TR2/3/3A Sluggish cranking on start up?
karls59tr
Bronze
Lately when I try to start up the TR3 the starter is very sluggish. Very slow cranking until it finally fires. The battery has a full charge and posts are clean and tight. I'm going to check the connections at the solenoid and at the starter itself to see if they have come loose. Other the the starter itself feeling it's age what else should I check?
What's the battery cranking power? A volt meter may show 12 volts, but that's without any load on the battery.
If the battery has a few years on it, the voltage may be 12 volts, but the "cranking power" itself may be weak. A better test is the voltage *under load*. Example of a battery load tester:
(also check ground straps, and starter lube if needed, and starter speed when all plugs are removed)
Check and clean all the grounds (body, frame, block and battery). Jump across the solenoid terminals with a screwdriver. If that doesn't diagnose it, first using the vehicle battery, use a pair of jumper cables to connect the starter body (one of the big bolts holding the starter on will do) to the ground post and the other from the power post to the power input stud on the starter. If that doesn't pep the starter up, try the same with a known good battery not installed in the car. These steps will give you the answer.
Do as Bob said, also after running the starter check the earth leads for heat, if you find they are getting hot they may need replacing or the contacts need cleaning.
Graham
If you do not want to buy a load tester for your battery, you could just drive to a nearby auto parts store and have them check it for free.
Charley
Actually I have a load tester and charging system and the battery tested out fine. I still have to do the tests Bob suggested. I will post what I find.:smile:
K TR2/3/3A Sluggish Cranking Update Triumph 3
D TR6 Sluggish Triumph 1
fpstude TR4/4A Another Wiper Question - Very Sluggish Triumph 12
nevets OD sluggish when cold Austin Healey 15
nevets sluggish OD, at first Austin Healey 24
V Car feels sluggish, What to test/check[New owner] Triumph 9
K Sluggish Midget- what could it be MG 3
Carlbanan56 MGB No spark and engine cranking slow MG 10
Sopwith_Camel Cranky but not cranking Spridgets 53
D TR2/3/3A Excessive cranking before it starts. Triumph 47
F TR2/3/3A Cranking Speed Triumph 4
S Petronix ignitor for pos.ground BG8 only has 3.2 volt when cranking. Austin Healey 8
B Just keep on cranking out the oldies ! Restoration & Tools 3
Tinkerman TR2/3/3A TR3 Cranking Dog Bolt Position Triumph 6
P No spark while cranking Triumph 10
G Setting timing without cranking the engine.... Triumph 2
S Healey Will Not Start (a.k.a. "Failure to proceed") Austin Healey 3
J Spitfire No start after fiddling with dash Triumph 2
AHSebring How do I create "Contact" to "Start Conversation" in my About Tab? FORUM Navigation Questions 1
O Wedge 79 TR7 no start Triumph 5
J MGB 1966 MGB won't start MG 1
L T-Series Hard to start MG 11
mctriumph General TR NEVER start a car with stale gas Triumph 0
K TR2/3/3A Timing chain rattle on start up? Triumph 2
KVH General Tech Initial Start Up After Rebuild Triumph 23
B Healey Won't Start - No Spark Austin Healey 38
T TR6 Perfectly tuned TR6 wont start when hot. Triumph 11
G Pre-War how to start a 55 mgtf. MG 3
KVH TR4/4A Hard Start When Engine Hot Triumph 20
K TR4/4A TR4 no start Triumph 26
M Spridget wont start Spridgets 50
D TR2/3/3A Getting difficult to start. Triumph 6
K TR2/3/3A Motor knocking at start up? Triumph 11
Q TR2/3/3A Where to start?! Triumph 13
Got_All_4 Wedge An issue with trying to start my TR7 Triumph 12
dougie Bruce McLaren's start in an Austin Healey Austin Healey 0
K TR2/3/3A Hard start questions.... Triumph 4
pairof75's General TR Circulate fluids without engine start Triumph 10
S TR2/3/3A Will Not Start Triumph 52
R TR2/3/3A Re-start after total restoration Triumph 22
S General MG 77 MG no start MG 31
B Cold Start Problems BN7 Austin Healey 21
S TR2/3/3A I have this miss where the car will start and kinda idle Triumph 23
J Spitfire 1979 Spitfire Running rough [sputtering, exhaust poping] at start up Triumph 2
K TR2/3/3A Help! No start! Need input from you guys. Triumph 9
T 100-6 start up issues Austin Healey 6
tr6nitjulius General TR AutoX & Rallye Start TRIUMPHest 2019 Triumph 0
K TR2/3/3A Mystery stall and no start? Triumph 7
K Left my key on for 5 hours and wont start, UGG!!!!!! Austin Healey 48
tr6nitjulius New Official Start Great Race 6/22/19 Video Other Cars 0
