Hey there Guest! If you enjoy BCF and find our forum a useful resource, if you appreciate not having ads pop up all over the place and you want to ensure we can stay online - Please consider supporting with an "optional" low-cost annual subscription.
TR3,3,3A,3B - used a threaded screw (bolt) as the hinge pin for the door check straps. However, I can not find a listing for this screw in the parts catalog. Does anyone have a part number and /or a photo?
I found a couple of 1/4" x 1" long rivets at the hardware store, that work great. Just drop 'em in the hole. If you need to take 'em out, just push 'em back up. At 1" long. they're not going to bounce out.
Spare Parts Catalogue; the factory book listing all (well, most anyway
) of the parts to build a TR. It's a very useful document, especially if you buy parts from The Roadster Factory as they don't publish a full catalog of their own, and instead use the factory part numbers.
Mine were removed from the car when I got it so I'm not sure if it was a bolt or pin. But both of them show marks from a bolt or screw. You can see the marks from the threads.
Here's a picture of my passenger side before I took it apart. The drivers side had the same bolt, but missing the nut. -According to the SPC, the nut should not be nyloc, though there should be a locking washer.
Much of the my car had been restored with non-original parts. -like the bent nail in place of a mills pin in the accelerator linkage.
A friendly reminder - be careful what links you click on here. If a link is posted by someone you don't know, or the URL looks fishy, DON'T CLICK. Spammers sometimes post links that lead to sites that can infect your computer, so be mindful what you click.
(Click X in the upper-right to dismiss this notice)
