TR2/3/3A TR3 Vent [not the verb] lid pin
TexasKnucklehead
I always thought that this type of snap-ring fit on a shaft that had a groove in it, to allow the ring to snap down into the groove of the pin. The vent lid that came with my car had this set-up, as did the one I got off ebay. Neither of the fat headed pins have a groove for the snap ring -it was held by the tension of the snap-ring (which is a lot of tension). I plan to use a small bolt and nut because of accessibility limitations, but was wondering if these are the proper pins/snap-rings.
I believe that is correct, no groove. There is very little force against the clip, so friction holds it in place quite well.
Probably won't matter, but I'll point out that the threads of the bolt are going to act like a rasp and wear the holes every time you open/close the lid. If you can't deal with the clip, you might consider drilling the original pin for a cotter pin instead.
Seems like I recall using a screwdriver tip to spread the clip, before I got some right-angle snap ring pliers that would fit.
My 56 is set up the same way. I'm glad you asked because I'm sure I would wonder about it when I came to it.
A friction washer I call it is factory issue. Easy to put on but try to get it off with out breaking is a real challenge. I'd drill and carter key it.
Marv
Marv
When your done "carter keying" it, put a cotter key in it. :rolleye:
Sorry Marv, couldn't resist. I'm feeling a little obnoxious this morning.
M TR2/3/3A TR3 Valve cover vent oil leak Triumph 8
N TR2/3/3A TR3 Scuttle Vent Triumph 15
N TR3 scuttle vent FORUM Navigation Questions 1
D TR2/3/3A TR3 Scuttle Vent knob removal? Triumph 2
Kleykamp TR2/3/3A TR4 engine into TR3 crankcase vent tube? Triumph 16
T TR2/3/3A Vent hole in lower front valance of TR3? Triumph 7
Kleykamp TR2/3/3A TR3 cowl vent door spring Triumph 3
CJD TR2/3/3A TR3 tank vent Triumph 5
CJD TR2/3/3A TR3 Vent Rod Triumph 3
B TR2/3/3A 57 TR3 fuel tank vent Triumph 3
T TR2/3/3A TR3 gas tank vent Triumph 12
luke44 TR2/3/3A TR3 Scuttle Vent Assembly Triumph 4
af3683 TR2/3/3A TR3 Drivers Side Defroster Vent Triumph 11
luke44 TR2/3/3A TR3 Scuttle Vent Disassembly Problem Triumph 6
S TR2/3/3A Tr3 gas cap vent Triumph 0
S TR2/3/3A tr3 gas tank vent Triumph 3
H TR2/3/3A TR3 Scuttle Vent Questions Triumph 3
Tinkerman TR2/3/3A TR3 Vent Assembly, The True Problem Triumph 7
S For Sale FREE - TR3 engine and transmission Triumph Classifieds 0
W TR2/3/3A TR3 Seat Belts Triumph 3
R TR2/3/3A TR3 Timminge Triumph 11
J For Sale Triumph TR2 TR3 rocker panels, right and left Triumph Classifieds 0
J SOLD!! Triumph TR2 TR3 Channel - Drip - Rear Edge Triumph Classifieds 1
J For Sale TR2 TR3 Tie Member Triumph Classifieds 0
S TR2/3/3A tr3 valve spring compressor Triumph 5
