TR2/3/3A Rough Running TR3A - help with diagnosis
spineguru
My TR3 is running a bit rough, but not consistently, which is giving me trouble trying to figure out where to go first.
It seems to be running rough when cold, particularly when accelerating under load. It is rough at lower RPM's and less so if I "get on it" a bit. So my initial tought was that it was running rich. The plugs are dry and brownish tan which I think look pretty good.
The car does not necessarily get smoother as it warms up, although it will run smoothly at times. Last night, for example, I took my to dance, and it ran rough on the trip there, but on the retun it ran pretty smooth.
However, near the end of the return trip, it ran very rough, even at constant speed (35-40 mph). It sounded more like a misfiring engine (perhaps a bad plug / wire / point?).
Anyway, I was think of adjusting the carbs (which I am probably not even qualified to that), but have always heard that the carb adjustment should be the last thing looked after ignition, timing, etc.
Lastly, jut to prove how confused I am, I even thought that maybe it was running lean (vs. rich), like maybe the filter was dirty, or something like that.
I guess the bottom line is the car is intermittently running rough whether it is hot or cold.
Anyone have any thoughts?
kc_doyle
If the plugs look good, IMHO I wouldn't mess with the carbs. Sounds like an ignition problem somewhere. But then what do I know. /ubbthreads/images/graemlins/laugh.gif
T
Tinster
Now everyone here knows Tinster has zero knowledge
of things electrical.
But if it was the Crypt Car? First thing I'd do
is buy a new coil and new plugs. See it that
makes a difference. Cheap diagnostic test and
you have nothing to lose.
Come to think about it. That's exactly what I did.
But then the dizzy gave out.
Tin
Harry_Ward
The colour of the plugs sound good to me so I would not lean out the carbs. Sounds either like no fuel to the carbs, bad fuel filter, dirty fuel pump screen, fuel pump not working properly. If no fuel filter or screen maybe junk possibly in the fuel line which is now in your float bowls. Could also be a sinking float in one carb. If not that then check high tension lead to coil for cracks and bad end connectors. If not any of the above points, coil, tune up time, etc. It could be a lot of different things which you will have to eliminate one by one.
Don Elliott
It might be as simple as sediment or other crud down in the bottom of your float bowls. Take off the tops, carefully fish out the float and wipe out the sediment in the bottom. If you have compressed air, blow them dry. To give it a test, fill the float bowls with a bit of gas - or reconnect it completely. I found this out in my TR3A back in 1963 after driving overnight 400 miles from Hamilton, Ontario to Montreal on a full tank of gas. Naturally by the time I got home (4 AM) the tank was almost empty and there were no gas stations open along the way. For a few days after this, it was hard to start till the rocking back and forth of the engine that wouldn't start because it wasn't getting any gas - well the shaking stirred up the sediment, bits of decayed old leaves, rust, etc. from my gas tank - and then it would start. After cleaning it all, it ran fine. When I did my restoration, I had the inside of my tank "slushed" with something like epoxy. Since 1990, I haven't had this problem again in over 94,000 miles because the interior of the tank cannot get rusty.
trrdster2000
Try running a fine file or fine sandpaper thru your points and while in there check out the low tension lead, they give you a fit when they are broken inside the cloth. Points tend to oxidize under the heat. Wayne
bailee2
Had a similar rough running engine due to a fuel problem on my TR3A late summer. It turned out to be the fuel filter. My (plastic) in-line filter was mounted vertically and would just stop gas from flowing when it either got clogged or some anomaly not understood by several good mechanics. Corrective action was to mount a new one horizontally which has shown no signs of reoccurence.
/ubbthreads/images/graemlins/crazyeyes.gif
TNTriumph
I have the same problem with mine I replaced the coil, fuel pump, spark plugs, and air filters. It ran good for awhile but then it went back to the same problem as before which leads me to think that it is the carbs. Let me know if you do anything and it helps.
Greg_Blake
I had a simialr issues once. After much tinkering, it turned out to be a pin hole in the fuel line right under the tank. I replaced all lines and had the tank cleaned out while I had it apart. Fixed the problem.
You can test to see if you have a good strong spark by removing the leads one at a time while the engine is running. Hold the lead close to a ground source and see if you get a good strong arc to ground. This can help you isolate an electrical problem.
It really sounds like a lack fuel though. I'd start looking at your fuel lines, filter(s), tank, and float boals.
Greg
S
spineguru
Here is a bit of irony. After I posted this, my wife's Ford Expedition started running rough and hesitating at low rpm's on acceleration. A trip to the dealer, some computer diagnosis, and we have a winner. A new ignition coil and a set of plugs. Running smooth again. I think it is a sign from God, so I think I will start by checking the ignition side of things! /ubbthreads/images/graemlins/grin.gif
billspit
Hope you find the problem. All the advice above is good. But, check your throttle shafts and see if you have any wear in them. I could never get my old TR-3 to idle worth a dang until I replaced mine.
NickMorgan
I am afraid that I would vote for dirt in the fuel line. That would explain problems when cold when the engine requires a richer mixture and then intermittent problems after that. Electrical problems generally are more constant or more likely when the engine is hot.
C Rough-Running 3000 Austin Healey 29
tr6web TR6 TR6 rough running - what can it be? Triumph 17
BierRunner TR6 TR6 Running Rough Triumph 5
T TR2/3/3A rough running after 20 min shutdown Triumph 9
J Spitfire 1979 Spitfire Running rough [sputtering, exhaust poping] at start up Triumph 2
N Stuck Needle Valve - Rough Running Austin Healey 15
glemon TR5/TR250 Stumped TR250 Running Rough--Follow Up Triumph 3
glemon TR5/TR250 Stumped TR250 Running Rough Triumph 8
D Rough running BT7 3 carb HELP Austin Healey 13
B Thoughts...rough running at cruise. Austin Healey 3
GTP1960 TR2/3/3A Rough running / a lot of carbon on the plugs Triumph 11
K TR2/3/3A Dead Petronix and rough running..... Triumph 10
I BJ8 is running a bit rough. . . Austin Healey 7
B Pics of my ’63 BJ7 and Questions on Hard Starting and Rough Running Austin Healey 11
bigbadbluetr6 TR6 TR6 carb question and running rough Triumph 13
M Rough Running 99 XJ8 after Overheating Jaguar 42
T TR2/3/3A TR3 Running Rough - Cause[s]? Triumph 8
K TR2/3/3A TR3 Running Rough Again? Triumph 7
bighealeysource BN6 runs rough on restart after running great Austin Healey 7
M 87 Series III XJ6 Rough Running Jaguar 16
G Rough running and backfiring MG 30
M TR2/3/3A Another rough running TR3 Triumph 1
T TR2/3/3A TR3 running rough Triumph 6
vping Running rough MG 9
bighealeysource Up-date on engine running rough on my BN6 Austin Healey 1
A rough running after long idle or long low rpm driv Triumph 1
R TR2/3/3A TR3 Missing [running rough not stolen!] Triumph 4
tahoe healey surging and rough running Austin Healey 20
K TR2/3/3A TR3 Running rough..Cam or Carbs?How to diagnose? Triumph 10
H MGB-GT Help with my 1967 MGB GT running very rough MG 5
R TR6 Rough running TR6 = Pertronix? Triumph 27
Woodie rough running Spridgets 7
A TR4/4A TR4A running rough question[s] Triumph 11
Woodie missing, running rough etc etc Spridgets 25
J running rough / missing Spridgets 7
77MidgetMkIV Rough running at weird intervals-any thoughts? Spridgets 22
77MidgetMkIV Now running really rough-help?!?! Spridgets 15
beebopbogo Engine running really rough - 2 cyls? MG 8
D TR6 Gp 2 cam, head shaved ,shorter pushrods, with a rough idle Triumph 10
P Spitfire 1979 Triumph Spitfire starts then runs rough Triumph 2
K TR2/3/3A Mystery clunking and banging from rear of car when driving over rough road or bumps? Triumph 14
H TR4/4A 67 tr4a runs rough and losses power when hot but not over normal temp Triumph 14
skystryd remind me it's fun. good idle. rough when accelerating Spridgets 6
RAC68 Loose Metal Knocking/Banging Sound during Rough Idle Austin Healey 32
C Rough Idle - What to check? Austin Healey 12
55modified Wanted Wanted rough BN1/2 hood for cutting up Austin Healey Classifieds 0
M TR2/3/3A Engine rough on acceleration Triumph 19
N Runs Rough Under Load Spridgets 15
Gliderman8 General TR Rough looking '67 Vitesse Triumph 7
JPSmit Rough Bugeye hood Spridgets 0
