TR6 triumph tr6 clutch problem
farrier
Hello just wanted to see if anyone could help me out with this problem, just got a tr6 that was stored for three years it did not have slave cylinder on it so i fitted new one, when i bled it the piston came nearly all the way out and got stuck, no oil came out of the hose to bleed it the nipple was open.
not sure if this is a clutch fork problem, has anyone got any ideas? would be most gratful for your help
TR3driver
Great Pumpkin - R.I.P
Sounds like a broken taper pin to me. Unfortunately, the only cure is to pull the gearbox and replace the pin (plus maybe some reinforcement so it doesn't break again).
Then you can work on whatever the hydraulic issue is.
tr6_easyrider
Make sure you have the slave cylinder mounted on the back side of the mounting plate and not the front(as I did my first time), as that will cause the rod to over extend and possibly come out of the housing.
cheseroo
+1
I've done the same thing (I think twice even - blonde). It's not that intuitive that you should first put the slave through the bracket and then affix the hydraulic hose rather than hook the hose up first and then attach the slave to the bracket but thats the way it's supposed to go.
F
farrier
yes i live up the road a little in the old school house, i drive past it every day they have proberly seen tr6 outside my house, small world!
F
farrier
hello again i have put new clutch master, new pipes, and slave bled it but still does not work, piston came out and jammed at the end, did swap slave around like everyone said to do so wanted to see if you think this is the clutch fork ?
TR3driver
Pull the operating lever as far away from the slave as you can by hand, then look at the angle it makes with the slave pushrod. Normally, the angle will be slightly greater than 90 degrees, meaning the lever still slopes towards the slave. If you can see that the lever slopes away from the slave (angle less than 90 degrees), then there is definitely a problem inside the bellhousing. Most likely the taper pin, but could be something else.
Check out the Buckeye Triumphs site for lots of good TR6 clutch articles :
https://www.buckeyetriumphs.org/technical/technical.htm
swift6
Is the slave mounted on the correct side of the mounting plate that attaches to the bellhousing?
F
farrier
thanks again slave is mounted on the right side, have a feeling its inside the bell housing, the car was off the road for 3 years when i got it, it did not have the slave cylinder on, and i can now see some hammer marks on the fork so maybe thats why it was put away for that period of time. thanks again
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
tr6nitjulius General TR TRIUMPH TR6 the possibilities! Triumph 12
B TR6 Triumph tr6 coolant leak Triumph 4
D Forum for Triumph TR6 only FORUM Navigation Questions 2
Quackedo TR6 1969 Triumph TR6 Differences Triumph 18
S TR6 Should I Buy This "73 Triumph TR6" Triumph 3
Sherlock Triumph TR6 (rather modified) Spotted 2
D TRIUMPH TR6 BODY SHELL Triumph Classifieds 1
J Wanted WTB Triumph TR6 Body/ Rolling Chassis Triumph Classifieds 0
T For Sale Triumph TR6 N.O.S engine block [late] Triumph Classifieds 2
Gliderman8 General TR Need clarification on Triumph Competition Preparation Manual TR250 TR5 TR6 Triumph 4
S For Sale Triumph TR6 Workshop Manual on CD/ROM - 1969 - 1976 Triumph Classifieds 0
J Wanted Driver Seat Frame For a 1976 Triumph TR6 Triumph Classifieds 0
T For Sale Triumph TR6 pass floor pan Triumph Classifieds 0
Got_All_4 TR6 triumph tr6 wrist pins where to get them Triumph 5
TR3TR6 TR6 Triumph TR6 Windshield seal on ragtop Triumph 6
D TR6 Soft Top Selection 1976 Triumph TR6 Triumph 5
T For Sale Triumph tr6 early tonneau cover - $250.00 Triumph Classifieds 0
C TR6 Need help with a 1969 triumph tr6 Triumph 21
J For Sale Triumph tr6 tr250, tr5 parking brake improvement kit Triumph Classifieds 1
A For Sale TRIUMPH 74 TR6 Dashboard w/Guages Triumph Classifieds 7
F Wanted wtb a 69 Triumph TR6,rustfree,for resto or nice or anything inbetween Triumph Classifieds 0
Y TR6 Triumph TR6 Trunk Boot lid wanted Triumph 4
TR3TR6 TR6 Triumph tr6 heater motor Triumph 3
S TR6 Help installing the Gear Box 1972 Triumph TR6 Triumph 13
A TR6 Triumph TR6 Triple Weber carbs Triumph 9
C TR6 How To: LS1 powered Triumph TR6, in detail Triumph 56
glemon GT6 TR6 GT6 Quoted HP More Triumph Trivia Triumph 1
Hap Waldrop TR6 New VTO15x6 in for the Triumph TR3-TR6 Triumph 25
LBCs_since_1988 TR6 6-Pack Club -Triumph TR6 Triumph 1
C TR6 Triumph TR6 Carburetors Triumph 31
2wrench GT6 1973 Triumph GT6 MK3 Engine for a TR6, yes or no? Triumph 10
toysrrus TR6 `58 Triumph TR6 or TR3? "The Scammer is back"! Triumph 2
hondo402000 TR6 Triumph TR6 thrust washers Triumph 2
Got_All_4 TR6 1969 Triumph TR6 passenger seat Triumph 13
roofman TR6 1972 Triumph TR6 fuse question Triumph 11
T TR6 1976 Triumph TR6 For Sale in Classified Section Triumph 0
J TR6 1975 triumph tr6 engine and tranny - bid idea's Triumph 0
J For Sale Triumph TR2 TR3 rocker panels, right and left Triumph Classifieds 0
J For Sale Triumph TR2 TR3 Channel - Drip - Rear Edge Triumph Classifieds 0
J TR4/4A Vintage Triumph Register Build Codes Triumph 6
J SOLD!! Triumph TR 2 TR 3 windshield stanchion mounting plates Triumph Classifieds 3
oldbagpipe For Sale 1961-1962 Triumph TR4 Short Bubble Bonnet (hood) Triumph Classifieds 0
oldbagpipe For Sale '2' Triumph TR4 engines Triumph Classifieds 9
motzart007 Wanted In search of used seats for 1969 Triumph Spitfire MKIII Triumph Classifieds 0
C For Sale 1963 Triumph TR3b-TCF Triumph Classifieds 5
tr6nitjulius General TR 1/1/2024 in TRIUMPH Triumph 0
