Spitfire Spitfire Rubber Bumper Pad Removal
bhooper
Member
Is it possible to remove the rubber bumper pads that were installed on the Spitfire's in '75?
I understand the purpose, but they look tacky. Can they be neatly removed, without leaving a big hole in the chrome bumper?
thanks!
ainadude
Member
If you're talking about the two front black rubber "underriders," yes, they can be removed. However, you'll be left with two body-colored frame extensions that look worse. I have a '76 and have ordered a pair of the less-obtrusive, earlier-style underriders that were installed on '71-'73 MKIV and 1500 models. It appears they can be installed on later models once you remove a plate at the front of the frame extensions. I should know within a week or so if it's a direct swap and will post results. Wish me luck.
Twinkie
Looking forward to see how you make out on that swap. I have a '78, and if I end up keeping it, I want to do that swap as well.
Keep us posted...
Ron
Administrator
Boss
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by ainadude:
If you're talking about the two front black rubber "underriders," yes, they can be removed. However, you'll be left with two body-colored frame extensions that look worse. I have a '76 and have ordered a pair of the less-obtrusive, earlier-style underriders that were installed on '71-'73 MKIV and 1500 models. It appears they can be installed on later models once you remove a plate at the front of the frame extensions. I should know within a week or so if it's a direct swap and will post results. Wish me luck.<hr></blockquote>
I, too, would like too see how your swap goes! If its not hard, I may like to loose my big ugly rubber overriders also! Send me a pic, or post it if you can put it one your own website (then just use the "image" button when posting to point to the picture).
Administrator
Boss
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by aeronca65t:
All of this talk suddenly made me think of this:
<hr></blockquote>
Now THAT's a bumber! Enough to make a 50's Buike envious
Dale
I am forwarding this from Dolly Parton "Shame on all of you for being ashamed" Big ugly overiders indeed.
Twinkie
And then I think about last summer when I watched a guy from my cafe table back into the front of my spit 2 or 3 times while parallel parking "by feel"! Wonder what the nose would've looked like then with the small over riders on...
Ron
eschneider Spitfire spitfire GT6 rubber source??? Triumph 7
L Spitfire New Acquisition, 1976 Spitfire Triumph 5
motzart007 Wanted In search of used seats for 1969 Triumph Spitfire MKIII Triumph Classifieds 0
B For Sale GT6/Spitfire License Plate Light Assembly Triumph Classifieds 0
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
A Spitfire Spitfire Diff Pinion Seal? Triumph 2
3798j General TR Spitfire up in the Tree Triumph 2
E Spitfire '69 Spitfire hard top Triumph 2
D For Sale 1966 Spitfire 4 MK 2 for sale, Triumph Classifieds 1
R For Sale Spitfire MKIII projects Triumph Classifieds 0
Darwin Wanted Spitfire engine needed Triumph Classifieds 0
G Spitfire Spitfire 1500 differential whining Triumph 6
T Spitfire Spitfire MK2 Clutch Hydraulics Triumph 2
A Spitfire Spitfire Fuel pump issues Triumph 5
P Spitfire 1979 Triumph Spitfire starts then runs rough Triumph 2
Lairhead52 Wanted 78 Spitfire instrument panel lights / lenses Triumph Classifieds 3
D Spitfire 1980 California Spitfire, Help Figuring What To Do With It? Triumph 15
W Spitfire 1975 Spitfire 1500 shifting problems when hot Triumph 8
K Spitfire 1978 Spitfire possible Vapor Lock? Triumph 16
R Spitfire Turn signal wiring Spitfire Triumph 5
S Spitfire Spitfire 1296 engines Triumph 1
D Wanted WTB: Late Triumph Spitfire Top Frame Triumph Classifieds 8
C Spitfire 1967 Triumph Spitfire Triumph 2
Dnickels Spitfire Spitfire mk2 front suspension too soft Triumph 2
T For Sale One Owner 1969 Spitfire for sale Triumph Classifieds 0
Dnickels Spitfire Spitfire lighting issues Triumph 4
SteveTheBrewer Spitfire Spitfire Rebuild Update Triumph 5
Basil Spitfire 74 Spitfire Barn Find Triumph 1
I Spitfire Triumph Spitfire 1500 refuses to awake after 10 year hibernation Triumph 6
I Spitfire spitfire 1500 refuses to awake after 10 years Triumph 2
B Spitfire Mk3 seat rails Triumph Classifieds 0
M Spitfire 1500 LH Door Triumph Classifieds 0
P Spitfire Bits Triumph Classifieds 1
M 1976 Spitfire 1500 (RHD) Triumph Classifieds 2
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 2
FlyingCat Wanted 1980 Spitfire Rear Bumper Triumph Classifieds 2
SteveTheBrewer Spitfire Triumph Spitfire Restoration Blog Triumph 22
R Spitfire Spitfire 1500 Triumph 3
T Spitfire Spitfire lights Triumph 7
Basil Spitfire How do I adjust SU carbs on my Spitfire? Triumph 5
F Spitfire No output from coil HELP!! 1972 Spitfire 1.3L Accusspark Triumph 19
glemon Spitfire Spitfire Questions Triumph 7
tr6nitjulius General TR TR6*8 TR4*2 GT6 Spitfire Triumph 2
J For Sale 1974 Spitfire for sale Triumph Classifieds 0
F Spitfire Triumph Spitfire , what fuel to run Her on with no engine history? Triumph 11
J Spitfire 1979 Spitfire Running rough [sputtering, exhaust poping] at start up Triumph 2
eschneider Spitfire Float height - '64 spitfire w/ dual HS2 Triumph 1
S For Sale Triumph Spitfire Workshop Manual on CD/ROM - 1962 - 1978 Triumph Classifieds 0
