Spitfire Spitfire Rubber Bumper Pad Removal
bhooper
Is it possible to remove the rubber bumper pads that were installed on the Spitfire's in '75?
I understand the purpose, but they look tacky. Can they be neatly removed, without leaving a big hole in the chrome bumper?
thanks!
If you're talking about the two front black rubber "underriders," yes, they can be removed. However, you'll be left with two body-colored frame extensions that look worse. I have a '76 and have ordered a pair of the less-obtrusive, earlier-style underriders that were installed on '71-'73 MKIV and 1500 models. It appears they can be installed on later models once you remove a plate at the front of the frame extensions. I should know within a week or so if it's a direct swap and will post results. Wish me luck.
Looking forward to see how you make out on that swap. I have a '78, and if I end up keeping it, I want to do that swap as well.
Keep us posted...
Ron
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by ainadude:
If you're talking about the two front black rubber "underriders," yes, they can be removed. However, you'll be left with two body-colored frame extensions that look worse. I have a '76 and have ordered a pair of the less-obtrusive, earlier-style underriders that were installed on '71-'73 MKIV and 1500 models. It appears they can be installed on later models once you remove a plate at the front of the frame extensions. I should know within a week or so if it's a direct swap and will post results. Wish me luck.<hr></blockquote>
I, too, would like too see how your swap goes! If its not hard, I may like to loose my big ugly rubber overriders also! Send me a pic, or post it if you can put it one your own website (then just use the "image" button when posting to point to the picture).
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by aeronca65t:
All of this talk suddenly made me think of this:
<hr></blockquote>
Now THAT's a bumber! Enough to make a 50's Buike envious
I am forwarding this from Dolly Parton "Shame on all of you for being ashamed" Big ugly overiders indeed.
And then I think about last summer when I watched a guy from my cafe table back into the front of my spit 2 or 3 times while parallel parking "by feel"! Wonder what the nose would've looked like then with the small over riders on...
Ron
eschneider Spitfire spitfire GT6 rubber source??? Triumph 7
C Wanted Spitfire 1500 diff rebuild Triumph Classifieds 0
L Spitfire New Acquisition, 1976 Spitfire Triumph 5
motzart007 Wanted In search of used seats for 1969 Triumph Spitfire MKIII Triumph Classifieds 1
B For Sale GT6/Spitfire License Plate Light Assembly Triumph Classifieds 0
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
A Spitfire Spitfire Diff Pinion Seal? Triumph 2
3798j General TR Spitfire up in the Tree Triumph 2
E Spitfire '69 Spitfire hard top Triumph 2
D For Sale 1966 Spitfire 4 MK 2 for sale, Triumph Classifieds 1
R For Sale Spitfire MKIII projects Triumph Classifieds 0
Darwin Wanted Spitfire engine needed Triumph Classifieds 0
G Spitfire Spitfire 1500 differential whining Triumph 6
T Spitfire Spitfire MK2 Clutch Hydraulics Triumph 2
A Spitfire Spitfire Fuel pump issues Triumph 5
P Spitfire 1979 Triumph Spitfire starts then runs rough Triumph 2
Lairhead52 Wanted 78 Spitfire instrument panel lights / lenses Triumph Classifieds 3
D Spitfire 1980 California Spitfire, Help Figuring What To Do With It? Triumph 15
W Spitfire 1975 Spitfire 1500 shifting problems when hot Triumph 8
K TR2/3/3A Mystery Clutch MC? Spitfire....TR4....69-70 TR6??? Triumph 2
K Spitfire 1978 Spitfire possible Vapor Lock? Triumph 16
R Spitfire Turn signal wiring Spitfire Triumph 5
S Spitfire Spitfire 1296 engines Triumph 1
D Wanted WTB: Late Triumph Spitfire Top Frame Triumph Classifieds 8
C Spitfire 1967 Triumph Spitfire Triumph 2
Dnickels Spitfire Spitfire mk2 front suspension too soft Triumph 2
T For Sale One Owner 1969 Spitfire for sale Triumph Classifieds 0
Dnickels Spitfire Spitfire lighting issues Triumph 4
SteveTheBrewer Spitfire Spitfire Rebuild Update Triumph 5
Basil Spitfire 74 Spitfire Barn Find Triumph 1
I Spitfire Triumph Spitfire 1500 refuses to awake after 10 year hibernation Triumph 6
I Spitfire spitfire 1500 refuses to awake after 10 years Triumph 2
B Spitfire Mk3 seat rails Triumph Classifieds 0
M Spitfire 1500 LH Door Triumph Classifieds 0
P Spitfire Bits Triumph Classifieds 1
M 1976 Spitfire 1500 (RHD) Triumph Classifieds 2
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 2
FlyingCat Wanted 1980 Spitfire Rear Bumper Triumph Classifieds 2
SteveTheBrewer Spitfire Triumph Spitfire Restoration Blog Triumph 22
R Spitfire Spitfire 1500 Triumph 3
T Spitfire Spitfire lights Triumph 7
Basil Spitfire How do I adjust SU carbs on my Spitfire? Triumph 5
F Spitfire No output from coil HELP!! 1972 Spitfire 1.3L Accusspark Triumph 19
glemon Spitfire Spitfire Questions Triumph 7
tr6nitjulius General TR TR6*8 TR4*2 GT6 Spitfire Triumph 2
J For Sale 1974 Spitfire for sale Triumph Classifieds 0
F Spitfire Triumph Spitfire , what fuel to run Her on with no engine history? Triumph 11
J Spitfire 1979 Spitfire Running rough [sputtering, exhaust poping] at start up Triumph 2
eschneider Spitfire Float height - '64 spitfire w/ dual HS2 Triumph 1
