR3A Post 60000 Clutch M/C to Reservoir Line Triumph 6
H TR2/3/3A TR3A clutch ratteling Triumph 2
Tinkerman TR2/3/3A TR3A Clutch Pressure Plate Triumph 2
K TR4/4A TR3A and TR4A clutch pressure plate...Difference? Triumph 2
NutmegCT TR2/3/3A clutch pedal "snap" - TR3A Triumph 9
K TR2/3/3A TR3A Clutch MC stop bolt and clutch slave adjust Triumph 5
MGTF1250Dave TR2/3/3A TR3A Clutch Hydraulics Triumph 8
MGTF1250Dave TR2/3/3A Help with TR3A Clutch Slave Cylinder Triumph 3
trglory TR2/3/3A TR3a spark plugs Triumph 1
P For Sale 61 TR3A Triumph Classifieds 1
D TR2/3/3A 59 TR3A Gearbox lever will not move. Triumph 11
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
mctriumph SOLD!! Project car 61 Tr3a Triumph Classifieds 0
71TR6 For Sale TR3A Nose Triumph Classifieds 0
P TR2/3/3A 1958 TR3A missing on cyls 2 & 3 Triumph 8
mctriumph For Sale scrapping two 59 Tr3a's Triumph Classifieds 15
J TR2/3/3A TR3A Finally on the Road! Triumph 6
angelfj1 TR2/3/3A TR3A Boot Millboard Install Triumph 7
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Hamish Racing TR2/3/3A Harewood hill climb Yorkshire TR3a Triumph 3
Hamish Racing Harewood Hill Climb Yorkshire TR3a Racing 0
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 4
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 1
Hamish Racing General TR TR3a hillclimb Thumdrrstorm video uk Triumph 4
Hamish Racing General TR TR3a faster that a Lamborghini Huracan STO ?? Triumph 6
W For Sale 1960 TR3A for sale Triumph Classifieds 0
D TR2/3/3A tr3a occasional seat padding Triumph 10
G For Sale 1960 TR3A for sale $11,999 Triumph Classifieds 0
Hamish Racing TR2/3/3A Greenville TR3a V8 ? Triumph 8
T TR2/3/3A Would like a paper pattern for TR3A hood stick cover Triumph 0
