TR2/3/3A TR3A help identifying part
angelfj1
Trying to wrap up upper steering support (behind fascia) and can't identify this part. Maybe rear wing stay or rear bumper related but I only have one.
Help would be appreciated. Thanks in advance.
G
Rear wing support. One with 90 degree bend-rear wing support modified into a possible back scratcher?
angelfj1
angelfj1
John: Your too funny! So it got bent and we were fooled into believing it was something else. This is one for the books. We even painted it without knowing it was supposed to be straight. This is the problem with projects that go one for several years.
Many thanks!
Frank
mallard
Frank you may want to trial fit the stay before you bend it. I think the early stays were straight, and the later ones looked just like the one you have.
bgbassplyr
:iagree:
angelfj1
angelfj1
I want to thank everyone who responded. Sometimes parts get mixed up, don't they?
Mystery solved . . . I think.
Part Number 611642, 43
rear overider tie bracket. left and right
illustration from Triumph TR4 Spare Parts Catalog
angelfj1 TR2/3/3A TR3A - help identifying part Triumph 9
angelfj1 TR2/3/3A Help identifying part [TR3A] Triumph 5
T TR2/3/3A Requesting help on removing TR3A steering column and box Triumph 21
J TR2/3/3A Need Help with 62 TR3A Triumph 6
P TR2/3/3A Help needed. TR3A transmission popping out of 1st gear Triumph 13
S TR2/3/3A Triumph TR3A Boot Floor Replacement - Looking for help Triumph 13
60TR3A TR2/3/3A TR3A Temp Gauge Not Working. Help! Triumph 9
Tinkerman TR2/3/3A Front windscreen help needed. TR3A 1960 Triumph 9
Tinkerman TR2/3/3A TR3A Seat spring set needed, Help Triumph 6
Tinkerman TR2/3/3A 60 TR3A Will not run above idle speed, help! Triumph 11
Simmo TR2/3/3A Mota Lita Steering wheel on TR3A. Help! Please. Triumph 4
L TR2/3/3A Help with TR3A wiring diagram Triumph 3
J TR2/3/3A TR3A frame off help Triumph 9
M_Pied_Lourd TR2/3/3A TR3A Help with Resto Pics Please Front Inner Sill Triumph 19
angelfj1 TR2/3/3A TR3A - help to identify this hole. Triumph 11
Tinkerman TR2/3/3A TR3A Accelerator Rod Dissasembly HELP! Triumph 1
M_Pied_Lourd TR2/3/3A TR3A Rear Axle Help Triumph 25
G TR2/3/3A TR3A body to chassis help Triumph 5
G TR2/3/3A TR3A Gas cap help Triumph 14
Tinkerman TR2/3/3A TR3A Handbrake Help Needed Triumph 9
G TR2/3/3A TR3A Windshield wiper motor...any help? Triumph 2
B TR2/3/3A 1958 TR3A front body attachment help needed Triumph 7
PeterK TR2/3/3A Need help with TR3A top install Triumph 12
J TR2/3/3A tr3a wire wheel help Triumph 5
charles TR2/3/3A TR3A Starter Problems - Help!! Triumph 38
S TR2/3/3A Rough Running TR3A - help with diagnosis Triumph 11
Dan_Pasta TR2/3/3A TR3A steering rebuild help Triumph 10
MGTF1250Dave TR2/3/3A Help with TR3A Clutch Slave Cylinder Triumph 3
trglory TR2/3/3A TR3a spark plugs Triumph 1
P For Sale 61 TR3A Triumph Classifieds 1
D TR2/3/3A 59 TR3A Gearbox lever will not move. Triumph 11
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
mctriumph SOLD!! Project car 61 Tr3a Triumph Classifieds 0
71TR6 For Sale TR3A Nose Triumph Classifieds 0
P TR2/3/3A 1958 TR3A missing on cyls 2 & 3 Triumph 8
mctriumph For Sale scrapping two 59 Tr3a's Triumph Classifieds 15
J TR2/3/3A TR3A Finally on the Road! Triumph 6
angelfj1 TR2/3/3A TR3A Boot Millboard Install Triumph 7
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Hamish Racing TR2/3/3A Harewood hill climb Yorkshire TR3a Triumph 3
Hamish Racing Harewood Hill Climb Yorkshire TR3a Racing 0
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 4
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 1
Hamish Racing General TR TR3a hillclimb Thumdrrstorm video uk Triumph 4
Hamish Racing General TR TR3a faster that a Lamborghini Huracan STO ?? Triumph 6
W For Sale 1960 TR3A for sale Triumph Classifieds 0
