TR6 TR6 Clutch Hydaulics
bigbadbluetr6
I have resently rebuild my TR6 clutch master and cylinder. The fluid in my reservoir has become murky. What has caused this? I know that it could be eating the rubber in the system but I just rebuilt them. Could it be that I need to replace the pipes connecting the two or is there a way to flush the system? I have ran some new fluid while bleeding the system but that wasn't good enough to clean out any rubber. Any help would be appreciated. Thanks Eric
About the only thing I'd use in the lines themselves is denatured alcohol, followed by a GOOD pressure blowout with an air hose. This with nothing attached to the lines. If the M/C and slave have been rebuilt you *should* be able to push the contaminated fluid out with bleeding after reattaching everything.
I had the same problem with a rebuild kit for the master and new slave. I got both from VB which also supplied bad caliper seals. I replaced all from another supplier and no more problem.
I used a VB kit to rebuild my slave cylinder and TRF to rebuild my master. Would the rubber already be deteriorating and causing the fluid in the reservoir to become murky? I also switched to synthetic fluid after the rebuilds. Maybe I need to either flush out the system or replace the lines. What does everyone think? Eric
At one time, British brake/clutch seals were made from some sort of 'rubber' that most DOT 3/4 brake fluids would attack. I know, I did not believe that either, until I proved it to my own satisfaction (around 1978 or so). Rebuilt the entire system, flushed and dried the lines (BTW methanol is safer than denatured alcohol, from the brake's point of view), parked the car for a few months, and found that all of the brand new seals were in the process of turning to goo.
Repeated the experiment with Castrol, and the seals held up just fine.
Most replacement seals since the 80s or so have been made from sterner stuff; but it sounds like maybe someone is supplying them in the original material again.
I bought a VB slave cylinder and used Dot 5, within 3 months it needed rebuilt. After using a TRF rebuild kit, there have been no problems in 5-6 years.
Would the slave cylinder which I rebuilt with a VB kit be causing this problem? The slave is not leaking but would it cause my problem?
Eric
Sounds more like the M/C. It would be unlikely the debris could migrate up the line from the slave. What's in the line already, will only move to and fro rather than 'circulate' to any degree.
DOT-5 is not my first choice. Castrol LMA is all I've used for decades now in old English cars. Some clients have chosen the DOT-5 route, no horror stories.
I have the same problem on my TR4, and I do think it is the seals. The part that troubles me the most is that I either replaced or rebuilt the entire clutch hydraulic system and the symptoms showed up again within a month. I don't recall what sort of brake fluid I am using, but it is probably the cheapest stuff I could find at the LAPS.
When I get bored, I plan to rebuild the works again and use a better brake fluid. Hopefully I can find better seals, as I doubt the cheap brake fluid is the culprit.
Do you mean Castrol LMA?
Honestly, after 30 years, I just don't recall if it was LMA or not. I kinda sorta think not, since I think LMA is a more recent product. But it was whatever LBC suppliers were selling then as "British" brake fluid (for about twice the price of common American brake fluid).
But after running DOT 5 for about 20 years now, I'd never use paint remover (DOT 3/4) if I had a choice!
My entire clutch system was trashed by the DPO.
I had to replace every component.
Purchased everything from TRF. 5000 miles no problems.
dale.
Got_All_4 TR6 Which Clutch Master Cylinder Fork is for TR6 Triumph 4
TR6Canuck For Sale 72 TR6 clutch and transmission Triumph Classifieds 4
K TR2/3/3A Clutch Slave Cylinder location when TR3 has a TR6 Gearbox? Triumph 16
K TR2/3/3A TR6 Gearbox in a TR3.....Use a TR6 clutch disc and pressure plate or Triumph 7
B TR6 TR6 1976 Clutch Choice Question Triumph 3
bfitz TR6 72 TR6 clutch high engagement point Triumph 16
H TR6 1974 TR6 clutch noise when pedal is depressed Triumph 3
M TR6 Which clutch master cylinder for a 71 TR6? Triumph 5
M_Pied_Lourd TR2/3/3A TR6 Transmission Swap Clutch Slave Question Triumph 3
T TR6 Problem with Clutch on 1976 TR6 Triumph 12
B TR6 TR6 clutch pedal height Triumph 2
Scot1966 TR6 TR6 Clutch Triumph 5
K TR2/3/3A TR3A with TR6 trans Clutch Bleed Issue Resolved. Triumph 6
K TR2/3/3A TR6 gearbox on TR3: re clutch slave adjustment. Triumph 13
toysrrus TR6 TR6 & GT6 Flywheel, Clutch question: Triumph 4
D TR6 1976 TR6 Clutch & Brakes Triumph 5
D TR6 1976 TR6 Brakes and Clutch Triumph 0
G TR6 TR6 Clutch Problem Triumph 22
D TR6 New poster, TR6 clutch problem Triumph 10
T TR6 tr6 clutch travel saga Triumph 1
K TR6 TR6 Trans in a TR3...What about clutch? Triumph 1
F TR6 triumph tr6 clutch problem Triumph 14
V TR6 TR6 Clutch Master Triumph 5
hondo402000 TR6 TR6 Clutch question Triumph 5
T TR6 TR6 clutch bleeding woes Triumph 28
hondo402000 TR6 New TR6 Clutch shaft, fork and beefy pin Triumph 3
hondo402000 TR6 TR6 Clutch cross shaft Triumph 9
T TR6 Borg & Beck or LUK clutch kit for the '74 TR6 Triumph 38
S TR6 CLUTCH ???????? TR6 Triumph 4
wangdango TR6 '76 TR6 frozen clutch? Triumph 10
RynoBoy74tr6 TR6 1974 TR6 clutch adjustment Triumph 11
JKent TR6 TR6 clutch problems Triumph 16
SherpaPilot TR6 TR6 Clutch Question Triumph 3
hondo402000 TR6 TR6 clutch master cylinder arrived[not girling] Triumph 5
bluemiata90 TR6 TR6 CLUTCH PIN OR HYDRAULIC TROUBLE Triumph 6
bluemiata90 TR6 TR6 clutch issue, Possible bleeding problem ????? Triumph 4
mrv8q TR6 TR6 clutch line Q Triumph 26
bluemiata90 TR6 TR6 ADJUSTABLE CLUTCH ROD??? Triumph 17
D TR6 HVDA TR6 Installation and SPEC Clutch [Cross post] Triumph 2
K TR6 Could 70-76 TR6 Clutch master and slave ..... Triumph 1
T TR6 Replacing TR6 clutch and master cylinders Triumph 2
electric TR6 clutch whistle noise - 74 tr6 Triumph 9
I TR6 Correct clutch master cylinder fluid for 69TR6? Triumph 5
F Brake and clutch fluid 73 TR6 Spridgets 9
F TR6 TR6 clutch noise Triumph 15
fad64b TR6 TR4A - TR6 clutch pressure plate??? Triumph 9
Brosky TR6 TSI Schumacher 3 piece TR6 clutch Triumph 0
Brosky TR6 TR6 V-8 Automatic, with optional clutch pedal Triumph 9
