TR2/3/3A TR3 Steel Wheels
DavidApp
I got a Rimmer Bros. TR2-TR6 Big Sale catalog in the mail.
In it I noticed they list New Steel road wheels for the TR6 as either 5.5 J x 15 or 6 J x 15
and Alloy wheels for TR2 to TR6 as 5.5 J x 15.
Is there a difference between the TR3 to TR6 wheel stud pattern or would these steel wheels work for the TR3?
I did manage to assemble a good set of 5 steel wheels.
David
TR3driver
Great Pumpkin - R.I.P
Stud pattern is the same, I have original TR6 wheels on my TR3.
My only concern with the alloys is whether they would clear the calipers. The later brakes were slightly smaller; probably to give a bit more room for the wheels. I once had some Asian rim.that fit fine on the back, but hit the calipers up front.
DavidApp
My thought was that it would have been nice to have new steel wheels. I had to acquire 2 and a bit cars worth of wheels before I had 5 good wheels.
I presume the 5.5 J wheels and tire may be too thick to go in the spare compartement.
David
TFB
I don't think you can run the TR3 hubcaps on TR6 wheels.
If any wheel manufacturers(Moss?) are listening I would pay wire wheel or alloy replica prices for new Tr3 steel wheels.
Tom
TR3driver
Mine sure are. I use a "compact spare" tire mounted on a stock TR3 rim for the spare. If I get a flat, the big wheel has to ride home behind the seats.
Depends on how badly you want them :smile:
TR3driver
Same setup, different car
PS, note that they are later TR6 wheels, that I modified with studs for the TR3/4 hubcaps. Using 69 TR6 wheels won't look quite the same, as those studs stick out quite a bit and so hold the cap farther out.
F For Sale Four Steel Wheels Triumph TR3 or TR4 Triumph Classifieds 5
T TR2/3/3A TR3 steel wheels Triumph 6
Scotsman TR2/3/3A Should inner tubes be used with TR3 OEM steel wheels Triumph 3
K TR2/3/3A What is a set of good used TR3 steel wheels worth? Triumph 18
T TR2/3/3A TR3 steel wheels - always silver? Triumph 2
T TR2/3/3A Tr3 steel wheels Triumph 12
T TR2/3/3A Anyone running tubeless radials on TR3 steel radials? Triumph 2
K TR2/3/3A What's a TR3 steel hardtop worth? Triumph 7
af3683 TR2/3/3A TR3 Stainless Steel Exhaust Triumph 5
T TR2/3/3A What gauge steel use for TR3 frame? Triumph 3
J TR2/3/3A stainless steel rear spring pins for TR3 Triumph 19
G TR2/3/3A tr3 steel hardtop Triumph 12
S TR2/3/3A rad steel pipe tr3 Triumph 2
fad64b TR2/3/3A TR3 steel wheel color Triumph 6
R TR2/3/3A TR3 Timminge Triumph 11
J For Sale Triumph TR2 TR3 rocker panels, right and left Triumph Classifieds 0
J SOLD!! Triumph TR2 TR3 Channel - Drip - Rear Edge Triumph Classifieds 1
J For Sale TR2 TR3 Tie Member Triumph Classifieds 0
S TR2/3/3A tr3 valve spring compressor Triumph 5
