so i have been lurking here a while and i believe its time to share my new project with you guys. I had the car shipped to me from 1200 miles away.
It came shipped on the rotisserie, which made booking a shipping company difficult. Luckily a guy with a big enclosed trailer was heading to Daytona and had room for my new little project. That is the "rough side also". Heres the real reason i had the car shipped all this way
The front suspension is completely custom. The previous owner works for a big name suspension company and this was going to be a street/autocross car for him. He didn't want to give up the project but his work was going to be paying him to design and fabricate suspension on his own Nova project. You cant pass up getting paid to work on your own project car so he put this midget up for sale. The suspension stats are-
-New Wilwood's tall spindles
-New Heidt's Superide II narrowed tubular upper and lower control arms.
-New Afco double adjustable coil over shocks with 4" stroke
-New 10.5" vented rotors with Wilwoods four piston calipers
-New Schroeder torsion bar
-New modified Triumph Spitfire quick steer rack 2.5 turns lock to lock.
-The complete suspension hub to hub is only 1.5" wider than the stock front end was.
I have been working on swaping a duratec engine into a spridget for a while. I had a junky sprite i was using to mock up everything and see if it would fit. When i saw this car for sale i new it was the perfect car for my engine. I should have the handling and braking to keep up with the engine. Also im no engineer and i think i would have had to give a real engineer a suitcase full of cash to have what is on this car duplicated. Heres the engine thats going in the car.
Basically its a 2.0 ford focus engine. all aluminum, very light. Caterham currently uses them in their new cars. I am using a custom bellhousing to fit a ford type 9 transmission to the engine. Other that the throttle bodies i plan to keep it pretty stock until i get used to the car. then i would like to rebuild it with uprated parts. high flow head, better cams, higher compression pistons, ect. 250 hp is not unheard of from these engines.
The car is not ready to just drop the engine in and go. I have a good bit of panel replacing to do.
I think my first step is to build a sort of internal frame structure to keep the door gaps ect from moved around. the car is on a rotisserie and when i start cutting big chunks of metal out i don't want things moving around that shouldn't. Has anyone else done floor, rocker, ect replacements with a spridget on a rotisserie?
I know this is going to be a huge undertaking. but this really is a dream of mine come true. I will gladly accept any pointers and comments anyone has. I know many people here have started with a rusty shell and now drive beautifully restored spridgets. I hope i can accomplish the same but obviously with a bit of a twist. thanks in advance
