TR2/3/3A TR3A Fuel Gauge problem
T
TR3-Stu
My '61 TR3A's fuel gauge is non-functional. It will only move about 1/8" off the peg when I move the sender full range. I purchased a new sender thinking that was the problem - but get the same results. In the past I've used Nisonger in New York for gauge repair/rebuilding and they did great work, but they're no longer doing instrument repair. Moss is recommending either West Valley Instruments in CA, or MO-MA in Albuquerque, NM. Has anyone used either of these two repair outfits? Has anyone used another outfit to rebuild Jaeger instruments?
Thanks,
Stu
Tugboat
Mo-Ma rebuilt my temperature gauge some years ago and did a splendid job. My notes tell me that Margaret Lucas at Mo-Ma handled all of the details and kept me updated on progress. Put me down as a satisfied customer.
Gliderman8
I used Mo-Ma to rebuild my tach and speedo. I’m also a satisfied customer. I’ve never used West Valley but have also heard good things about them.
GilsTR
Memory says..... to get best results with your fuel gauge.... you need to send your sending unit in with the gauge
to end up with the best results.
Frank from San Diego is often on here. He does excellent small gauge restoration. Might touch base with him.
Gil. NoCal
Frank_D
I have used MoMa for Speedo and Temp gauge restoration and Margaret was very responsive and the work was excellent. My Speedo is as accurate as my GPS. I recommend them. Did not know about Nisonger not doing gauge work anymore.
Frank D…..
T
TR3-Stu
Thanks for all the helpful input. Looks like MoMa and West Valley both have positive feedback. As to Nisonger - they were damaged in one of the large tropical storms that hit New York (I think it was tropical storm Sandy) with 6 feet of water in their repair shop. They no longer do repairs, only sell replica gauges. Thanks again.
Stu
Stevenry
Maybe try this first. My gauge worked intermittently, then stopped. When it was intermittent, sometimes a gentle rap with a knuckle would get it registering again. I did not remove my seats, so I couldn’t see anything at all, but laying across both seats and getting a hand up there, I felt what seemed to be a bracket that went across the back of the fuel gauge. In the center of the bracket, right in the middle of the back of the gauge was what felt like a knurled nut. It was loose, and tightening it as much as I could with my fingers got the gauge working perfectly. I assume the bracket and nut/bolt are Important for grounding or an electrical connection.
At some point I’ll get the seats out and have a good look at the rats nest up there. My current project when not working (can’t wait to retire) or battling Pacific Northwest truely astounding summer blackberry growth, is trying to get the climate control and a/c working on an ‘85 Mercedes Turbodiesel wagon.
Steve
Platinum
Steve, do you know about the heater control valve just to the starboard side of center on the firewall needing to have good clean contacts on the two-wire plug? That drove me nuts for a bit. "Normally open" with A/C off. It mixes hot water into the system when the A/C is engaged if it doesn't get power from the control. Just one of the quirks.
Stevenry
DrEntropy,
Yeah, I’ve dealt with the mono valve issues. I actually just put in a Klima heater valve replacement that is excellent. (Mercedessource). However I have vacuum pod leaks on all but one vent, and the compressor froze a couple years ago. Can’t complain after 410,000 miles. I’m trying to get really psyched up to remove the dash so I can get at the pods and replace all the diaphragms and then do the compressor and diesel giant a/c kit.
The spigot heater valve on the TR2 is georgeous in comparison!
Steve
T Wanted Working Fuel Gauge for TR3A Triumph Classifieds 5
K TR2/3/3A Can a TR4A Fuel Gauge be swapped into a TR3A? Triumph 8
D Wanted TR3A Fuel gauge Triumph Classifieds 4
B TR2/3/3A Fuel gauge issue 60 TR3A Triumph 13
T TR2/3/3A TR3A fuel gauge question Triumph 36
tmc TR2/3/3A TR3A fuel gauge Triumph 5
TR3TR6 TR2/3/3A TR3A FUEL GAUGE Triumph 8
NutmegCT TR2/3/3A fuel gauge / sender TR3A Triumph 25
NutmegCT TR2/3/3A Fuel gauge fixed! TR3A Triumph 7
NutmegCT TR2/3/3A Fuel gauge needle replacement TR3A Triumph 0
C TR2/3/3A TR3A Fuel Gauge Triumph 1
kodanja TR2/3/3A 1960 TR3A w/TR4 engine, fuel pump replacement Triumph 15
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
Donald1107 59 TR3A Fuel Pump Triumph 48
F Wanted 1960 Triumph TR3A fuel tank Triumph Classifieds 5
T TR2/3/3A Late Fuel Tank in Pre-TS60000 TR3A Triumph 3
G TR2/3/3A TR3A Electrical Quirks, Flasher, Wipers and Fuel Guage Triumph 4
T TR2/3/3A Is there a special way to get fuel pump off and on a 1961 TR3A? Triumph 4
PatGalvin TR2/3/3A New Fuel Lines TR3A Triumph 2
Anthony_S TR2/3/3A Fuel pump and who knows what else TR3a Triumph 23
R TR2/3/3A TR3A fuel line Triumph 2
R TR2/3/3A TR3A Fuel sending unit Triumph 3
JohnnyMead TR2/3/3A TR3A Routing Fuel Line: Fuel Pump to Carbs Triumph 15
Bremer TR2/3/3A TR3A fuel pump questions Triumph 15
angelfj1 TR2/3/3A TR3A - Fuel Tank Banjo Bolt Triumph 6
bigjones TR2/3/3A TR3A fuel line Triumph 13
JohnnyMead TR2/3/3A TR3A Fuel Tank-Fuel Line Question Triumph 8
ekamm TR2/3/3A Boot closeout for fuel tank tr3a Triumph 13
angelfj1 TR2/3/3A TR3A - Fuel Tank/Boot Fiberboad Panel Triumph 8
M TR2/3/3A TR3A Fuel Pump Refurbish Triumph 20
angelfj1 TR2/3/3A AC Fuel Pump for TR3A Triumph 6
Geo Hahn TR2/3/3A TR3A Fuel Sending Unit Triumph 1
C TR2/3/3A TR3A Electrical problem Triumph 16
trglory TR2/3/3A TR3a spark plugs Triumph 1
P For Sale 61 TR3A Triumph Classifieds 1
D TR2/3/3A 59 TR3A Gearbox lever will not move. Triumph 11
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
mctriumph SOLD!! Project car 61 Tr3a Triumph Classifieds 0
71TR6 For Sale TR3A Nose Triumph Classifieds 0
71TR6 TR2/3/3A A TR3A wiring question Triumph 17
P TR2/3/3A 1958 TR3A missing on cyls 2 & 3 Triumph 8
mctriumph For Sale scrapping two 59 Tr3a's Triumph Classifieds 15
J TR2/3/3A TR3A Finally on the Road! Triumph 6
angelfj1 TR2/3/3A TR3A Boot Millboard Install Triumph 7
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
B TR2/3/3A TR3A Gearbox fluid capacity question Triumph 7
Hamish Racing TR2/3/3A Harewood hill climb Yorkshire TR3a Triumph 3
Hamish Racing Harewood Hill Climb Yorkshire TR3a Racing 0
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 4
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 1
