TR2/3/3A TR3A fuel gauge
tmc
My newly installed fuel gauge in my TR3A (TS45911L) flickers when I turn on the key, but doesn't register correctly. Somewhere in the recesses of my mind I remember reading something about calibrating a fuel gauge. In this case, everything is new or rebuilt.......the gauge, the wiring, the tank sender. Can anyone shed light on this? How does one do such a thing?
NutmegCT
Here's the system I used when I calibrated my own gauge:
https://mgaguru.com/mgtech/electric/fg_06.htm
I also had to put a new pointer on the gauge. That was more challenging than the calibration!
One thing to check first: be sure the gauge is wired in correctly, and that the wires themselves aren't burned through and/or have corroded ends.
Tom
TR3driver
Great Pumpkin - R.I.P
Which includes making sure it is securely grounded. Mine became a whole lot more repeatable when I added ground wires for the gauge and tank sender.
tmc
tmc
Tom
Thanks for the connection with the article. I don't have the resistors, but I know how many gallons are in the tank and what it's capacity is, so if I can adjust my gauge to be semi-accurate, that'll be fine. I do have a ground wire on the sending unit, but not on the gauge. I'll look into that, too.
Don Elliott
I have the original sender and gauge in my 1958 TR3A. When I fill up the tank, my gauge reads full until I have driven about 60 to 100 miles. Then it suddenly jumps to about 3/4 full. From that point down to almost empty, it behaves as it should.
It's been this way for over 22 years.
It's not a problem, but does anyone have any suggestions?
TR3driver
Good place to start would be to learn if the problem is the gauge or the sender. Fill the tank and measure the sender resistance with the gauge disconnected from it. Drive 20 miles or so, check again. Repeat.
My TR3 still has its original gauge & sender AFAIK; and it isn't very linear either. Like yours, it reads full for several days (40-60 miles) after a fill-up. But then it starts falling slowly, but more or less evenly. Below 1/2 tank indicated, it starts falling more rapidly; so its less than 40 miles from 1/4 to empty. It probably just needs better calibration; but could also be that the variable resistor in the sender is worn out. They do wear over time, and generally the wear is the worst in the middle of the range.
BTW, the article linked to above is for a MGA, which doesn't have quite the same resistance range as the TR3-4. If you want a really good calibration, you need to measure your sender and calibrate the gauge to match.
Resistors with leads are getting harder to find, but are still fairly cheap when you do find them. Eg,
https://www.radioshack.com/product/index.jsp?productId=2062304
(I found a better assortment at my local electronics shop, but those are getting harder to find, too.)
PS, Hopefully this is too obvious for words, but JIC : You can always combine multiple resistors to get the value you want. For two resistors in series, the total resistance is the sum of each resistance. Eg, to get 1200 ohms you could combine a 1000 ohm and 200 ohm resistor in series (ignoring the effects of tolerance for the moment).
For resistors in parallel, the formula is more complicated. 1/Rtotal = 1/R1 + 1/R2 Thus for the example of a 1000 ohm plus a parallel 200 ohm, the result is 1 / (1/1000 + 1/200) = 166 ohms.
T Wanted Working Fuel Gauge for TR3A Triumph Classifieds 5
T TR2/3/3A TR3A Fuel Gauge problem Triumph 10
K TR2/3/3A Can a TR4A Fuel Gauge be swapped into a TR3A? Triumph 8
D Wanted TR3A Fuel gauge Triumph Classifieds 4
B TR2/3/3A Fuel gauge issue 60 TR3A Triumph 13
T TR2/3/3A TR3A fuel gauge question Triumph 36
TR3TR6 TR2/3/3A TR3A FUEL GAUGE Triumph 8
NutmegCT TR2/3/3A fuel gauge / sender TR3A Triumph 25
NutmegCT TR2/3/3A Fuel gauge fixed! TR3A Triumph 7
NutmegCT TR2/3/3A Fuel gauge needle replacement TR3A Triumph 0
C TR2/3/3A TR3A Fuel Gauge Triumph 1
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
Donald1107 59 TR3A Fuel Pump Triumph 48
F Wanted 1960 Triumph TR3A fuel tank Triumph Classifieds 5
T TR2/3/3A Late Fuel Tank in Pre-TS60000 TR3A Triumph 3
G TR2/3/3A TR3A Electrical Quirks, Flasher, Wipers and Fuel Guage Triumph 4
T TR2/3/3A Is there a special way to get fuel pump off and on a 1961 TR3A? Triumph 4
PatGalvin TR2/3/3A New Fuel Lines TR3A Triumph 2
Anthony_S TR2/3/3A Fuel pump and who knows what else TR3a Triumph 23
R TR2/3/3A TR3A fuel line Triumph 2
R TR2/3/3A TR3A Fuel sending unit Triumph 3
JohnnyMead TR2/3/3A TR3A Routing Fuel Line: Fuel Pump to Carbs Triumph 15
Bremer TR2/3/3A TR3A fuel pump questions Triumph 15
angelfj1 TR2/3/3A TR3A - Fuel Tank Banjo Bolt Triumph 6
bigjones TR2/3/3A TR3A fuel line Triumph 13
JohnnyMead TR2/3/3A TR3A Fuel Tank-Fuel Line Question Triumph 8
ekamm TR2/3/3A Boot closeout for fuel tank tr3a Triumph 13
angelfj1 TR2/3/3A TR3A - Fuel Tank/Boot Fiberboad Panel Triumph 8
M TR2/3/3A TR3A Fuel Pump Refurbish Triumph 20
angelfj1 TR2/3/3A AC Fuel Pump for TR3A Triumph 6
Geo Hahn TR2/3/3A TR3A Fuel Sending Unit Triumph 1
trglory TR2/3/3A TR3a spark plugs Triumph 1
P For Sale 61 TR3A Triumph Classifieds 1
D TR2/3/3A 59 TR3A Gearbox lever will not move. Triumph 11
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
mctriumph SOLD!! Project car 61 Tr3a Triumph Classifieds 0
71TR6 For Sale TR3A Nose Triumph Classifieds 0
P TR2/3/3A 1958 TR3A missing on cyls 2 & 3 Triumph 8
mctriumph For Sale scrapping two 59 Tr3a's Triumph Classifieds 15
J TR2/3/3A TR3A Finally on the Road! Triumph 6
angelfj1 TR2/3/3A TR3A Boot Millboard Install Triumph 7
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Hamish Racing TR2/3/3A Harewood hill climb Yorkshire TR3a Triumph 3
Hamish Racing Harewood Hill Climb Yorkshire TR3a Racing 0
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 4
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 1
Hamish Racing General TR TR3a hillclimb Thumdrrstorm video uk Triumph 4
