TR2/3/3A TR3a Clutch cylinders
Lemlem
Hello everyone, On my car the master cylinder has a .75 bore and the slave cyl has a 1 inch. Shouldn't it be the other way round?
TR3driver
Great Pumpkin - R.I.P
Nope, that's right. Why do you want to reverse it?
Geo Hahn
Try thinking about the brakes: The diameter of the master cylinder vs the diameter of the pistons in the calipers.
Like using a lever -- you position the fulcrum to turn a lot of movement into a little movement.
L
Lemlem
Thank you for the responses BUT, "like a lever" a lever works by leverage advantage, ie A long handle and a small pivot. It seems that if the m?cyl is smaller then the volume of fluid entering a larger cylinder will not push it as far! It seems like it should be the other way round,NO!
L
Lemlem
Are there any other comments on this. What I'm trying to say is; if a Master cylinder has a bore of 3/4" and it is operating another cylinder which is 1" then for 1" of movement of the master the fed cylinder can only move 3/4" as it needs more fluid to occupy the 1" diameter. Conversely, if a 1" cylinder fed into a 3/4 the 3/4 piston would have to move farther!
Darrell_Walker
Well, the math is a bit off, you need the ratio of the two volumes, not just the diameter.
But you are right, a larger piston pushing a smaller slave will result in more movement at the slave, the opposite will result in less movement, but with a mechanical advantage.
But that doesn't mean the sizes the Triumph engineers selected are wrong, and of course other parts of the linkage (clutch petal, the arm that operates the fork) also affect the system.
L
Lemlem
Yes, I agree, I was just generalising the dimensions. Well, here is the issue, the clutch pedal needs 2 pumps before it will fully operate and I have bled it properly, adjusted the slave rod as per the book 1/10th" play. It was just the same when I started!
TR3driver
Check how far the slave moves for one stroke of the pedal. If it is less than about 5/8", there is a problem in the hydraulics. (My guess would be a broken spring inside the MC, but there are lots of other possibilities including not having the pedal properly adjusted.)
If it is moving that much (and you do have it properly adjusted), then there is a problem inside the bellhousing.
Oh yeah, also check that the return spring is, in fact, returning the slave piston all the way to the internal stop. A weak or ineffective return spring can also cause odd problems.
TR3driver
JIC anyone is wondering, it's actually the ratio of the piston areas.
L
Lemlem
Thank you, when you say pedal adjustment, both pedals are at the sme height is there a different adjustment?
Darrell_Walker
Randall is of course correct. I was thinking about that there is an equal volume of fluid displaced, but the mechanical advantage (or disadvantage) of the hydraulic potion of the mechanism is the ration of the areas.
L
Lemlem
I appreciate the input from everyone, if anyone knows, what is the recommended process for adjusting the Master cylinder rod.
TR3driver
Nope, drivers seat is always fixed. Only the passenger side folds forward, even on RHD cars.
PS, it's good practice to start a new thread when you have a new question. Lets folks decide if they are interested in reading by the title, and makes it easier to find later on.
L
Lemlem
Thank You, Yes, I realized that afterwards. I clicked on New reply instead of New post. As for the clutch issue, I ended up modifying (shortning)the push rod then removing the very strong spring, I pushed the piston all the way out then adjusted the free play on the rod. I added a very week spring just to ensure the lever would in fact come back. It is perfect. I presume that someone fitted the wrong cylinders, I ordered the correct ones and of course they were not going to work! Thank you all.
sp53
My experience with the ¾ master cylinder and 1 inch slave was resolved when I put in a ¾ slave. What I found was that it took a lot more leg pressure to push the ¾ slave, so I rebuilt the 1 inch slave and found the car much more comfortable to drive.
T TR2/3/3A TR3A clutch&brake master cylinders Triumph 11
T TR2/3/3A TR3A clutch problem Triumph 15
C TR2/3/3A TR3A clutch/brake cylinder rebuild Triumph 4
angelfj1 Wanted '59 TR3A Clutch Master Cylinder - USED, RE-BUILDABLE, NOS Triumph Classifieds 4
angelfj1 TR2/3/3A 59 TR3A Clutch Master Cylinder Failure Triumph 19
K TR2/3/3A TR3A with TR6 trans Clutch Bleed Issue Resolved. Triumph 6
K TR2/3/3A TR3A Clutch Slave Bleed Issue? Triumph 8
M TR2/3/3A TR3A clutch hydraulic problem Triumph 9
T TR2/3/3A TR3a Clutch Pedal Return Triumph 2
K TR2/3/3A Complicted Clutch Slave Problem TR3A Triumph 12
M TR2/3/3A TR3A Clutch Bleeding Triumph 17
K TR4/4A Can I put a TR3A Clutch in a 4A? Triumph 16
M TR2/3/3A Position/Adjustment of TR3A Clutch Slave Cylinder Triumph 20
H TR2/3/3A TR3A Clutch Ratteling Triumph 3
Tinkerman TR2/3/3A TR3A Post 60000 Clutch M/C to Reservoir Line Triumph 6
H TR2/3/3A TR3A clutch ratteling Triumph 2
Tinkerman TR2/3/3A TR3A Clutch Pressure Plate Triumph 2
K TR4/4A TR3A and TR4A clutch pressure plate...Difference? Triumph 2
NutmegCT TR2/3/3A clutch pedal "snap" - TR3A Triumph 9
K TR2/3/3A TR3A Clutch MC stop bolt and clutch slave adjust Triumph 5
MGTF1250Dave TR2/3/3A TR3A Clutch Hydraulics Triumph 8
MGTF1250Dave TR2/3/3A Help with TR3A Clutch Slave Cylinder Triumph 3
trglory TR2/3/3A TR3a spark plugs Triumph 1
P For Sale 61 TR3A Triumph Classifieds 1
D TR2/3/3A 59 TR3A Gearbox lever will not move. Triumph 11
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
mctriumph SOLD!! Project car 61 Tr3a Triumph Classifieds 0
71TR6 For Sale TR3A Nose Triumph Classifieds 0
P TR2/3/3A 1958 TR3A missing on cyls 2 & 3 Triumph 8
mctriumph For Sale scrapping two 59 Tr3a's Triumph Classifieds 15
J TR2/3/3A TR3A Finally on the Road! Triumph 6
angelfj1 TR2/3/3A TR3A Boot Millboard Install Triumph 7
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Hamish Racing TR2/3/3A Harewood hill climb Yorkshire TR3a Triumph 3
Hamish Racing Harewood Hill Climb Yorkshire TR3a Racing 0
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 4
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 1
Hamish Racing General TR TR3a hillclimb Thumdrrstorm video uk Triumph 4
Hamish Racing General TR TR3a faster that a Lamborghini Huracan STO ?? Triumph 6
W For Sale 1960 TR3A for sale Triumph Classifieds 0
D TR2/3/3A tr3a occasional seat padding Triumph 10
G For Sale 1960 TR3A for sale $11,999 Triumph Classifieds 0
Hamish Racing TR2/3/3A Greenville TR3a V8 ? Triumph 8
T TR2/3/3A Would like a paper pattern for TR3A hood stick cover Triumph 0
Top Bottom
