TR2/3/3A TR3A Help with Resto Pics Please Front Inner Sill
M_Pied_Lourd
Hi Guys,
Just getting ready to take out the old inner sills and was wondering if anyone has any photos that they could share of how the area at the front of the sill/lower bulkhead should look. Mine is in pretty rough shape and has patches braised and pop riveted. I believe that there is a threaded hole in the nose of the original sills (haven't received my replacements yet)but mine have been welded over as well....
I can post some pics tonight if my description of the area doesn't make sence.
Thanks for the help.
Cheers,
M. Pied Lourd
I don't have any good pics of that area, but yes, there is a threaded weld nut at the front of the inner sill. There are also three other caged nuts along the lower front edge in the back. All of those threads are 1/4"-28, same as all of the other body caged nuts.
BTW, if you have any spots where you need to replace a caged body nut, but don't have access to weld in an original style, I used McMaster's # 90594A040 weld nuts. They weld on from the outside and have the same 1/4"-28 threads. 50 pcs for about $10. I used five of them in the rear fender area right at the back where there's no access to weld in the caged nuts. I also used a few in the more forward section of the rear wings where access was possible, but difficult.
Thanks for posting those Art.
Will see if anyone has some pics of that area. I will try to post some pics tonight of what mine looks like currently. Not pretty...
Cheers,
David
Here's a pic I dug out (cropped). I don't know if it will help you. I'm sure you're looking for some more extensive pics.
BRSLimited said:
Martx, did you make those sills yourself or modify ones you got somewhere else?
The sills that you see laying on the table are from the Roadster Factory. I bought them maybe eight or ten years ago and was going to use them for the restoration. However, along the way, a whole 'nuther body showed up that didn't need inner sills (along with a whole lot of other repairs), so I still have the ones from TRF. They have not been modified, or touched in any way. Other then the surface rust, that is how I received them.
Hi Art,
Actually, that is not too bad. I think that I get the idea. I don't think mine is too far gone to fix it properly. Will wander out to the garage shortly and take some pics.
Cheers,
David
Here is a pic of the area that I was talking about. Par for the course...lots of patching and braising.....
Cheers,
David
Does this help? This is all original.
Next
Awesome Keith. Perfect!
Cheers,
David
I think that the hole (cage nut) in the center of the sill is an attachment point for the bottom of the splash guard that runs up the side of the bulkhead. Can anyone confirm this?
Cheers,
David
Your right MP. Photo of mine.
Cheers, Dick
Thanks Tink, another great photo.
Cheers,
M. Pied Lourd
The pictures that I posted don't have the lip in the front of the bulkhead at the bottom. All the others look like they have a 1/2" or 3/4" lip on them in the front. This must be one of the many changes they made over the years, or something is not correct on my car.
After rebuilding TS33753, when following straight after with TS79550 we noticed that the front edge of the new floors joined the bulkhead with a lip instead of a radius.
We just shrugged and figured it was yet another minor change when the body was re-tooled at TS60000.
Viv.
The Floor that I put in tonight fits perfectly as it extends right to the end of the flange in my picture above. It also lines up perfectly at the rear so I think that I am good to go.
Cheers,
David
Tr3aguy said:
The ones that I have seen that have the lip are from previous floor replacement and is wasn't wrapped up on the bulkhead....Someone can correct me if I am wrong.
The picture I posted earlier is a post 60k body, and on that side I did not replace the floor. It's as original.
T TR2/3/3A Requesting help on removing TR3A steering column and box Triumph 21
J TR2/3/3A Need Help with 62 TR3A Triumph 6
P TR2/3/3A Help needed. TR3A transmission popping out of 1st gear Triumph 13
S TR2/3/3A Triumph TR3A Boot Floor Replacement - Looking for help Triumph 13
60TR3A TR2/3/3A TR3A Temp Gauge Not Working. Help! Triumph 9
Tinkerman TR2/3/3A Front windscreen help needed. TR3A 1960 Triumph 9
Tinkerman TR2/3/3A TR3A Seat spring set needed, Help Triumph 6
Tinkerman TR2/3/3A 60 TR3A Will not run above idle speed, help! Triumph 11
Simmo TR2/3/3A Mota Lita Steering wheel on TR3A. Help! Please. Triumph 4
L TR2/3/3A Help with TR3A wiring diagram Triumph 3
J TR2/3/3A TR3A frame off help Triumph 9
angelfj1 TR2/3/3A TR3A help identifying part Triumph 6
angelfj1 TR2/3/3A TR3A - help to identify this hole. Triumph 11
angelfj1 TR2/3/3A TR3A - help identifying part Triumph 9
Tinkerman TR2/3/3A TR3A Accelerator Rod Dissasembly HELP! Triumph 1
M_Pied_Lourd TR2/3/3A TR3A Rear Axle Help Triumph 25
G TR2/3/3A TR3A body to chassis help Triumph 5
angelfj1 TR2/3/3A Help identifying part [TR3A] Triumph 5
G TR2/3/3A TR3A Gas cap help Triumph 14
Tinkerman TR2/3/3A TR3A Handbrake Help Needed Triumph 9
G TR2/3/3A TR3A Windshield wiper motor...any help? Triumph 2
B TR2/3/3A 1958 TR3A front body attachment help needed Triumph 7
PeterK TR2/3/3A Need help with TR3A top install Triumph 12
J TR2/3/3A tr3a wire wheel help Triumph 5
charles TR2/3/3A TR3A Starter Problems - Help!! Triumph 38
S TR2/3/3A Rough Running TR3A - help with diagnosis Triumph 11
Dan_Pasta TR2/3/3A TR3A steering rebuild help Triumph 10
MGTF1250Dave TR2/3/3A Help with TR3A Clutch Slave Cylinder Triumph 3
RichB4493 Wanted TR3a overdrive dashboard switch Triumph Classifieds 0
kodanja TR2/3/3A 1960 TR3A w/TR4 engine, fuel pump replacement Triumph 21
C TR2/3/3A TR3A Electrical problem Triumph 20
trglory TR2/3/3A TR3a spark plugs Triumph 1
P For Sale 61 TR3A Triumph Classifieds 1
D TR2/3/3A 59 TR3A Gearbox lever will not move. Triumph 11
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
mctriumph SOLD!! Project car 61 Tr3a Triumph Classifieds 0
71TR6 For Sale TR3A Nose Triumph Classifieds 0
71TR6 TR2/3/3A A TR3A wiring question Triumph 17
P TR2/3/3A 1958 TR3A missing on cyls 2 & 3 Triumph 8
mctriumph For Sale scrapping two 59 Tr3a's Triumph Classifieds 15
J TR2/3/3A TR3A Finally on the Road! Triumph 6
angelfj1 TR2/3/3A TR3A Boot Millboard Install Triumph 7
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
B TR2/3/3A TR3A Gearbox fluid capacity question Triumph 7
Hamish Racing TR2/3/3A Harewood hill climb Yorkshire TR3a Triumph 3
Hamish Racing Harewood Hill Climb Yorkshire TR3a Racing 0
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 4
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 1
