TR2/3/3A TR3A clutch/brake cylinder rebuild
chuck leipham
I'm rebuilding the clutch and brake master cylinders on my original owner 1960 TR3A. I've found that all of the all of the TR3 parts suppliers rebuild kits only come with 2 rubber shaft plunger seals. My original internal shafts and book drawings show three seals. Does anyone know if it's been determined that the middle (smaller rubber plunger seal) is no longer needed?
Administrator
Boss
Chuck, you posted your question in our forum help forum - which is a place to ask questions about how to navigate this forum. Since you have a specific question about your TR3 I'm moving your post to the Triumph forum. If you're reading this, you are now in the Triumph forum.
CJD
Yes, that was a change. The kit should have come with the instructions for which seal was eliminated. I thought it was the end one, which was only needed if the other seal already failed...so it was redundant.
Snowkilts
Don't lose those wavy washers. They are apparently made of unobtainium. And make sure you put them back the correct way around.
T TR2/3/3A TR3A clutch&brake master cylinders Triumph 11
T TR2/3/3A TR3A clutch problem Triumph 15
angelfj1 Wanted '59 TR3A Clutch Master Cylinder - USED, RE-BUILDABLE, NOS Triumph Classifieds 4
angelfj1 TR2/3/3A 59 TR3A Clutch Master Cylinder Failure Triumph 19
K TR2/3/3A TR3A with TR6 trans Clutch Bleed Issue Resolved. Triumph 6
K TR2/3/3A TR3A Clutch Slave Bleed Issue? Triumph 8
M TR2/3/3A TR3A clutch hydraulic problem Triumph 9
T TR2/3/3A TR3a Clutch Pedal Return Triumph 2
K TR2/3/3A Complicted Clutch Slave Problem TR3A Triumph 12
M TR2/3/3A TR3A Clutch Bleeding Triumph 17
L TR2/3/3A TR3a Clutch cylinders Triumph 16
K TR4/4A Can I put a TR3A Clutch in a 4A? Triumph 16
M TR2/3/3A Position/Adjustment of TR3A Clutch Slave Cylinder Triumph 20
H TR2/3/3A TR3A Clutch Ratteling Triumph 3
Tinkerman TR2/3/3A TR3A Post 60000 Clutch M/C to Reservoir Line Triumph 6
H TR2/3/3A TR3A clutch ratteling Triumph 2
Tinkerman TR2/3/3A TR3A Clutch Pressure Plate Triumph 2
K TR4/4A TR3A and TR4A clutch pressure plate...Difference? Triumph 2
NutmegCT TR2/3/3A clutch pedal "snap" - TR3A Triumph 9
K TR2/3/3A TR3A Clutch MC stop bolt and clutch slave adjust Triumph 5
MGTF1250Dave TR2/3/3A TR3A Clutch Hydraulics Triumph 8
MGTF1250Dave TR2/3/3A Help with TR3A Clutch Slave Cylinder Triumph 3
trglory TR2/3/3A TR3a spark plugs Triumph 1
P For Sale 61 TR3A Triumph Classifieds 1
D TR2/3/3A 59 TR3A Gearbox lever will not move. Triumph 11
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
mctriumph SOLD!! Project car 61 Tr3a Triumph Classifieds 0
71TR6 For Sale TR3A Nose Triumph Classifieds 0
P TR2/3/3A 1958 TR3A missing on cyls 2 & 3 Triumph 8
mctriumph For Sale scrapping two 59 Tr3a's Triumph Classifieds 15
J TR2/3/3A TR3A Finally on the Road! Triumph 6
angelfj1 TR2/3/3A TR3A Boot Millboard Install Triumph 7
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Hamish Racing TR2/3/3A Harewood hill climb Yorkshire TR3a Triumph 3
Hamish Racing Harewood Hill Climb Yorkshire TR3a Racing 0
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 4
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 1
Hamish Racing General TR TR3a hillclimb Thumdrrstorm video uk Triumph 4
Hamish Racing General TR TR3a faster that a Lamborghini Huracan STO ?? Triumph 6
W For Sale 1960 TR3A for sale Triumph Classifieds 0
D TR2/3/3A tr3a occasional seat padding Triumph 10
G For Sale 1960 TR3A for sale $11,999 Triumph Classifieds 0
Hamish Racing TR2/3/3A Greenville TR3a V8 ? Triumph 8
T TR2/3/3A Would like a paper pattern for TR3A hood stick cover Triumph 0
